Arched bookcases and Fireplace surround w mantle.
Looks like PNT but.  I don't see no HF clamps there. :)
  • Replies 137
  • Views 34.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • It's DONE !!!! 9 pm on Friday night and I am exhausted ! I think I'm going to sleep late tomorrow.
  • After several distractions I got back on the arches.  Had to make templates for the top and bottom curves. Getting the blanks glued up was a bit tricky but the came out with tight joints and dead flat
  • Main shop is 20 x 50 w 16 ft ceilings I think. Office, bathroom ,kitchen & storage 12 x 50. Loft is 12 x 30 , stairs up to loft sure  beats the ladder I had in my old shop. Main outfeed /assembly
Posted Images
The general public has no idea of the work involved and the time it takes to properly make the joints. If you tell them the hours required just to complete the arch, they can't see it. I see it and I appreciate the effort and time it takes to do it right...
I saw it live, and I appreciate what Steve and Rick do. It's very complicated and they master it.
??? PNT ??? I used a hodgepodge of clamps because length & handles kept running into each other. I've got a few things from HF but clamps ain't one of em. Northern Tool has a small selection of Bessey  "F" clamps & the auto adjust toggle clamps for just under $19 each. Best price I've seen them at. Every shop should have a pair of those Bessey toggle clamps, awesome on all sorts of jigs !
Rick is an old friend and former neighbor that helps out from time to time.
The time envolved caught me off guarg on this one. Should have bought a finger joint bit in hindsight. Luckily the big arch gets backed up by the plywood the big TV mounts too so those 4 joints won't get flexed after its mounted. The small arches only have 2 joints.
Steve, if the project takes more time than originally thought, does that cost you or is it time and materials? I know my limitations but when I go to new never done before I always go over...The hardest thing for me is calculating time required...
Finally got back on the big arch. Pattern routed the blank to final shape then sanded both edges smooth. Routed the molding on both sides and had to do plenty of freehand climb cutting with tightly clinched cheeks. A 7' wide curved part is not an easy thing to route, the grain direction keeps changing. A few sections had some tearout from the pattern routing but I was able to get them out when I cut the molding. Then I clamped the sanded part to a jig to trim the ends and rip the top of the curve off.
A few dominos let us dry fit the arch.  We clamped it to the side of the table so it was held firmly to receive a vigorous sanding to remove a ridge left after routing.  The inside of the triangles made by the arch gets moldings. I spent the day today cutting & fitting 10 degree miters and sanding the cuts until they fit, that's 5 degrees each side. A 3/8" thick molding with a 5 degree mitered end means the cut is about 2" long. The side cuts of 67 1/2 and 22 1/2 were a breeze in comparison. Dripping sweat I got frustrated fitting the last long miter so pictures will have to wait till tomorrow.
I learn a lot from you Steve. Thank you! I wonder with your good vision and experience did you anticipate all of these necessary and exotic efforts to complete this task? And then to calculate how long it will take. It is one very special thing to complete the task you are on. But on top of that to determine the steps involved and predicting how much time you will take in my eyes may be harder than the actual project, as tough a challenge that it is. Do you ever ask the client for time and material for these kind of projects?
I am enjoying this project. Thanks.
I had a totally different approach in mind when I quoted the job. Then I figured out it wouldn't work. The little details are eating up the budget but it's about time to knock out the big casework and go after the finishing. Thanks for the kind words ! I will take pictures of the long sharp pointed miter process today.    I had to figure it out 20+ years ago to wrap exposed roof trusses in a skylight shaft. 1/4 Mahogany ply and a cap molding I set up and made seemed like a good idea until cutting this joint was a reality.
So I cut the skylight trim on the mitersaw using a 90 degree jig.
I set this picture up just to demonstrate .
I copy the angle with a Tee Bevel, protractor , whatever then bisect it.  For the small trim I rough cut on the bandsaw and sand to the line. Inevitably it takes a little fine tuning by eyeball.  Usually trial and error on a scrap then copy the best result onto a longer piece.
I use a scrap to back up thin trim & keep it square to the table.
Both sides of the joint had to be cut, free hand grinding a long angle on that piece of curved trim was another butt clenching move. Both sides of the arch top as well as upper & lower corners on each side of the arch.
This shot shows the angle on the curved trim.
The fits not perfect but after several coats of primer & paint and being 9 ft in the air it will appear perfect.
The joints on the bottom edge will be much more visible. A thin bead of glue and a few micropins will hold all this trim in place.
Just the thought process scares the begibers (sp?) out of me. Mods, see how I toned that down;)
As I started this build I felt a bit overwhelmed. Slowed down, broke it into steps and focused on one step at a time. Feeling much better know. I hope the rest of this build starts moving quicker.  The arched tops inside the bookcases will be fun & fairly straight forward.
Steve's experience allows him to say this.  Every time I think something is going to be straight forward it ends up a two day adventure. :blink:
Got started on the curved inside tops for the bookcases today. Basically building a frame to fit inside the case and wrapping the underside with wiggle wood.  Sawed out the curve and sanded to the line. Then used that to pattern route the rest of the parts. Used clamps everywhere possible and routed the clear section at each end.
Shifted the clamps and routed the rest of the arch.
Using a large bearing over bit to pattern route takes some focus and caution. Damn near cut the cord once today. Now there is just a few more pieces to route and it's on to the wiggle wood.
Got the arch frame assembled and skinned the inside with wiggle wood (Italian poplar  3/8 bending ply) . Glue & nails plus clamps wherever possible.
Knocked this one together and hauled it out of there to beat the traffic. Already have all the parts cut for the second one. That can wait till Monday for assembly.  I've got a date with a redhead to get ready for.
Got to get that chain mail underwear in place, right?
And I quote you in these:
”Sign and date it”
”Without pics, it didn’t happen”
