On 12/21/2025 at 11:38 AM, legenddc said:
Office Built-in Cabinets Part VI
One of the requirements for this cabinet was the bottom drawer needed to fit a basketball. I'm proud to say I managed to achieve that and don't need to redo any drawer sizes.
Blum undercount drawer slides on
I somehow managed to make all of the dovetails in the drawers without messing any up. I did take the time to label everything and draw rough lines for the grooves to help me ensure nothing got flipped.
IMG_8303.thumb.jpeg.48af9366ea7a898b861478267beaf314.jpegIMG_8304.thumb.jpeg.75c47505b9a659602352010fa062db3f.jpeg
I'm waiting on someone now to come buy the old planer and then I'm heading down to the shop to work on the grooves and plywood bottoms. Then I will sand all of the insides before I glue them up.
Any recommendations for finish on the drawer boxes? The bottom is pre-finished plywood. I don't want to use Arm-R-Seal as it smells forever in an enclosed space. I don't think Rubio will match the bottom. I was thinking of using clear shellac. What grit do I need to sand to for shellac?
Shellac is good, and also, a water based poly will cure quickly and with much less smell.
When i use shellac, which is most of the time, i only sand the final coat - assuming reasonable care was taken on previous coats to get them uniform, etc. I start with heavily thinned shellac (1 part shellac, 3 parts alcohol) and make the mix thicker in subsequent coats.
I usually sand it in the 300-400 grit range, with the paper on a sanding block. And a bit of finishing wax over the final coat makes it very smooth.
Looks like you're doing a great job!!
It appears when my phone ran out of space I deleted a lot of the cabinet pictures so some imagination is required. I finished sanding all of the lower doors. I filled in any larger holes or gaps with Durham's Rock Hard, sanded it smooth, and then sent it off to the paint shop.
Of course the paint shop is just our dining room. My wife volunteered to paint as her job was slowing up. She did a coat of primer and then I brought them back to my shop to sand and fill in any small holes with 3M glazing putty. Then back up to be primed and painted. Since my wife had time to paint, I hoped right onto the upper cabinet doors and she painted them as well.
Now my basement is filled up with cabinets, face frames, and 14 painted drawer/door fronts. I have been working on milling the lumber for the drawer boxes. It takes a lot of time to go from 4/4 rough wood down to 5/8" boards. Add in more time to glue up boards for the wider drawers. Last Thursday I went down to try and get the bottom drawers to final thickness but my planer was acting up. It's been randomly slowing down on wider boards, resulting in them having to be pushed/pulled through. Not a very safe or fun activity.
I could try cleaning the rollers again but that didn't last very long the last time I did it. The fix is new roller but they cost over $100. Option 3 is what I chose.
Mostly I went this route as it would be here this past Sunday in time for me to have a week off of work.
And then the shipment was delayed until Tuesday. I borrowed my dad's planer to keep moving Sunday/Monday. Monday morning I realized his planer blades aren't aligned properly and were planning the boards on an angle. Fortunately, I realized this before anything was too thin.
It was then I walked out of the shop and noticed the floor was wet. Long story short, the water heater pressure relief valve went off. Apparently they can go bad as they get older. After 27 years ours has had enough. In case you're bad at math, it was manufactured around the time the Chicago Bulls won their final championship.
Back to our scheduled programing, with the new planer in hand, I was able to get some drawers made. I used the Rockler dovetail jig for these because my dad has one and it's free to borrow.
I'm happy the dovetails are done on all of the drawers. The jig works well, but it's a lot of trial and error to set up. I bought some poplar and milled it up so I wasn't messing up the actual pieces. Initial tweaking of the setup was almost 2 hours. Once that was done changing the jig to the different box sizes was very quick.
After the first box was made I cut the plywood bottom, made grooves in the box and installed it. Had to make sure the measurements were correct before I finished the other 6.
IMG_8287.thumb.jpeg.7e5c90723792c83631e90c3812ee2507.jpegIMG_8290.thumb.jpeg.ec3eb5f6124ecc2442a2d222d4918182.jpeg
Nice job on your dovetails. I know that jig well and absolutely agree it can be a pain to get dialed in. Yours look flawless. Well done.
Maybe I should have rephrased my question. What grit do you sand the wood to before applying the shellac?
@legenddc, looking really fine. Question about the electrical receptacle/docking station. The pic you provided looks like the wire runs alongside a jointed/pivoting arm, for lack of a better description. Your wall outlet is behind your middle drawer and the top drawer contains your device. When you get the connections made, can you take a pic of behind the top drawer, before you attach the top of the cabinet, please?
  • 1 month later...
On 6/8/2025 at 7:23 PM, fcschoenthal said:
I at least have a covered glass when sanding or finishing. Nothing like getting an extra head layer to remind you.
Yeah, I have a few peanut butter or other large plastic lids laying around to use to cover my coffee.  I have one with a skull and crossbones felt marked on it that I use to cover finish jars between coats.  Don't want to use that one to cover anything you are going to drink :D
  • 3 weeks later...
  • 1 month later...
  • Who's Online   3 Members, 0 Anonymous, 59 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
