duckkisser Posted September 8, 2020 Report Share Posted September 8, 2020 I want to build a garbage cabinet to put along my stove but they don’t make cabinet slides that are 30 inches long at least ones that don’t cost 80 dollars from custom stores. I wanted to make my own wooden ones like they use in old dressers. But I’m worried that something that long will rack or get stuck and won’t work. I had thought to build a cabinet with space length wise for two garbage cans so I just pull on drawer to access both cans. The other option is to build a roll out cabinet where I pull the whole unit out to get to the garbage cans. If I make it into a rolling cabinet I can use it as a rolling cutting cutting/prep station. my concern is how heavy will this be both on a wooden slide or as a rolling cabinet. Also there is not a lot of room for cabinet/ slides/ drawer to hold trash. Any ideas or thought on how to best do this Please share. If you have built a tilt out garbage can how much did it cost so I have an idea of price. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted September 8, 2020 Report Share Posted September 8, 2020 Drawer slides shouldn't rack when they are longer than they are wide. But in your case, I think I would put the case on casters and roll the whole thing out. Also, you will lose some usable volume for a tilt-out. Quote Link to comment Share on other sites More sharing options...
curlyoak Posted September 8, 2020 Report Share Posted September 8, 2020 The bottom fits into a dado on the door. The added 45 degrees oak on one side keeps it in place. In the cabinet I made a elongated L. That gives me an easy way to fasten to the bottom and the hardware. After 15 years I replaced the slides. Above is a printer I wanted more extension. I had enough vertical space to do this. And all the parts and pieces were on hand. 1 Quote Link to comment Share on other sites More sharing options...
Chestnut Posted September 8, 2020 Report Share Posted September 8, 2020 https://www.wwhardware.com/kv-8605-140-lb-over-travel-drawer-slide-zinc 28" and I think a 1" over travel supports 140 lbs $34 per pair plus shipping. Cheaper and faster than making your own. One of the places that manufactured slides just make sense. There are a lot of other options on that site as well, may be able to find something cheaper. https://www.woodworkerexpress.com/ This is also a good source I use. Typically for blum hinges as their prices is almost always the cheapest and is usually 60% less than what rockler wants. Quote Link to comment Share on other sites More sharing options...
legenddc Posted September 9, 2020 Report Share Posted September 9, 2020 I have a skinny cabinet next to my oven and put this in it. Works pretty well for our recycling. Still have a drawer above it too. I was going to custom make one, but by the time you find trash cans to fit it was cheaper to buy that thing from Lowes. Cabinets are normally 24" deep, are yours 6" deeper? 1 Quote Link to comment Share on other sites More sharing options...
duckkisser Posted September 10, 2020 Author Report Share Posted September 10, 2020 I was going to make a cabinet the ones you see there are custome cabinets that previous owner built out of plywood. Kinda ugly but they do the job. But after your post legend I moved some stuff and I’m thinking I might buy one of those pull out racks. Thinking I’ll put some kind of rack for pots along my stove so I can still have a counter along my stove. How well do those racks hold the garbage cans? Quote Link to comment Share on other sites More sharing options...
Popular Post drzaius Posted September 10, 2020 Popular Post Report Share Posted September 10, 2020 Here's my take on this very worthwhile project. Originally, it was just a slide out platform at the bottom with a door attached. Problem is, any trash that missed the can ended up at the bottom & tended to accumulate. I rebuilt it as shown below with the platform at the top & holes cut out to fit dedicated trash & recycling bins. The bins were from Ikea & were far better & cheaper than anything I could find at Lowes, HD, Walmart, etc. I removed the recycling bin to better show the construction. The child proof lock is to keep the cats out cause they will open it & empty it all over the kitchen. 5 Quote Link to comment Share on other sites More sharing options...
legenddc Posted September 10, 2020 Report Share Posted September 10, 2020 @duckkisser Ours has held up well for the last year or so that we've had it. The cans come with the one I bought and linked too. My parents have one like drzairus that has held up pretty well over the last 20 years. I like that style better, but given your space, you may need to use the bottom mount one that I showed. Once you get under 12" it's hard to find ones that fit. If you're at 14" you might have more options. Quote Link to comment Share on other sites More sharing options...
DerekMPBS Posted September 23, 2020 Report Share Posted September 23, 2020 If you live near a university you might go to one of their surplus sales and see if you can score an old rack-mount server that has the rails attached. Those server rails can support a lot of weight, are full extension, and come in lengths up to 36" long. Most are side-mount. You can buy them new as accessories, but they are expensive, often more than $100/set. 2 Quote Link to comment Share on other sites More sharing options...
