Cmac2008 Posted November 7, 2014 Report Posted November 7, 2014 I need to invest in a new dado blade... I've looked at the frued 8" a lot.... I mainly do work with 3/4 red oak... What teeth count would be best for me? 12 runs about 100$. 24 about 200$... What about the dial-a-width? Anybody got one and love it??? Quote
chefmagnus@grics.net Posted November 7, 2014 Report Posted November 7, 2014 I had a wobble dado and gave it away. I had a terrible time with tear out. I now put blue tape on my dados and cut them with the Freud Super Dado. Here is the link to Amazon. I got a Warehouse Deal for a open package for $155. Freud SD508 Super Dado 8-Inch Stack Dado https://www.amazon.com/dp/B00004RK0P/ref=cm_sw_r_awd_gwoxub1G4VG5W Quote
Tom Cancelleri Posted November 7, 2014 Report Posted November 7, 2014 I would definitely say avoid a wobble dado. I haven't had a chance to try out the Freud stacked dado, I do love Freud blades so I'm sure it gets the job done. I have a Systimatic 22 Fine stacked dado 8". It's a beast of a blade, and the chippers are ridiculously over engineered I think. Quote
dwacker Posted November 7, 2014 Report Posted November 7, 2014 24 is probably the most useful. I wouldn't use a wobbler if you paid me. 1 Quote
RichardA Posted November 7, 2014 Report Posted November 7, 2014 Check out Infinity tools .com they have one called the Dadonator, that is supposed to out perform almost any other brand. I can't verify that, as I have a Freud. if and when I do need another, I'm going to give that one a try! And anything that wobbles on a spindle that goes around smooth, just scares the hell outa me! Quote
Jfitz Posted November 7, 2014 Report Posted November 7, 2014 I have the Freud 8" dial a width dado. It's OK - cuts pretty well, but you still need to finesse the number of "clicks" to get to the right size. I think the most annoying thing is the 'batwings' it makes on the sides, but I've started using a router plane to make the dado an accurate depth so those tend to disappear. Quote
dwacker Posted November 7, 2014 Report Posted November 7, 2014 The way I look at it is there is a reason they are not legal to use in a work place and I don't want to find out why. 1 Quote
rodger. Posted November 7, 2014 Report Posted November 7, 2014 I have the 8" dado stack from freud. Works great - frequently cut 1/2,3/4,and 7/8 dados in hardwood on a 1.5 hp saw. Quote
Tpt life Posted November 7, 2014 Report Posted November 7, 2014 Woodsap, this may be for guys who need to ship. With dozens of shops within five square miles due to the RV industry, I can drop blades off with no hassle re sharpening. The more times it can be resharpened the better. This usually means in that quality range, the deeper carbide wins. Quote
knotscott Posted November 8, 2014 Report Posted November 8, 2014 In the $200 range, I'd undoubtedly go with the Infinity Dadonator....very impressive performer. In the $100 range, I'd look to the Delta/DeWalt 7670 set...it's a 24T set that's cleaner cutting than any set I've seen < $125. Quote
Trip Posted November 8, 2014 Report Posted November 8, 2014 I’m going to go a bit contrarian.... I’ve got the Freud Super Dado: http://www.amazon.com/Freud-SD508-Super-8-Inch-Stack/dp/B00004RK0P/ref=sr_1_7?ie=UTF8&qid=1415421676&sr=8-7&keywords=Dado+stack which is the backup stack when my Forrest Dado king is out being resharpened: http://www.amazon.com/Forrest-DK08244-8-inch-32-inch-Width/dp/B0000223VZ/ref=sr_1_1?ie=UTF8&qid=1415421861&sr=8-1&keywords=forrest+dado Why do I go contrarian? Folks are perfectly correct that the best stacks are not really needed to dado sheet goods for shelving… But, there are many joinery techniques that use a stack – it’s here where a quality stack comes in handy. The alternative is to get a mid-level dado stack and quality finger-joint set for joinery: http://www.amazon.com/Forrest-H9192-Finger-Joint-Blade/dp/B000LONIEK/ref=sr_1_1?ie=UTF8&qid=1415422162&sr=8-1&keywords=forrest+finger Quote
MichaelNV Posted November 8, 2014 Report Posted November 8, 2014 I don't hesitate to recommend the Oshlun dado set they have them available in both 6 inch and 8 inch and you can't beat the price and quality. Available from Rockler and also good pricing on Amazon (http://www.amazon.com/gp/product/B0012YF25Q) Quote
Shane Jimerfield Posted November 9, 2014 Report Posted November 9, 2014 Side note: when using the shims to dial in a perfect dado width be sure that the shim does not slide down into the thread on the arbor. Rotate the arbor so that the thread is positioned to hold the shim up. That was a sucky lesson to learn, but learn it I did. Quote
Mzdadoc Posted November 9, 2014 Report Posted November 9, 2014 +1 on the Freud SD508 Super Dado. I used mine for the first time before I got sick. ( no worries household flu) Perfectly smooth bottom and bat ears I could barely see. Quote
Beechwood Chip Posted November 9, 2014 Report Posted November 9, 2014 Side note: when using the shims to dial in a perfect dado width be sure that the shim does not slide down into the thread on the arbor. Rotate the arbor so that the thread is positioned to hold the shim up. That was a sucky lesson to learn, but learn it I did. You can buy magnetic shims so that they stay where they should and don't slide down into the arbor threads. I like to use a drop of 3-in-1 oil between the shim and the blade - the surface tension holds the shim in place. Quote
Tim Kohl Posted November 9, 2014 Report Posted November 9, 2014 slightly off topic: on some mid priced sets the cutters have 2 arms other have 4 is there much difference? Quote
knotscott Posted November 9, 2014 Report Posted November 9, 2014 slightly off topic: on some mid priced sets the cutters have 2 arms other have 4 is there much difference? "Arms" = teeth. When all else is equal in a blade design, more teeth equates to a cleaner cut. However, it's not an absolute parameter that always means "better"....it's just easier to spot than many of the other factors that effect cut. Precision, sharpness, hook angles, bevel angles, tooth grind, side clearances, etc, all have an impact, as does feed rate, the material being cut, and user technique. A premium precision set from the same manufacturer with 4 tooth chippers should have a cleaner cut than the same manufacturers set that has 2 tooth chippers...ie Freud's 508 vs 208 set (same design, same precision, different tooth counts), but that logic doesn't translate directly to another set that has a different design. It is however less expensive to make a set with fewer teeth, so read into what you may. Most of the better premium sets have 24T outside cutters and 4T or 6T inside chippers (Forrest Dado King, Infinity Dadonator, Freud 508, Ridge Carbide Dado Master). Quote
bushwacked Posted November 10, 2014 Report Posted November 10, 2014 Lots of good info here. In the market for a dado set as well. Question though.... All this talk of sending them out to be sharpened and stuff. How often do they need to be sharpened (yes when they start getting dull I know that but what kind of mileage can you expect?) and where should I look for a sharpener guy at? What's a good price to pay for sharpening? Quote
knotscott Posted November 10, 2014 Report Posted November 10, 2014 Lots of good info here. In the market for a dado set as well. Question though.... All this talk of sending them out to be sharpened and stuff. How often do they need to be sharpened (yes when they start getting dull I know that but what kind of mileage can you expect?) and where should I look for a sharpener guy at? What's a good price to pay for sharpening? I really depends on usage and care. Keeping the dado set clean can extend the edge life quite a bit. Mine doesn't see a ton of action, and have yet to sharpen it...it's probably 5 or 6 years old. Quote
Trip Posted November 10, 2014 Report Posted November 10, 2014 ==>How often do they need to be sharpened Obviously how many linear feet of use, depth of dados, wood species, etc... As mentioned, cleaning helps. Type of carbide also influences edge retention --- One reason people gravitate to Forrest is the use of C4 chips in their blades vs C3 and C2 for most everyone else. Resharpening is the other reason – Forrest’s C4 cutters are thicker and can withstand more resharpenings. It's not uncommon to get eight resharpenings on a Forrest (sometimes ten), while my Freud will be lucky to get five or six. ==>What's a good price to pay for sharpening? Depends on what you mean by ‘sharpening’. Some services fire-up a single-grit (#4000) blade station and have at it – quick, cheap, poor quality and the vast majority… At the other end of the spectrum, some services verify plate flatness, repair any cracked braze joints, repair/replace any cracked cutters, hand-tune the blade, perform a multi-grit polishing (#2000, #6000 & #8000) and perform a test cut… My last bill from Forrest was $46 for a stack. One the other hand, I've received a $44 bill for a single WWII -- needed four new cutters and the plate had to be retuned and balanced (case hardened Red Oak was involved). One thing about a Forrest blade sharpened at Forrest's service -- that blade needed some serious work -- when it came back, you could not detect where the repairs were made -- the entire blade was cleaned and polished. Before I switched to Forrest, I had blades come back with brazing that looked like it was done at Joe's Auto Repair... Quote
bglenden Posted December 3, 2014 Report Posted December 3, 2014 One thing to keep in mind for Sawstop owners is that they recommend against using dado stacks like the Dadonator - the ones with the "filled in" (look almost like blades) chippers. Cheers, Brian Quote
dwacker Posted December 3, 2014 Report Posted December 3, 2014 One thing to keep in mind for Sawstop owners is that they recommend against using dado stacks like the Dadonator - the ones with the "filled in" (look almost like blades) chippers. Cheers, Brian Can you use groover bodies on a Saw Stop? Quote
Vyrolan Posted December 3, 2014 Report Posted December 3, 2014 One thing to keep in mind for Sawstop owners is that they recommend against using dado stacks like the Dadonator - the ones with the "filled in" (look almost like blades) chippers. Don't tell Amazon... Quote
DarrylR Posted December 3, 2014 Report Posted December 3, 2014 I have the Freud Dial a width SD608 stack and am very happy with it. It makes very smooth bottomed dados and is very easy to adjust small amounts with no shims needed at all. My dado fits are much better than they were before. Yes it's expensive but I don't plan to buy another one for a long time. Quote
