Llama Posted December 1, 2013 Report Posted December 1, 2013 Yes, I know this is the hand tool area I found this at a local store, and was looking for more information about it. The tag stated that it's a Millers Falls #215. Quote
..Kev Posted December 1, 2013 Report Posted December 1, 2013 You'll need help Mel. You need to lift the table while you turn the crank. 2 Quote
Llama Posted December 1, 2013 Author Report Posted December 1, 2013 I hope not Google isn't helping either Quote
Byrdie Posted December 1, 2013 Report Posted December 1, 2013 Go to Shannon's site - renaissance woodworker. He's got a series of posts about the post drill he renovated and put to use. Quote
G S Haydon Posted December 1, 2013 Report Posted December 1, 2013 You'll need help Mel. You need to lift the table while you turn the crank. Good point TIODS, I had not noticed that. Quote
Eric. Posted December 1, 2013 Report Posted December 1, 2013 That's a cool piece. If I were you I'd rig up some pulleys and hook my donkey to it. Or use the water mill. I'm trying to think of a more efficient and convenient power source but nothing is coming to mind. 1 Quote
wdwerker Posted December 1, 2013 Report Posted December 1, 2013 You clamp the work piece to the table because you need both hands free. The top hand wheel is the feed downward and the side crank turns the bit. Quote
Llama Posted December 1, 2013 Author Report Posted December 1, 2013 Thanks for the info! I knew the top wheel locked the thing, but I didn't realize I would have to clamp the work to the table. Not ideal...I do want to get one of these, but I'd like a more automated version. One hand wheel would be nice! Any ideas on which one would fit my needs/wants? Quote
wdwerker Posted December 1, 2013 Report Posted December 1, 2013 They made a later model that had a flywheel and added some gears that advanced the feed . I saw one that was made to clamp to a post in a barn. Even long after power was available they would have seen use in a rural barn or remote forge. 1 Quote
sdesocio Posted December 1, 2013 Report Posted December 1, 2013 Doesnt Roy have a bigger one that he uses from time to time? Quote
TRBaker Posted December 1, 2013 Report Posted December 1, 2013 Mel, check out the veneer gluing thread that is currently active. Vic recommends a video on glue-ups and in the background is a neat drill press. Byrdie spotted it. 1 Quote
Daniel Kuehl Posted December 2, 2013 Report Posted December 2, 2013 Doesnt Roy have a bigger one that he uses from time to time? There's an episode where Roy demonstrates how a bunch of old pedal powered machine were used. I don't think it's a miller falls though... 1 Quote
Daniel Kuehl Posted December 2, 2013 Report Posted December 2, 2013 Here's a link to the video...Post drill "bit" starts at the 17:00 min mark. http://video.pbs.org/video/2263882759/ Quote
Tom King Posted December 2, 2013 Report Posted December 2, 2013 I don't think it would be hard at all to use if you were really coordinated, and had three hands. 1 Quote
calblacksmith Posted December 3, 2013 Report Posted December 3, 2013 Sorry, double post but here are the post drill pics from my post below. Quote
calblacksmith Posted December 3, 2013 Report Posted December 3, 2013 Well, I am a bit late in posting but yes it is a post drill. I have a Champion post drill in the pics below. The handle has been removed but that is only one screw. The drill has a ratchet mech that is activated by the cam which is on the mount for the hand crank. The flywheel is crowned so it can be run with a flat belt setup if desired. They work well and the auto feed really helps and you do not need 3 hands to run the drillpress. In a similar vein, the Cole drill is a hand powered drill that uses a feed nut to apply pressure to the drill bit. It can apply up to a thousand pounds of pressure to the drill bit per the makers advert. It can be used in tight spaces, at odd angles and even have the bottom removed, flipped over then clamped to a table then used as a drill press. It is more accurate to drill this way than with a hand drill. Cole also made a vise and I am in process of buying one, I will see if it pans out. The two Cole drills I have I bought for less than $50 for all. The one with the shaft was at an equipment auction and the one without a shaft was at a antique store. The shaft is a standard 1 1/8" so it is easy to replace. I just thought I would put in a few cents worth on the topic of hand powered drill presses 1 Quote
rodger. Posted December 4, 2013 Report Posted December 4, 2013 That's a cool piece. If I were you I'd rig up some pulleys and hook my donkey to it. Or use the water mill. I'm trying to think of a more efficient and convenient power source but nothing is coming to mind. ROFL Quote
