On 8/19/2024 at 8:18 AM, gee-dub said:
Yes. Even when material comes S2S or better I still run it through the milling steps to assure parts are square and true.  For material too wide for my 8” jointer I use the planer sled.
My jointer is also 8". Sometimes I will rip and glue it back. If necessary a friend in the neighborhood has a 12". It is old but completely rebuilt. An amazing tool. I call it the benevolent beast. To adjust the bed there is a mini ships wheel. Mine to use whenever I need to. They are snow birds meaning they leave during the hot summer. I have the key and permission to use the shop.
gee-dub, from knowing you and your approach I expected you would true the lumber. Many people would use the wood as you bought it. Been there and won't go back.
“Many people would use the wood as you bought it.”
Many  do when the lumber is  correct to start with. There is no reason to over process wood, but in your shop your free to do as you wish.
Why I buy wood S3S. This way I don’t waste time processing and spend more time building.
Now is processing brings you enjoyment, by all means do it..
My training probably conflicts with many other opinions, but hard to change
When I started at Commercial  Millwork & specialty company(still in business) in 1983, all lumber  came in rough. We had a  warehouse full of shipped in lumber and forklifted. So I’m very familiar with trueing lumber. Skipping forward to 2010 all lumber at the  furniture company was brought in fully processed. No time to  processing wood.
I think if the pre-milled lumber was kiln dried, chances are good that it will remain true and flat. We hobby woodworkers sometimes err on the side of caution, and mill to machinist's tolerance, but that isn't always necessary. A large percentage of my stock is air dried, and even if I get some detectable movement after milling, it is very rarely enough to interfere with assembly.
It is worth the time to build a true foundation. If it is true, raising the building will be so much easier and a lot more fun. Dressing lumber is the foundation of the furniture.
Dressing lumber is the foundation , I would question. There is no need to over process wood because  you can.
You can’t take a flat board and make it flatter? Or Am I missing something?
Not in my opinion.  If blanks, once reduced to "oversize" have an edge or a face that are true, I will use that. ;)
Me too. I have been down the dead end road. I will not go there again!
  • 3 weeks later...
15 hours ago, gee-dub said:
picked these up at a show back in 2005. They set in a drawer in the drum sander base and only come out now and again. They are one of those inexpensive, silly things that really help out when you need to sand an odd profile.
I like these.  If you have a wider cove, wrapping sandpaper around a small clump of yarn also works.
  • Thanks 1
@Mark J, yes, a machinist's tool. I bought an inexpensive set of ten, similar to these, and find all sorts of uses for them.
Taylor Tool Works sells a handy hardware kit for bolting these blocks together to make more elaborate fixtures.
Note that these inexpensive blocks may not meet the tolerance needed for some machine work, but are more than adequate for woodwork. Also note that the holes in the blocks, threaded or not, aren't sized to allow bolting them directly together, but instead for attaching them to machine tables. That's why the Taylor hardware kit is so useful.
3 hours ago, Mark J said:
I keep my eye out for 1-2-3 blocks, but I never see them at the hardware or woodworking stores.  Are they more of a machinist tool?
Lee Valley sells them
  • Who's Online   2 Members, 0 Anonymous, 59 Guests (See full list)
    26,008
    Bob44
    Bob44
