On 8/11/2024 at 1:35 PM, pkinneb said:
@gee-dub so curious Are you building this around a select comfort mattress/ frame? If yes will it be attached?
It is a split-king with individually adjustable frames; soft and cushy on LOML's side and firm on mine.  There is hardware supplied with the frames to attach a typical headboard.  There will be a stretcher on my headboard that these can attach to.  They need to be attached so that the fabric of the mattress and base do not rub when being adjusted.
  • Thanks 1
On 8/11/2024 at 8:23 AM, Mark J said:
I noticed you put all your parallel clamps on the bottom side of the glue up, rather than alternate them top and bottom.
They would have crucified me for clamping like that in the  shop..
Ok you already had my attn but now I gotta see how you do this. I have always wanted to do a headboard with ours (same set up only i'm soft and wife is firm :)) but wasn't sure how.
I'll remember to take some pics.  The brackets came with the frames.  Sort of adjustable "L" brackets with multiple holes for setting distance.  I'm sure you could fabricate something similar from wood.  They are not seen without 'looking under the hood' as far as I can tell at this point.
  • Thanks 1
@gee-dub, after seeing your sacrificial ZCI on your sled, I think that’s a neat idea and suspect that you have done the same on your miter gauge on your ts. Mind posting a pic of it?
On 8/17/2024 at 3:03 PM, Von said:
Thanks for the tip. I wasn't familiar with a bodywork file. I have a wishlist on Amazon now which I should just rename "useful stuff I heard about from gee-dub" :-)
The man is a walking "Great Idea Factory"!
It seems the lumber came dressed? I prefer rough so I can remove any twists and doglegs out of the material. However the wood appears to be flat as a pancake. I raise my confidence when I start by jointing one face.
Yes. Even when material comes S2S or better I still run it through the milling steps to assure parts are square and true.  For material too wide for my 8” jointer I use the planer sled.
Sapele  is a pretty straight lumber and doesn’t need all that processing. We bought so much of it, we had hardly any waste..
Sapele has a good weight to it. Solid lumber to work with
  • Who's Online   3 Members, 0 Anonymous, 44 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
