rodger. Posted March 3, 2016 Report Share Posted March 3, 2016 Doing some ripping of plywood sheets on the TS. I am currently using my rip blade, but I was wondering if a combo blade would be more appropriate. I don't really need a dedicated plywood blade, so I would just like to use one of the three blades I have (Rip 24T, combo 40T or combo 50T). All blades are high quality blades, and are clean and sharp. Which one is best? Quote Link to comment Share on other sites More sharing options...
Woodenskye Posted March 3, 2016 Report Share Posted March 3, 2016 I would go with the 40 or 50 tooth blade. Marc mentioned he uses a 40 tooth blade for ripping plywood recently. I only use a rip blade when ripping 6/4 or thicker hardwood, because I have a contractor saw. 1 Quote Link to comment Share on other sites More sharing options...
Chestnut Posted March 3, 2016 Report Share Posted March 3, 2016 More teeth is better. My plywood saw holds a 60tooth blade (7.25") and it works wonderfully for ply doesn't tear out nearly as much. I break down sheets with a circ saw because i don't have enough room to maneuver a full sheet in my shop. I've also done the arguably unsafe climb cut that Matthias Wandel suggested to get clean ply cuts and it works well. https://woodgears.ca/shop-tricks/tearout.html 1 Quote Link to comment Share on other sites More sharing options...
Tom Cancelleri Posted March 3, 2016 Report Share Posted March 3, 2016 More teeth is better. For a cleaner tearout free cut, you can lower the blade and take a small scoring of the underside that's about 1/16" deep before raising the blade to complete the cut. I did that a bunch on the vanity when I did the drawer faces, just for extra tear out protection. A Zero Clearance insert will also help. 2 Quote Link to comment Share on other sites More sharing options...
Robby W Posted March 3, 2016 Report Share Posted March 3, 2016 I use the Forrest Duraline AT blade for plywood and surfaced goods. I get very little to no tearout on either face. No a cheap blade, but since I seem to cut a lot of sheet goods, worth every penny to me. It is a 60 tooth, high ATB blade. 1 Quote Link to comment Share on other sites More sharing options...
TerryMcK Posted March 3, 2016 Report Share Posted March 3, 2016 For a 10" blade you need to aim for 60 to 80 teeth. Blue tape and.or zero clearance insert on the table saw helps to minimize tearout. 1 Quote Link to comment Share on other sites More sharing options...
knotscott Posted March 3, 2016 Report Share Posted March 3, 2016 I'd use a 40T or 50T over a dedicated ripping blade....both will leave a better cut. If all else is equal, I think the 50T will have better edge life than the 40T. If your plywood volumes are really high, and cut quality isn't a top priority, it might be worth looking into a blade with a triple chip grind (TCG)...best edge life of all other grinds. .For best cut quality, a good Hi-ATB grind will be hard to beat, but edge life isn't as good. 1 Quote Link to comment Share on other sites More sharing options...
Brendon_t Posted March 3, 2016 Report Share Posted March 3, 2016 Although not specifically for plywood, I have an 80t dewalt blade meant for laminate flooring. That's what I use on ply. Leaves a great cut line, little to no chip out, no burning. 1 Quote Link to comment Share on other sites More sharing options...
Phil B Posted March 3, 2016 Report Share Posted March 3, 2016 +1 to the more teeth is better camp. I use an 80T 10" on my TS for plywood and get pretty good results. For better chipout control there are 3 things you can do: plywood blade (60 or 80T on a 10" blade). zero clearance insert. scribe the keeper side of the kerf with a knife. Blue tape can help but I find it a bit of a nuisance. Another way to improve chipout is to use higher quality plywood like baltic birch. 1 Quote Link to comment Share on other sites More sharing options...
ChrisG-Canada Posted March 3, 2016 Report Share Posted March 3, 2016 I use a Freud Industrial 60T blade and it cuts ½" and ¾" plywood with zero tear out 1 Quote Link to comment Share on other sites More sharing options...
rodger. Posted March 3, 2016 Author Report Share Posted March 3, 2016 Thanks for all the replies fellas. I have used the blue tape trick many times with ply, but I have 4 full sheets to break down into many pieces. This is too much material to realistically use blue tape. I'll switch out the blade for the 50T, and continue to use my ZCI. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted March 3, 2016 Report Share Posted March 3, 2016 Other than all of the above good suggestions try cleaning the blade first. Any resin build up will lead to heat and gather more resin from the ply. Quote Link to comment Share on other sites More sharing options...
Jim DaddyO Posted March 3, 2016 Report Share Posted March 3, 2016 Good suggestions. I would add to put your show face up on a table saw too. That way the blade is going "into" the show face as it cuts, compressing the fibres into the wood instead of trying to tear it out as if exits. Opposite for a circular saw, show face down. This works: Quote Link to comment Share on other sites More sharing options...
Nestor Posted March 3, 2016 Report Share Posted March 3, 2016 A zero-clearance insert dedicated to the blade you choose might help. Before making the kerf on your insert, give your saw a once over to ensure your table is square and the blade is at 0 degrees. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
