Popular Post gee-dub Posted January 23, 2025 Author Popular Post Report Posted January 23, 2025 Someone was talking about these weird Rockler clamps the other day; here's a use case. The arc is asymmetrical. The "inside" surface of each pier butts against the center console. The outer appearance needs a typical overhang to get the look I am after. Therefor the arc is not centered on the panel. I use the "top" to set the arc on the pullout. Just as with the tops I gang the pullouts to rough cut the curve at the bandsaw. The panels are taped back to back in order to create a mirror image of the asymmetrical curve. They get sanded smooth at the edge sander. I use the same rocking motion as previously mentioned to assure that the free-handed arc is fair. Finished up with a shave. And I remember why I have those really long pipe clamps 5 Quote
Popular Post Chestnut Posted January 23, 2025 Popular Post Report Posted January 23, 2025 On 1/22/2025 at 9:48 AM, gee-dub said: I don't know about being a master of anything I think of it like levels of a trade skill you have Apprentice, Journeyman, and Master. Someone has to hit that level, we can't all be apprentices and journeyman. I'd vote that you have the requisite number of hours and knowledge of the trade to pass a woodworking master examination if such a thing existed. I guess i should have said expert. 7 Quote
Popular Post roughsawn Posted January 24, 2025 Popular Post Report Posted January 24, 2025 That's gettin' to be a big honkin' piece of furniture, gee-man! How you planning on lugging that assortment into the house? Small skid steer? 3 Quote
Popular Post Mark J Posted January 24, 2025 Popular Post Report Posted January 24, 2025 You know, when this bed project is done and hung, you're gonna be ready for a nap. 4 Quote
Popular Post gee-dub Posted January 27, 2025 Author Popular Post Report Posted January 27, 2025 One of those things you do that you might not think to mention and could help someone out. I batch out these router table fence ZCI blanks whenever I run out. My (rather beat up) split fence faces have these profiles on them. The insert sets like so. You position the fence and insert ahead of the bit and back into it until you get the projection you are after. This allows you to get very clean cuts when doing odd things like running a curve against the cutting area. The oak piece is just a scrap but I do the sapele "keeper" next. This removes the bulk of the material in a very predictable way. Then I can shave to a finish ready surface with just a few strokes. I will do the same for the "tops" of the drawer boxes that set between the drawer and door carcasses. 6 Quote
Enzo Caleb Posted January 27, 2025 Report Posted January 27, 2025 It sounds like you're on track for a beautiful project! You’re right that the term "pier group" often refers to furniture with vertical cabinets or columns, especially at the headboard. The sapele should complement the cherry nicely. Floating the mattress and piece is a great design choice—adds a modern, clean look. I totally get the frustration of running out of materials, but it sounds like you’ll have everything you need once you make that extra trip to the lumber yard. Quote
Mark J Posted January 27, 2025 Report Posted January 27, 2025 13 hours ago, gee-dub said: insert sets like so. You position the fence and insert ahead of the bit and back into it until you get the projection you are after. It looks like your ZCI is sitting proud of the fence. Is that deliberate, or is that appearance an illusion. Quote
Popular Post gee-dub Posted January 27, 2025 Author Popular Post Report Posted January 27, 2025 On 1/27/2025 at 6:10 AM, Mark J said: It looks like your ZCI is sitting proud of the fence. Is that deliberate, or is that appearance an illusion. It's flush. The "points" on the original fence faces have been wear-worn so they are rounded off quite a bit. The original faces are 1/32" under 3/4" but a few passes at the drum sander make the insert material match pretty quick prior to cutting. 3 Quote
Popular Post gee-dub Posted January 28, 2025 Author Popular Post Report Posted January 28, 2025 I use a 3/4" bowl bit to cut a finger pull groove under the leading edge of the pullouts. I set up the router table with stops 2" to the left and right of center. This is the result. LOML and I did a bit of soul searching on the hardware for the pullouts. Under-mounts involved too much space requirement as did really heavy duty center-mount slides. Our previous headboard uses center-mounts and we have had them fail at the worst times. In the end we decided to tolerate the appearance of the side mounted hardware since it is only exposed when we are using the pullouts which is when we are in bed. Ever onward . . . 8 Quote
Coop Posted January 29, 2025 Report Posted January 29, 2025 The pullouts are cool! Are they y’all’s idea or some you’ve seen before? Probably handy for coffee in bed. Quote
Popular Post gee-dub Posted January 29, 2025 Author Popular Post Report Posted January 29, 2025 @Coop - They are stolen from another design of mine for the wife's sideboard. The pull outs are to give us a useful surface when the adjustable bed frames are in the "sit-up-to-read-or-watch-TV" position. Otherwise you end up too far forward to set down your remote, glasses, or whatever on the nitestand. 6 Quote
wtnhighlander Posted January 29, 2025 Report Posted January 29, 2025 @gee-dub, are those standard drawer slides? They look skinnier than what I'm familiar with. More like the slides used for rack mounted computer hardware. Quote
Popular Post gee-dub Posted January 29, 2025 Author Popular Post Report Posted January 29, 2025 @wtnhighlander - Correct as usual sir. These are KV, self close, "low profile" slides. I didn't want a lot of reveal between the pullouts and the top drawer. Standard side mounts are around 1-7/8" to 1-15/16". These are a shy 1-1/4". Single center mounts are available but we have had poor experiences with them. As we get older we occasionally need to steady ourselves unexpectedly and the typical center mounts will disengage . . . not good; DAMHIKT. They make a more robust version of the center mount but then, like BLUM-style under mounts, the required clearance messed with my aesthetic. Sometimes you have to pick your battle. 5 Quote
Popular Post gee-dub Posted January 29, 2025 Author Popular Post Report Posted January 29, 2025 I mill out some hard maple drawer box parts . . . parts is parts. I take the whole 60 seconds required to swap the rip blade for a 60T crosscut. I use the 60T for burn-prone woods and the 80T for others. I cross cut the long and short drawer box parts to final length. I will let these rest while I grab a bite to eat. When I get back I will cut the grooves for the bottoms and the notches for the Blum under mount slides. 4 Quote
Coop Posted January 30, 2025 Report Posted January 30, 2025 Do you have the Blum guide/jig for the notches and screw locations or do you just use the slides as guides? Quote
Mark J Posted January 30, 2025 Report Posted January 30, 2025 Yellow. Yet another brand of parallel clamps! Quote
Popular Post gee-dub Posted January 30, 2025 Author Popular Post Report Posted January 30, 2025 On 1/29/2025 at 7:20 PM, Coop said: Do you have the Blum guide/jig for the notches and screw locations or do you just use the slides as guides? I do the notches at the bandsaw. I use the Rockler drill guide for the front locking devices and rear hole. I used to just measure off the hardware but spoiled myself with the jig during a sale. I think it was about $30 on sale. 3 Quote
Popular Post gee-dub Posted January 30, 2025 Author Popular Post Report Posted January 30, 2025 On 1/30/2025 at 5:53 AM, Mark J said: Yellow. Yet another brand of parallel clamps! Those are some Stanleys. Years ago someone on another forum posted about stumbling across them on the cheap at a Pic-n-Save. I jumped in the car and went over to our local one. I got all they had for $10 each. They use a mechanism similar to the Jorgenson. 4 Quote
Popular Post roughsawn Posted January 30, 2025 Popular Post Report Posted January 30, 2025 gee-man, thanks for the picture of the set-up for cutting the pull out finger groove. Now I see why you suggested making my new router table at the same height as the table saw. I would have never thought to use the two together like that. Your project is looking beautiful. 4 1 Quote
fcschoenthal Posted February 4, 2025 Report Posted February 4, 2025 @gee-dub how many board feet of sapele are needed for this? Quote
gee-dub Posted February 5, 2025 Author Report Posted February 5, 2025 On 2/4/2025 at 10:11 AM, fcschoenthal said: @gee-dub how many board feet of sapele are needed for this? Yikes! Let me think about that and try to give you a good number including spoil. Quote
fcschoenthal Posted February 5, 2025 Report Posted February 5, 2025 On 2/4/2025 at 6:39 PM, gee-dub said: Yikes! Let me think about that and try to give you a good number including spoil. You don't have to go to too much trouble. I just kept coming up with $h!t-ton. Quote
Popular Post gee-dub Posted February 5, 2025 Author Popular Post Report Posted February 5, 2025 @fcschoenthal - That is pretty darn accurate. First a disclaimer; I choose parts out of a board which results in more waste than may be "normal". That is I take things like frame parts out of a blank based on figure pattern leaving odd shaped wedges of waste on either side. This example is from a different piece: The lumber run shown in this thread was for 76 board feet. I used all but one board of that and had already made some frame and panel parts from what I had on hand. If I had to make guess I would go with having 85 bf on hand if you want to make one 5 Quote
Coop Posted February 5, 2025 Report Posted February 5, 2025 I like the way you did the board above. Quote
Popular Post gee-dub Posted February 5, 2025 Author Popular Post Report Posted February 5, 2025 @Coop - Thanks. Those ended up being the corner posts for this piece. 4 Quote
