Help me tune my drill press
here is a video showing two methods the second method is what you need
Tried that - didn't budge.
My understanding is that the spindle is tapered on the "business end" with a Jacobs taper. I'm going to attempt a bearing puller to get it off. I don't want to pound on it anymore than I have (worried about damaging the spindle).
I know it does not show one in the exploded view but is there a screw up in the chuck holding it on?
No, I shone a flash light up there to look for fasteners.
I got th e chuck removed with a 4" bearing puller. Came off very smooth and easy with the puller.
Now, I may have a new problem. The spindle looks dinged up - all of these marks were between the chuck and spindle - not sure if I should just press a new chuck on top, or deal with the damage.
Like I said previously, this is a second hand machine, so I don't know what the previous owner did to make these gouges.
post-6372-0-50865300-1438040080_thumb.jppost-6372-0-28496500-1438040101_thumb.jp
If i take strip of 80 grit, turn on the drill press, and clean up the damage a little, will it do more harm than good do you think?
I put the dial indicator on the spindle and Gave er a whirl. Less that 0.5/1000 vaiance, so the issue must be with the chuck.
Looks like this.
Holly crap! I remember seeing one of those when I bought mine but had no idea what it was for.
Thanks Micks
The chuck is the least expensive part to replace!
If I could find a new spindle, I would prob go to the effort of replacing it as well, but they have been discontinued or declared obsolete by every parts place I look at.
If I was going to clean up that spindle I would use a flat mill file the widest that I own turn the drill press on and, just knock the high spots off the flat file will register off the flat face of the spindle. I'd be afraid the sand paper would dig holes or change the shape of the spindle.
If sandpaper is used it should be on a solid flat backing surface.  Or a file might work or something like a hard oil stone would also knock off the high spots.
Ideally would probably be put it in a lathe and cut a new taper lightly into the surface.  Someone definitely spun the chuck on that taper.
Well, I gotter done. New chuck is on and I improved the runout to about 6/1000. I did do some minor filing and sanding to get it done.
Happy with the results, seeing as the new chuck is a 14 dollar unit from busy bee (grizzly).
I'll clean up and do some real world drilling to see how it performs in the "real world".post-6372-0-06324100-1438109300_thumb.jppost-6372-0-82342400-1438109336_thumb.jp
  • 26,009 Total Members
  • Joseph b Newest Member ·
