Hello everyone,
I'm getting ready to retire from the Air Force soon and am just beginning to pick up woodworking as a hobby. I've recently come across this Forum and Marc's videos. This seems like an excellent resource!
Within a month or so I plan to purchase a table saw. I've done quite a bit of research over the past couple years, and it appears that the Ridgid R4512 is the right model for me in my price range. I've read any number of folks that say to get rid of the stock bade and purchase a specialty blade. Blade selection is an area I could use some help in. Unless I win the lottery in the next couple weeks, I'm going to have to make some tough calls on how to spend my money.
I have no immediate plans to be working with any exotic woods. I would imagine I'll be working with something like, maple, oak, pine, MDF and melamine. I have to admit I don't know too much about woods yet, but I will clearly be starting with relatively inexpensive woods. I think it would be a couple years before I dabble with high end hardwoods. I would like to pick a single blade that will work well for typical applications (i.e. ripping and cross cutting). Are there other applications I'm unaware of?
I imagine there are some tradeoffs when selecting a blade. I think the most important quality I'm looking for is a blade that will produce a very clean cut with the least tearout and fewest blade marks as possible. Are there other tradeoffs/considerations I should think about? Of course I want to spend as little as possible, but I'm familiar with the concept of "you get what you pay for."
On this forum, I see a lot of very positive comments on the Forrest Woodworker II blades. There are quite a few 10" FWW II blades available. Am I correct that the 10", 48 tooth, 3/32" kerf blade (model WW10487100) is the best general purpose blade of the FWW II series? These FWW II blades seem to cost $100+ Thats a pretty hefty chunk of change. Heck, its 20% of the cost of the entire table saw!
The other option I'm considering is a Freud Diablo blade. Again there are a lot of options, but these options look to cost about half as much as the FWW II blades.
I would imagine a Freud Diablo is a pretty good improvement over the stock blade. Is that a good assumption?
Is the FWW II twice as good as the Freud Diablo? Is the improvement (Freud Diablo to FWW II) something that maybe only an experienced woodworker would notice or appreciate? Is it a small upgrade or a large upgrade?
I'll probably ask about dado blades in a separate post.
I would certainly appreciate any advice you have.
V/R
Adam
Some general rules of thumb:
If your saw is less than 1.5 HP, you may want to get a thin kerf blade. It removes less wood and requires less power, but some people report that they can flex.
Eventually you'll want blades for specific jobs (cross cut vs rip, plywood vs solid wood, dados, etc).
Make sure you get the right arbor size for your saw.
I've been really happy with the Freud blades. The Diablo series is less expensive but can be sharpened fewer times, because there is less material on the teeth. But for a little more you can get higher end Freud blades. I use the Freud LU83R010 10 inch 50 tooth ATB thin kerf and really like it.
There's a lot of good discussion in and I'm not sure how much there is that hasn't been said.
I use Diablos on my circular saw and my miter saw and have been very happy with the results. On my table saw I use a WW II, but just picked up a Diablo to use as a backup for when my WW is off to be sharpened (like right now). One advantage to going with the Freud blades is that instead of getting one high quality combination blade like the WW II you could get multiple task-specific blades (ripping, cross-cutting, etc.) for the same price and potentially get a better result for those jobs.
I have the FWWII thin kerf and have been using the same blade for almost 16 years. I sent it back to Forrest last year for sharpening and they honored a 15 year old certificate for discount on sharpening :-) I do have other blades that I use for "rough" work, but this thin kerf with stabilizer gives me beautiful cuts.
I'm lazy. I use combo blades most of the time. Unless I'm ripping a BUNCH of 8/4 or hard 4/4, then I'll suck it up and put on the rip blade.
The two blades I use most often are a WWII 40T combo and a Freud Industrial 50T combo. I keep the Freud in most of the time, and pull out the WWII for those "special" projects. But frankly, I don't know why, because if I'm honest, I can hardly tell the difference. As in not at all...except the Freud is a bit cleaner on cross-cuts and ply...and burns a little more on rips...for the obvious reason.
I think I got the Freud Industrial blade for about 60 bucks at Rockler with a 20% off coupon. It's far superior to the Diablo blades.
If you use a blade for its full useful life span then good blades will cost less than cheap ones in the long run. Personally the only time I change blades is to cut dados or melamine. Combo blades are just fine 99% of the time.
Don
==> Combo blades are just fine 99% of the time.
Let's modify that to 'sharp combo blades of good quality are just fine 99% of the time'. You could leave a WWII on for days/weeks at a time. I only change for sheet goods (Hi-AT) or when I'm going to spend the afternoon in a dedicated Rip session (I have a Forrest WWII custom grind ATBR -- I think it's a #6 grind)...
The key is a good quality blade that can be resharpened. I just bin my blades into a single shipment once a quarter and sent them to Forrest.
"best" depends on so many things....the 48T WWII will be the cleanest cutting of the WWII series, the best at crosscuts and ply cuts, but won't rip as efficiently...does that make it "best"?
I would imagine a Freud Diablo is a pretty good improvement over the stock blade. Is that a good assumption? Yes, but it might be worth spending a few more dollars for the Freud Industrial version...LU83, LU86, LU87, or LU88, depending on what you're looking at. You'll get more carbide for more resharpenings, and often more elaborate anti-vibration slots.
Is the FWW II twice as good as the Freud Diablo? Not in my opinion. The Forrest is excellent, while the 40T Diablo is "very good". If you want to eclipse the performance of the WWII, buy two blades....something like the LU88R010 and the LU87R010, or better yet, the Infinity 010-060 and 010-124 will give you the ability to rip thick wood more efficiently than the WWII, and will have cleaner cuts in plywood and cleaner crosscuts. Both of those 60T blades are versatile enough to leave in your saw for all but very thick ripping, at which point you install the 24T blade.
Tips for picking saw blades
Tips for buying a table saw
Never mind "eventually", start separating out cross-cutting and ripping operations from day one.
I agree wholeheartedly! I originally thought once nice combo blade would be good, mostly out of laziness and because I heard a number of others saying so. But I don't have a nice high HP cabinet saw like many others do.
Then I heard Tom Iovino make a great point on an older WTO program that has stuck with me ever since.
I'm pretty sure Tom has either the same or a very similar saw to the one I have. Mine is fairly new to me (less than a year) as your's will be to you. I'm sure, like me, you intend to keep and use it a while. The point Tom made is that our lower HP saws will bog down when using high tooth count combo blades to make rips where a large amount of material ends up getting removed. The gullet between the blades isn't there just to create space between the teeth. It's also there to remove waste - sawdust. A lower tooth count rip blade is designed the way it is for a reason. To remove the waste and create less stress on the saw.
After hearing Tom's argument, very logical, I bought a couple of different blades and make an effort to change to the right blade for the cut. It's a pain in the butt sometimes but I made an investment in this saw compared to the POSes I was using before and I intend to make it pay off. I have a 24 tooth rip, a 40 tooth combo and an 80 tooth crosscut.
As far as brand, I have a couple of the store brand carbides from my local big box but I also invested in a couple of Freud blades. I like the vibration dampening technology they cut into the face of the blade. I think it makes for a more consistent cut. Truth is, different people will like different brands for different reasons. I'm sure you'll find some good advice on here and come to your own conclusions. Good luck with your saw purchase and I'm sure you'll enjoy making sawdust as much as the rest of us.
If I were you I would try the stock blade and see how that works for what you're doing. It may work well enough for now and it will help you determine what matters most to you.
Also, if you are cutting melamine and want a crisp clean edge without chips in the melamine it is best to use a melamine blade. If you're not concerned about chipping the melamine a nice, sharp blade will usually leave you with one clean edge on the top when you run it through. Melamine can make your blade dull surprisingly quick as well.
As referred to above, I was helped with picking out my saw blade on here as well. I am glad I went with this blade: http://www.amazon.com/gp/product/B00008WQ2X
It has lasted through lots of Red Oak, Hard Maple, Soft Maple, Pine, etc. Still as sharp as ever, and cuts perfectly smooth. Especially with a ZCI. Makes a world of difference.
Also, look at the price on Amazon now, under $30 for this blade...that's a deal.
Hello again,
Thanks Knotscott, I'm still here... and thanks to everyone that provided some insight.
It definitely looks like there are a number of considerations and there isn't a single right answer.  I can't say I've figured out which blade(s) I'm going purchase yet, but it is reassuring that there wasn't a unanimous recommendation to buy the most expensive one.
As gpalmer suggested, I'll be sure to try the stock blade before buying anything else.  I suspect one of the common struggles for neophytes is determining if problems are the result of poor equipment, poor technique or some combination of the two.  Heck, given my lack of experience, I'm not even sure I could distinguish between cuts that are "top notch" and those that are merely "pretty good."  I suspect there are some subtleties that only experienced woodworkers will notice.
For what it's worth, I don't anticipate being able to make daily (or even weekly) forum posts for a while.  I can swing daily perusal of the forums, but I like to take some time when writing.  Sorry I didn't get back to folks sooner for responding to my original post, but like money, time is a limited commodity for me right now.  Of course I'm hoping that changes in the near future :)
V/R
Adam
Welcome Adam, I have the same saw and love it and I have to say that when I switched to Diablo blades I felt the superior cut in the first try. Even if you're not real prolific in the shop, you'll still appreciate a better blade.
The Freud Diablos and have kept me happy enough I've never considered switching. I've found that having full kerf rip and thin kerf combo blades work for me. The rip does it's job so much easier than a combo can rip.
Does the Diablo line even offer a full kerf rip blade?   I thought the whole line was TK until you get into blades of 12" diameter or more.
  • 2 months later...
This is going to sound odd, but I got a Freud 80T plywood/melamine blade.  Works great for crosscutting, particularly stuff that tends to fuzz a bit on the backside like poplar.  Here's the silly part, out of extreme laziness I tend to leave it on the saw for a lot of rip cuts too.  It actually does reasonably well ripping on softer woods, including poplar.  I'll get burning on stuff like hard maple and cherry.  I generally just use the 80T and switch to a 24T rip blade when I need to do serious ripping.  The two blades together cost about as much as a WWII.  So just don't think that you absolutely have to switch blades every time if you go the two blade route.
