fcschoenthal Posted February 5, 2025 Report Posted February 5, 2025 On 2/5/2025 at 9:27 AM, gee-dub said: I choose parts out of a board which results in more waste than may be "normal". Unless you're going for that look, that would be the only way to make good use of a board with all of the sapwood. 1 Quote
Popular Post fcschoenthal Posted February 5, 2025 Popular Post Report Posted February 5, 2025 On 2/5/2025 at 9:27 AM, gee-dub said: If I had to make guess I would go with having 85 bf on hand if you want to make one Never said that I wanted to make one, just arming myself if the wife ever sees the one you made and wants one like it. 4 Quote
Popular Post gee-dub Posted February 10, 2025 Author Popular Post Report Posted February 10, 2025 I just use a magnetic stop at the bandsaw to cut the Blum slide relief gaps in the rear of the drawers. Then free hand the short cuts. I pre-finish the insides of the drawer box components with a clear shellac. I keep a couple of these old hand cream jars with shellac and a rag inside. One is "clean" and is used for things like the drawer parts. The other is "dirty"; the clean stuff gets dumped in there if it gets polluted and then the "clean" container gets fresh stuff. I use this "dirty" stuff for shop fixtures, chisel handles, refreshing vise chops, and so forth. I was able to mill the drawer faces from a single board which makes them match up nicely. They will get profiled but will look sort of like this. The door frame parts get M&T joinery. There will be floating panels so there will be grooves. This particular batch of sapele has been tear-out prone so I wheel scribe the groove boundaries. Highlighted here with some white pencil to make them easier to see. I use a slotting bit at the router table and the wheel gauge scribe lines yield me nice clean cuts. Time to size the door panels and then profile them and the drawer fronts. 7 Quote
fcschoenthal Posted February 10, 2025 Report Posted February 10, 2025 On 2/10/2025 at 11:56 AM, gee-dub said: I just use a magnetic stop at the bandsaw to cut the Blum slide relief gaps in the rear of the drawers. I've got a couple of drawers to make soon and plan on using the undermount slides to match some existing. I've seen two ways to allow for the slides in the back. Cut the gaps like you did before assembly and leave the rear drawer panel narrower than the sides, then putting a couple of screws through the drawer bottom into it to hold. Is either better than the other? Quote
gee-dub Posted February 10, 2025 Author Report Posted February 10, 2025 On 2/10/2025 at 10:13 AM, fcschoenthal said: I've got a couple of drawers to make soon and plan on using the undermount slides to match some existing. I've seen two ways to allow for the slides in the back. Cut the gaps like you did before assembly and leave the rear drawer panel narrower than the sides, then putting a couple of screws through the drawer bottom into it to hold. Is either better than the other? I am far from a Blum expert but, the rear of the slides have a pin that inserts into a hole you provide at the rear of the drawer box (@16:33 in the video). This acts as a capture and an adjustment point. I have seen Andy Rae use a block of wood the width of the drawer back instead of the hole. This is fine as long as you don't need to use the adjustment feature. Here's a good video on the process which seems to be overly complex if you are trying to use their documentation. It is one of those things that once you get your head around it, it makes sense. Starting from a standing-stop and using the Blum docs can make you crazy BTW, I use the Rockler Jig-It drill jig shown in the video. It is a bit pricey at full-pop but goes on sale often enough. Quote
fcschoenthal Posted February 10, 2025 Report Posted February 10, 2025 I've watch most of Jason's videos (sometimes he gets too long winded). Here is another of his where he's installing undermount slides with the short back. While it's a different manufacturer, the installation is the same. I guess it's basically whichever you want to do because both work. I'm putting these in the kitchen of a rent house, so will probably use the short back with the screws. That way, I can remove the bottom and replace if something happens to it. 1 Quote
pkinneb Posted February 10, 2025 Report Posted February 10, 2025 Your work is so clean its impressive @gee-dub!! Reminds me of Philip Morley's and something I aspire to someday 1 Quote
Popular Post fcschoenthal Posted February 10, 2025 Popular Post Report Posted February 10, 2025 His shop is too clean too. Makes you wonder if he cleans up before taking the pictures. 1 2 Quote
Popular Post gee-dub Posted February 11, 2025 Author Popular Post Report Posted February 11, 2025 On 2/10/2025 at 3:53 PM, fcschoenthal said: His shop is too clean too. Makes you wonder if he cleans up before taking the pictures. It's all about camera angle. Things look good but just 'out of frame' lie the bowels of hell Seriously, a slow careful approach will give you better success and less lost time than hurrying forward and making mistakes. I guess I have just learned that slow and steady does indeed win the race 3 1 Quote
Popular Post gee-dub Posted February 11, 2025 Author Popular Post Report Posted February 11, 2025 I rip the door panels to final width. I do a test profile to check the fit. The white pencil marks are 1/4" in from the edge. These lines disappear into the groove which tells me I have the depth I want. I put blobs of silicone rubber glue in the grooves as opposed to space balls. This lets me position the panels and 24 hours later I have them setting just where I want them in custom fitted space balls. Not much makes it into apiece in my shop directly from the machine although there are exceptions. These panels and the drawer fronts will get a kiss from the Millers Falls No.9 (Millers Falls defines their planes by actual length) which is the equivalent of a Stanley No. 4. OK, test fit is good. Let's move on . . . I keep a piece of chalk in a holder in my apron. I use it for all sorts of witness marks to help me track my progress (or lack thereof) while working the material. My old buddy Gulf Wax steps in to make my hand tools move smoother. A raking light is always helpful when trying to assure a surface prep is "done". And the drawers and doors will look sort of like so. I still need to glue up the door frames and then profile the outer edges of them. However, it is getting close and I am excited to lay on some finish. 8 Quote
fcschoenthal Posted February 11, 2025 Report Posted February 11, 2025 On 2/11/2025 at 3:08 PM, gee-dub said: I put blobs of silicone rubber glue in the grooves as opposed to space balls. This lets me position the panels and 24 hours later I have them setting just where I want them in custom fitted space balls. You've probably got the process down, but do you ever have issues using silicone as a spacer? I'd have a hard time getting the right amount in the groove and worry about getting some stray where I didn't want it, messing up either the fit or the finish. Quote
Popular Post gee-dub Posted February 11, 2025 Author Popular Post Report Posted February 11, 2025 On 2/11/2025 at 1:40 PM, fcschoenthal said: You've probably got the process down, but do you ever have issues using silicone as a spacer? I'd have a hard time getting the right amount in the groove and worry about getting some stray where I didn't want it, messing up either the fit or the finish. I have had a bit of squeeze out here and there. I generally try for a "blob" about 1/4" in diameter. I put at least two per edge. Silicone rubber takes a good long while to cure so if you check back on your glue up and see squeeze out you can use an awl and a paper towels to pretty well clean any of that up. I can absolutely state that learning this required a series of less-than-desireable results back in the past. That is one of the great benefits of the forums I get to learn from your past mistakes and you get to learn from mine without duplicating them (hopefully) 4 1 Quote
fcschoenthal Posted February 11, 2025 Report Posted February 11, 2025 Thanks for the tip, I'll give it a try. If nothing else, I'll lay out a bead of silicone and then cut it up into ball size pieces. Quote
Popular Post gee-dub Posted February 11, 2025 Author Popular Post Report Posted February 11, 2025 Pre-finish color tint on the door panels. Looks a little rough but the sapele really pops when the finish hits it. 6 Quote
Popular Post wtnhighlander Posted February 12, 2025 Popular Post Report Posted February 12, 2025 @fcschoenthal, I recall a magazine article that suggested laying beads of silicone onto a sheet of waxed paper, letting them cure, then cutting them up for DIY spaceballs. @gee-dub, do you hit your wood supplier with a cut list in hand, searching for stock with good grain for the parts you need, or do you buy up nice stock in advance? Obtaining stock that gives me enough material for good grain & color match in a project may be my biggest struggle. 3 Quote
Popular Post gee-dub Posted February 12, 2025 Author Popular Post Report Posted February 12, 2025 On 2/11/2025 at 7:04 PM, wtnhighlander said: @gee-dub, do you hit your wood supplier with a cut list in hand, searching for stock with good grain for the parts you need, or do you buy up nice stock in advance? Obtaining stock that gives me enough material for good grain & color match in a project may be my biggest struggle. I hear you on the color match issues. I know a lot of folks let the lumber yard "store their wood for them" and they just go buy it when they are ready. I have collected a lot of stock in the pre-COVID years. When I see today's prices I realize I have "gold in them thar hills". Still, when this project came along I had to make a lumber run as I had just finished a large project out of sapele. I do kind of go into a "zen state" at the yard and really take my time. This is absolutely not my normal state . I have learned to take my time at the yard, when doing surface prep, and when finishing. Thank goodness for my wife's tolerant nature because at almost all other times I am a frenetic goof ball. When I am lucky enough to pull boards from a slab set I mark them with chalk to keep them together. This makes color matching easy when it comes time to use them. When I am not so lucky I just pull double the material I need and shuffle the boards around, viewing them for different angles, and try to match things up . 6 1 Quote
Mark J Posted February 12, 2025 Report Posted February 12, 2025 Do you sand a raised panel before applying finish, or is your tooled surface smooth enough? If you do sand the panels before assembly, what's your process for maintaining crisp edges on the bevels? Quote
Popular Post gee-dub Posted February 12, 2025 Author Popular Post Report Posted February 12, 2025 On 2/12/2025 at 6:08 AM, Mark J said: Do you sand a raised panel before applying finish, or is your tooled surface smooth enough? If you do sand the panels before assembly, what's your process for maintaining crisp edges on the bevels? Depends on the material and the finish I will use. I hit most surfaces on this piece with a fine abrasive to make things consistent. I find that surfaces freshly hand planed are super smooth and not as receptive to a blended finish absorption as I like. Don't get me wrong; I love my hand tools. When doing surface prep I have to look at the finishing protocol and what I want the material to be like. Film finishes like shellac or lacquer can go onto super smooth surfaces. My oil:varnish blend likes things a little more open. I then "finish the finish" with super-fine wet paper to get my final finished surface. Many of the things I do are habitual and may not be best practices. I certainly couldn't make any money doing things this way. 4 Quote
Popular Post gee-dub Posted February 13, 2025 Author Popular Post Report Posted February 13, 2025 Had the urge for along nap this afternoon but still managed to get a bit done. Many years ago I bought a dozen rolls of this poor quality wax paper at the 99-cent store. Still haven't run out When I am done dispensing silicone rubber glue I just take the nozzle off and toss it in the plastic tub where I keep such things. By the next time I am ready for it "next time" I can just push out the old spoil with a piece of coat hanger. This tai-chi hinge cup jig has proven to be quite useful. It got good reviews back in the day and I will have to add to them. The dust collection is particularly good. Taa-Daa. Feeling pretty good about it. Knocking off for now. LOML and I are having a movie-night . . . ahh, young romance. 7 Quote
Popular Post fcschoenthal Posted February 13, 2025 Popular Post Report Posted February 13, 2025 On 2/12/2025 at 7:37 PM, gee-dub said: This tai-chi hinge cup jig has proven to be quite useful. It got good reviews back in the day and I will have to add to them. The dust collection is particularly good. I got one off of Amazon recently and totally agree. It's a lot better than others (Kreg) that I've seen or used. 3 Quote
Popular Post gee-dub Posted February 19, 2025 Author Popular Post Report Posted February 19, 2025 I'm using Peruvian walnut for the pulls to match the bedroom dressers. I borrow a pull from one of the dressers to use as a pattern. I cut the blank along a crack in order to make decent use of an otherwise undesirable piece of stock. After milling true and square I rip to width. Crosscut to length and select the "show" face. I am trying to take advantage of a couple of defective pieces by knowing that the ugly parts will be removed as the parts are shaped. I set up stops for the threaded inserts. I use an insert to set the depth. I go an additional 32nd of an inch or so to allow the inert to set below the surface. And I get this. I use the existing pull as a pattern. Rough cut at the bandsaw. I use a pivoting jig to sand the final surface. Unfortunately the defect I hoped to sand off went deeper than I suspected so I will have to make another blank. I'm wishing now that I had made a couple of extras while I was doing all the other prep work 4 Quote
pkinneb Posted February 19, 2025 Report Posted February 19, 2025 On 2/19/2025 at 12:48 PM, gee-dub said: I use a pivoting jig to sand the final surface. So if I am following, you screw the handle to the flat piece on the end and move it left to right correct? Great Idea! Quote
wtnhighlander Posted February 19, 2025 Report Posted February 19, 2025 @gee-dub, this is an excellent tutorial on making wooden pulls! What size screw & insert do you prefer? 2 Quote
fcschoenthal Posted February 19, 2025 Report Posted February 19, 2025 On 2/19/2025 at 1:02 PM, pkinneb said: So if I am following, you screw the handle to the flat piece on the end and move it left to right correct? Great Idea! Thanks Paul, I was about to ask, but then figured it out with your explanation. That is a great idea for consistency. Quote
Popular Post gee-dub Posted February 19, 2025 Author Popular Post Report Posted February 19, 2025 @pkinneb - @wtnhighlander - Hi guys. Sorry, didn't mean to be too brief on this. I sometimes tend to blah, blah, blah, too much and err on the wrong side of that . Like many things we do that involve drawers and doors; rinse and repeat. Here's the skinny on the jig. You can see that this was made out of some old plywood that had been laying outside next to one of the outbuildings for a year or so . . . It consists of a spoil board, a trammel, and a mounting plate. You basically need a known pivot point and a mounting plate however you decide to do that. I know that for this pull the radius is 5" so I place a hole (new or existing) at this point from the sanding belt's surface. Mount the blank and set the pivot point with a screw. The whole rig is set about 1/16" back from the abrasive to start. The spoil board is the foundation and is clamped tight at one side and snug at the other. Believe me, you want to start this process with the blank downstream of the abrasive's direction. An edge sander can whip something out of your hands before you have time to say what the . . . ??? Feed the blank into the abrasive 'flow'. The initial pass may not even touch the abrasive. Tap delicately with your micro-adjuster and make a second pass. Rinse and repeat. You will end up here. There are a few more milling operations to arrive at a finish-ready pull but, we are almost there. 4 3 Quote
