Tool Chest - Finished
1 hour ago, treeslayer said:
nice progress D, looks great. hardware installation is my least favorite part of woodworking even though in means the end is near, i think of it as one last chance to screw things up:blink:
Thanks Dave!
Yeah, been there done that, that's why I make those templates, which may seem like a waste of time but they take all the stress out of the maneuver lol.
  • Replies 140
  • Views 26.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Immortan D
    Immortan D
    My tool chest is done. Thank you all who have supported this build, I really appreciate it. Pics:
  • Got some strong enough brass door handles and proceeded with the installation. Out of MDF I made a template, drilling the holes on my drill press, and tested the fit. Then clamped the
  • I needed a molding and decided to make it myself. I started with a oversized board to make clamping easier. I just used carpet tape to attach it to my workbench. Then I used a rabbeting pla
Posted Images
41 minutes ago, Chet K said:
More importantly did you hear any sounds coming from you? ^_^
Its coming along Daniel.
Nope, but I had to change my underwear just the same lol
Fixing issues now. Toothpicks to the rescue. Have to drill those hinge holes again.
And there's another issue in this very same frame. As one can tell from the pic, when I mortised for the hinges I did it on the wrong side of the frame, so I had no choice but to extend those mortises to the other side. Not sure how to fix this.
do you have to fix it? will it be noticeable to anyone but you? a small piece glued in i think would not be noticed to anyone.
I don't,  but it's been bothering me lol. Will try shaving a small piece of wood, see if it makes it less noticeable.
Glue in a piece that is slightly to thick and wide, but exact length. Then screw the hinge in place with the back edge slightly lubed. Then glue the patch in place and you can shave it flush when dry.
If cosmetics really matter put a patch in and then then put some edge veneer on to cover it up. Got that one from Terry Mc.
Precision hand drill
Just turned the Dewalt angle adapter with a palm ratchet to drill the replacement holes. Worked like a charm. I guess that's neo-cromagnon woodworking?
neat idea!
Fitting of the LN beading tool.
I want the top bin to be a project area instead of a permanent setting for tools. So no tool fitting will take place there, except for a small slider tray for pencils and marking knives. So I started looking for spots for the small planes and eventually I ended up moving all of them out of the bin.
The spot for the beading tool was half way into the "tunnel" so I had two choices: taking the whole chest apart and then reassemble, or just deal with the spot and so I did.
I nailed a small jig together to mark the position of the holes, referencing the floor and the edge of the tunnel.
Using the jig I marked the holes and drilled with the "precision drill" lol
Now that tool is quickly becoming a lifesaver in this project.
I installed brass hooks and turned out well, easy to store and retrieve the beading tool without interference from other tools.
1 minute ago, wdwerker said:
Beading not bedding, I had to go look at Lie Nielsons site to figure it out. My brain just couldn't make the leap today.
Fixed, Thanks!
I made the front door removable using brass hardware. It slides up for removal.
Top of the door.
At the bottom of the chest I mortised holes to receive the hooks on the door. The brass plate in front of the mortise should prevent splitting.
I may install glass in that door, not sure what to do.
I glue glass into doors using Lexcel clear caulk. It dries extremely clear, slightly flexible and keeps the glass from rattling. I lay the glass in a rabbet and wipe the caulk with a finger dipped in mineral spirits . It might take a couple days to dry but I've been doing it this way for over 25 years and it's held up to the test of time.
That elastomeric product seems like a better solution than the silicone I've been using. Thanks Steve!
Glad to share successful methods.
I never put caulk under the glass. Wiping the bead to smooth it pushes it around the edges. You can cut this if the glass ever gets broken. Caulk under the glass makes it a nightmare to remove the broken pieces.
Daniel, why do the mortises for the hinges go all the way thru? Just jacking witch ya;)! This thing is looking fantastic man!
Thanks Ken!
1 minute ago, shaneymack said:
This thing is great, Daniel!
Thanks Shane!
1/4" plate glass is pretty tough stuff but i would probably use tempered glass, more expensive of course but whats a little money on a project as nice as this one!!
Thanks Dave! That sounds good.
Where are you getting this brass hardware, as in the hooks and the items in the last two pics?
At that size I would just use 1/8" double strength glass. Tempered has to be ordered to an exact size and can take days to weeks to get.  Once the glass is glued into the frame it will take a really strong blow to even crack it.
