How's the extraction on your drum sander? Is anyone left with a pile of dust that rolls off the conveyer after the piece comes through?
I've using one of these: https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcTvKnMUpKmqoZ95vJeKDEjqDYIDO9tYvS3arAigYs4PtOOQMQoX7_a6Fp3F
It's a twin drum sander with two 4" outlets. The dust extractor is more than capable but I'm still ending up with a pile of dust at the end of the board.
Could it be trying to take to much off at once? Poor design? Or something that happens to all of them?
2 minutes ago, bushwacked said:
in for info and curiosity.
Also, how much are you taking off in each pass?
Probably about 0.5-1mm. Not sure what that is in inches. I'll start a piece going through and raise the bed until it just touches and then turn the handle a tiny bit to take another pass until it's done.
26 minutes ago, bushwacked said:
to rule out taking too much off, just raise it up until it touches, but dont turn anymore ... if still getting dust coming off then its a design issue or dust collection issue I would lean toward.
This is what I do, turn it until it just touches and then each pass is a quarter of a turn at most which is approximately 1/64".  I end up with virtually no dust on the project or belt.  I am running a 1.75 hp DC with my SuperMax 19-38 and the DC run is about 25 feet.
I know for my shop built, lathe based, drum sander, I had a serious issue with the dust initially.   I only had the DC pointed in the general direction of the sander, and ended up having to wear a full face respirator just to keep the dust out of my eyes and mouth, and I'm not a respirator type guy.   Once I built a simple hood out of a pvc pipe, and connected the DC directly to that, I could run the machine with little dust in the air.  Yes, I get some buildup on the bed itself, but very little airborne.
Not sure how that helps you, but there it is.
When my filter is getting clogged I see this happening, sometimes using fine grit paper too. I use a separate dust collector on my drum sander, became tired of fighting the fine dust mixed in with the chips and constantly cleaning the filter bag.
-Ace-
You keep saying "extractor."  A shop-vac is an extractor and it's not capable of pulling enough CFM to collect from a drum sander.  A dust collector is a dust collector...are you using an extractor or a dust collector?  If the latter, how much power and how far is the run?
I have exactly the same setup as gd, except with an aftermarket cyclone and I exhaust outside so there's no filter impedance.  I've never had an issue...in fact the drum sander is one of my more efficient machines for DC.
6 hours ago, lewisc said:
I suppose we'll call it a dust collector. The manufacturer said it's 7.5kw. Google tells me that converts to 10hp. It's a big unit so that sounds about right to me. One of these: http://www.micronair.com.au/files/7713/6496/2317/VC4S_Brochure_13.pdf. There is about 30metres of ducting with various points and gates for connecting flexible hoses for the machines.
Whoa.  If you can't collect with that thing then there's either a problem with the sander's DC engineering, or you sucked up a wallaby and it's stuck in the duct.  Otherwise I have no advice because you have plenty of power.
BTW...if you're gonna put a link out there for people to click, you should warn them they're about to download Encyclopedia Britannica.  That goes for all PDFs, but especially huge ones like that.
@lewisc That unit certainly looks like its up to the task.  The air flow is way above my unit which does a very good job.  I wonder if the sander has any internal baffling that could have come loose and is causing spoil to be misdirected?
Will dust get picked up off the bed with the collector running and no material present.?  Mine is a single drum but, for example, if the machine is just setting there, not turned on and with no material present . . . with the collector running if I toss a bit of sawdust onto the bed under the drum area it gets suck away.  Since you state dust is left behind I assume this is not happening on your machine. Using this method you might be able to find what is going on.
I only have a small 12" wide drum sander which has only 1 small 2.25" port which I have connected to a 4" hose / 2Hp cyclone. The dust collection is good in that there are no clouds emerging from the machine and I've run it for a couple hours at a time with nothing visible or discernible in the air. There is however very small 'piles' that will drop off the belt as you describe sometimes.
You've probably already checked but... is there anything obstructing dust collection inside the machine?  Have you verified that suction where the dust collection piping/hose attaches to the machine is adequate?
The dust collection you have seems like it might be powerful enough to suck all the dust you could possibly produce - makes me wonder if there's some sort of blockage.
There's nothing blocking it. The outlets sit above the middle of drums. It sucks up a fair bit of dust but there is always a pile of dust that doesn't get sucked up - it could just come down to trying to take too much off or the ports are not adequate for the width of the sander.
Its currently got two 4" Outlets that go into a 4" Y connecter into a 4" hose. I'm modifying the ducting to go from 6" pipe to two 4" pipes to see if it makes a difference.
Perhaps try turning your feed rate down. I see you have some burning going on. I know it happens, but when I start to see burning. Stop, clean or change the paper and slow the feed rate down and take a less of a cut.
-Ace-
That 4" wye was killing your airflow.  Going directly from 6" to two 4" will make a big difference.  There is still more cross-sectional area in a 6" pipe than in two 4", so you could theoretically drill out another hole in the middle and add a third 4" port to get a little bit more if you still aren't where you want to be, but you'd really want to increase the 6" too to take full advantage.
Thanks all for your suggestions. The problem has been solved. The solution was changing the ducting around at the end of the run. I put in a 6" Y branch that splits into two 4" pipes. It's pulling dust from the bed and leaving nothing behind to fall off the sander.
Running a 4" pipe and then splitting that into two 4" pipes was limiting the air flow and the main source of the problem. I'll still have to remember watch out for how much is being sanded off.
  • Who's Online   4 Members, 0 Anonymous, 50 Guests (See full list)
    26,008
    Bob44
    Bob44
