Maybe a little different question than @roughsawn, but I sometimes wonder if the wedge shape of the panel, as drawn above, risks splitting the rail or stile if fitted a little too tight. I've tried it like you show, and also tried flattening the section that actually goes into the groove. No failures either way, but my sample size is fairly small.
Ya, same question here...that's what I was getting at. Whenever I profile panels, I leave an "ear" 1/4" wide that slides into the grove in the rails and stiles. About 1/8" long, just shy of touching the bottom of the grove all the way around. Then stabilize with spaceballs.
I see the edge of the wedge touching the edge of the groove, and no room for movement. I know that is not the case...thus my question as to where and how movement is accounted for???
Thanks gee-man. My next panels are going to have wedges. I like the simple design. I made several urn lids with a wedge top design, and they look great.
On 1/19/2025 at 4:56 PM, fcschoenthal said:
 My pieces aren't showroom quality, but figured out a long time ago that my family only cares that I made it (and that it's free), and don't notice the things that are off that I do.
Ain’t that a neat deal!!
On 1/21/2025 at 11:31 AM, gee-dub said:
Once the corner edge is chamfered or rounded the seam all but disappears.
I'm assuming that the amount of material left on the outside joint is equal to the chamfer width you plan on using. Brilliant for not having any joint lines. I'll probably have to practice that a couple of times to remember to use it in a project.
I've also seen someone leave just the outside layer on plywood to cover the plys on the joint. They were cutting on a CNC, so no issue with the thickness. I'd have a hard time keeping the thickness consistent enough to look worthwhile.
