On 7/9/2023 at 8:41 PM, Chet said:
You are tougher then me, I'd have the worst case of heebie jeebies, would of been twitching all night if I left my bench like that.:lol::blink::unsure:
Not gonna lie I was a little shocked when I walked in apparently i was really into what I was doing LOL
On 7/10/2023 at 7:10 AM, Chestnut said:
I really want to try out a shaper to see what they are like. I feel like for the little bit of CNC work I'd want to do they are perfect, but by no means inexpensive.
Also the bolt cutting trick is great. I never learned that for the longest time and getting the nuts back on was always a PITA.
Drew if you ever want to give it a try just let me know and we can set something up. Its pretty straight forward but still a learning curve for me. I am looking forward to the new Trace product since I spend a fair amount of time designing in studio it should streamline that process. Ultimately like any tool I just need to use it more hence the exercise today.
That'd be awesome. I'll have to think of something and then find some time. Will you be around sometime in 2040 probably mid summer. That's after Hazel graduates so I might have some more time :D. Joking i can probably find time earlier but it still might be a while.
  • Haha 1
Well it's definitely been a while since I have turned but got through it in what I would call usable parts :)
First up I needed a handle for the adj pin so turned the blank to 1 1/2"
Once I got it turned I needed to drill a 1/4" hole in one end to accept the pin. Big problem found the chuck but couldn't find the dang key (since found) so I moved on to the Head hold down. This one I just needed an 1 3/4" round with 7/16" pins on each end. Not perfect but it will work
Getting there...
With that complete I needed to drill a 3/16" hole for the stop pin
With that it was time to trim the ends off
Next up was to plane the flat on one side
First I tried the #4 - to big, then a block plane - to small, finally the #3 - aah just right
That's it for today. Now that I found the drill chuck key I can finish the handle in the morning and then turn the stop pin. After that I will make the brackets for the stop and that will finish up the head. Getting pretty close now after the above just some clean up and the seat to go.
On 7/22/2023 at 7:37 PM, Coop said:
Two tools I’ve never heard of, Scorp and Baked Potato .
To be clear while the first is truly a Scorp the second is a Travisher this one is referred to as the baked potato becuase of its shape :)
On 7/23/2023 at 8:38 AM, Mark J said:
Paul, do you plan to sand the concave seat surface at all?
I will raise the grain in an effort to get some of the sap/pitch out of it during the finishing process so I will have to at that point but just a light hit of 150 or 220.
  • Who's Online   1 Member, 0 Anonymous, 56 Guests (See full list)
    26,008
    Bob44
    Bob44
