Danish oil + ash =
A) disgusting
2) like a yellow submarine
D) all of the above. . Plus P
P) why would you do that?
D is clearly the most correct answer. In getting closer to the bench being a bench instead of a bunch of parts, I tried some Watco danish oil and a few others on some sanded scrap.  Holy grosse batman.  White Ash turns a nasty yellow.  Any experience with finishes that don't turn the bench into a banana?
Watco on my hard maple bench didn't turn it that yellow but the pores in Ash might be another story. Thing with a bench is you want an in wood finish and not something that builds making it slick so your options are limited. Minwax wipe-on poly is pretty light in color and already thin so a couple of coats with that won't build much. You could even thin it more. Whatever you do, don't use BLO, which is why I think Eric refers to his bench as having a banana finish.
Personally iv had alot of success using a bunch of really really thin shellac washes that will soak in deeper than normal, where you get a bit of moisture resistance and what not but it doesnt build... without probably 20 coats.
But at the same time i would probably still use danish oil and just tint it slightly.
Speaking of ash and work benches, i have these 8" x 10" x 10' ash timbers i want to make one hell of a bench out of. Just need to work up the gumption to process it by hand considering i cant mill them with my current machines.... or even the machines in the shop i work in.
I tried some tung oil on maple as a candidate for my bench when I finally get it finished. It gives it a warmer look, but certainly not yellow. I think that's what I'll go with.
Maple will darken some no matter what you finish it with.
If you want to get rid of the yellow what about a brown tint to the finish your applying? That picture frame i made i tinted the first coat of shellac and i don't think that it looks yellow at all. Just a thought. I have some ash and some random finishes I might try a few things just out of curiosity.
I'm going to give a Danish oil,  then dyed seal a cell coat a go.
2 hours ago, Brendon_t said:
A) disgusting
Sounds like an excellent way to hide beer spills.
15 minutes ago, Brendon_t said:
I was hoping to hide Burbon. .
Wrong approach; bourbon's too expensive to spill, at least the good stuff is. I should talk, dropped a whole half bottle of tequila taking it out of the freezer last week.
Timeout! Now you're coming up with a finishing "schedule". You realize as soon as you're done with this you're going to beat the crap out of it the rest of your life? I vote Danish oil and done.
We do get a vote, right?
Yes I get that, and yes I'm going to be beating the top up, and yes I'm sure I'm overthinking it but yellow is ugly, and yes everyone else gets a vote, except you because I didn't like your vote, and yes, this is a whole run-on sentence.
Danish oil finish is usually just BLO + a little varnish. If the BLO was too yellow for you, danish oil won't look any different.  I have read that Tung Oil yellows far less, so that might be worth testing on a board, no personal experience with it though. I read that it emits fumes and stinks up the shop for weeks and weeks, so I have avoided it.
You should just put 1/4" thick layer of that clear bar top finish on it.  That would look sweet!
Gold-Holographic-600x360.pngYou going more bass boat style or lowrider?
Make the yellow a feature?
Thinking more red white and blue.  Make it a clear product of 'Merica
What happened to the tinted oil idea.  Transtint in oil works well. Pretty sure it would respond well to ammonia fuming as well.
Nothing happened to it.  It's on the list of things to do for the next tester board.
There are several brands of Danish oil, and from what I've read, they are not all the same.  Watco brand is available in nine different colors.  Which one did you use?  I'm interested, because I will soon be doing similar tests, and I'll probably include the dark walnut or black walnut Watco Danish oil in my tests.
I want to see a test board of this...
