Cliff Posted November 11, 2017 Report Posted November 11, 2017 After 5 years of living in this house, my wife finally picked out some sconces. We wanted to minimize seeing the cords, but not have to hardwire them. So I came up with a solution that included a live edge shelf made from material that was left over from my kitchen counter-tops. First I resawed and glued together a 2.5" thick piece of walnut with some tiger striping. Took me a long time to decide what to use this for. Originally I wanted to make a bench but it was just too thin. The glue up was pretty good but a bit misaligned, so I had to clean it up. No matter what I do, I can't get rid of the damn tracks on my LAJ. Honestly this time I think I had the blade too far out. Because I did the cambering with the LV jig. But luckily my favorite tool was available to do the cleanup. Scraped down the entire thing to get it cleaned up. Squared and trimmed up the ends. This is the live edge before epoxy. After putting epoxy on the shelf, I tested different places to put the shelf. I decided it looked stupid in the center, like shown below. So I ended up going with 2 inches from the bottom. 2 Quote
Cliff Posted November 11, 2017 Author Report Posted November 11, 2017 I made the mortise for the shelf to sit in. Definitely my best work yet in terms of getting things sized correctly. I still ended up with some small gaps. But I plan to use walnut wood filler on them. Honestly since live edge is sorta.. rustic in nature, I think it wouldn't hurt to ignore the gaps but it bothers me. Some pics of gaps- And a test fit Quote
Cliff Posted November 11, 2017 Author Report Posted November 11, 2017 The sconces were centered on either side of the shelf. I drilled a hole for the cord to go through, and then made little blocks with a curve that almost (but not quite!) matched the curve of the sconce. That way you won't be able to see the cords at all. Um, I sorta forgot to take pictures of that. I also forgot to take pictures of the french cleat and "stabilizing block" on the back that will help it sit on the wall. In my defense, I was watching Halt and Catch Fire on the laptop and hadn't intended to journal this anyway. Today, I glued the shelf in. I'll add some 4" spax screws to the back that I've already pre-drilled for. It went in decently square, maybe 1/32nd out. I knew that would happen based on the test fit, so I had clamps standing by. You can also see my blocks that will cover the cords here - I find it difficult to match a curve, hopefully will get better at that. Tomorrow I can do my final sanding touchups (already sanded to 220 but I've scuffed some things) and get the first coat of ARS on. 2 Quote
wdwerker Posted November 12, 2017 Report Posted November 12, 2017 Only another woodworker might ever notice those tiny gaps. I guess it's just in our nature, I would have filled them too ! 1 Quote
mat60 Posted November 12, 2017 Report Posted November 12, 2017 Its funny how something a small as the gaps can bug the crap out of us when most would never notice. Still very nice work Cliff. 1 Quote
Llama Posted November 12, 2017 Report Posted November 12, 2017 If you cut a shoulder on the shelf, that wouldn't happen... Quote
Cliff Posted November 12, 2017 Author Report Posted November 12, 2017 43 minutes ago, Llama said: If you cut a shoulder on the shelf, that wouldn't happen... True. I didn't think of that. Quote
Coop Posted November 12, 2017 Report Posted November 12, 2017 Looking good Cliff. I like your clamp configuration! Quote
Cliff Posted November 21, 2017 Author Report Posted November 21, 2017 Third coat of finish is on in this pic. It's looking pretty good, but I can see a couple of spots where I didn't sand well enough. I gotta learn to slow it down triple check because I get so eager to get the project done. Obviously my next project is cleaning. The shelf Plasticy but not as bad as I thought it would be. My bedroom will never have super bright fluorescent lighting, and no one will ever get this close to it. And finally.. the biggest gap by far.. with the wood filler. I can see it like it's a supernova against a dark sky, but hoping nobody else will. I also think this picture was after sanding on the third coat, before 4th coat. Quote
prov163 Posted November 22, 2017 Report Posted November 22, 2017 We’re always critical of ourselves. But we should always strive to do our best work. That’s a beautiful piece. Are there two sconces? Quote
Cliff Posted November 22, 2017 Author Report Posted November 22, 2017 1 hour ago, prov163 said: We’re always critical of ourselves. But we should always strive to do our best work. That’s a beautiful piece. Are there two sconces? Yup. Next picture will be it up on the wall with the sconces. I'm waiting 7 days on the finish then a final polish before install. Quote
Popular Post Cliff Posted November 26, 2017 Author Popular Post Report Posted November 26, 2017 I still need to make some cord covers, since I placed it higher than I had intended and my wife hates seeing cords. But it's done! 6 Quote
bushwacked Posted November 27, 2017 Report Posted November 27, 2017 oh that looks great! I had a hard time figuring out what it would look like on a wall, but that is nice!! Is anything actually going on the shelf? Quote
Chestnut Posted November 28, 2017 Report Posted November 28, 2017 I could see a nice clock or a vase for flowers, I'd have a hard time covering up the nice looking wood though. I like it Cliff good work! 1 Quote
drzaius Posted November 28, 2017 Report Posted November 28, 2017 Wiremold makes some channel that, when painted the wall color, is very unobtrusive. Home Depot carries them Quote
Cliff Posted November 28, 2017 Author Report Posted November 28, 2017 10 minutes ago, drzaius said: Wiremold makes some channel that, when painted the wall color, is very unobtrusive. Home Depot carries them Thanks, I'll check that out. Might be better than making a walnut one. Quote
drzaius Posted November 28, 2017 Report Posted November 28, 2017 Just now, Cliff said: Thanks, I'll check that out. Might be better than making a walnut one. Ya, I think one made of walnut would draw attention to itself. Quote
mat60 Posted November 28, 2017 Report Posted November 28, 2017 That came out great Cliff. Bet your wife is happy. 1 Quote
