On 4/9/2026 at 9:34 AM, fcschoenthal said:
Mine are plastic. I just use a sharpie to mark the segment. It doesn't rub of too easily
Ditto
On 4/4/2026 at 9:46 AM, gee-dub said:
While selecting material I came across this bit of figure. I couldn't resist placing it at the center of the top rail of the mirror frame.
This is one of my favorite tasks in a project, finding grain patterns that work with the shape of the piece.
Thanks.  The vac is handy but one standing on the floor can be just as helpful.  The Dust Deputy really kicks things up a notch.  Here's how that thing works . . .
@gee-dub, does 30 minutes of dry time leave the first corner's glue soft enough to fine-tune the squareness when joining the final corners? I usually have more luck achieving square when I can compare corner to corner measurements, than by using a reference square aganst the 'L'. I like the idea of making the frame in two stages, though.
Just thought I would mention that I use a rag in a can dripped with 3-in-1 to wipe down my planes before I put them away. I have never had any rust issues but I do live in a mild climate.
The can with the rag also holds my paraffin block and sets right on the plane till.
It is always satisfying to complete a project. I think the second most satisfying stage for me is the completion of surface prep.
Time for glue-up and then on to finishing.
Casting this out to the brain trust . . . .
The original frame stayed in place (including the dive off the wall during the earthquake in 1970) with just ten, 8d finishing nails surrounding the interior and levering against the mirror backer. I'm not saying that is how I would do it but obviously Somebody's Grandpa knew what he was doing:D. I am thinking I will use some #8 trim head screws as shown unless any of you wizards can suggest why I should or should not
Here's the frame on the elevating tables.
Here it is raised into position.
Here is the planned fastener of choice.
Opinions welcome.
I don't see any issue with the screws holding things together. It does seem tight to get to the screw heads to drive or remove them. You presumably have a good plan for that (and I am curious), but someone who follows you may not and may be tempted to do something "creative."
  • Who's Online   2 Members, 0 Anonymous, 72 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
