Just an observation, your marking triangles on the show side get partially cut away with the bevel cut.  Do you also mark the back sides?
Also, any reasons that one would choose the TS over the router table for this operation (or vice-versa)?
On 12/10/2024 at 11:59 PM, wtnhighlander said:
Looking goid, @gee-dub!
+1
FYI, you weren't the only one noticing difficulties with site access. Hope it is all straight now.
FYI, It is from time-to-time very slow for me, but I've not seen an outright failure. No issues in the last couple of days.
13 hours ago, gee-dub said:
I've been unable to post to the forum for a couple of days due to technical difficulties.  Not sure if others experienced this; maybe its just me(?).
I had similar problems for a day or two, but only on my Android.  PC was OK.
One of stuff is common. Why someone throws one of jigs on a wall and collects them is beyond me. Some of my jigs are common and can be used in various  builds.. Those should be kept. I use to make raised panels on the  saw, but I stopped when I moved up to router bits..
When I hear someone made something hand made, I know everything is hand made..
@gee-dub, how do you deal with the difference in book-matches that results from the grain entering / leaving the show surface at opposing angles? My experience has revealed rather startling color and/or chatoyance variation when the two faces of the match are joined side by side. My last big project has one panel with a 'black eye' and a 'white eye' because the book-matched halves reflect light in opposite directions around a knot-swirl figure.
Glen, your work is so far above my pay grade, I think I'll just keep lurking. Looking awesome!
Quick question...when you cut your 14 degree bevels on your panels, how do you determine how and where they will reference in the dados in the rails and stiles? It looks like the bevel, at some point, just makes contact with the inside edge of the rails and stiles, and just butts up and stops there???
I know you have room inside for movement, and maybe even have spaceballs inside. But, how do you figure where the panels meet the frame, and how much room for movement?
