Arched bookcases and Fireplace surround w mantle.
The open areas in several places would expose the panel groove. I tried to figure a way to transition between a profile with and without the groove. So I set up the upper cutter & bearing without the grooving blade/bit in the router table and profiled 2 sides of a 12' & 10' board, ripped those off and repeated to make the trim. The same bit set up in a portable router used the bearing riding on my 1/2" MDF templates to profile both edges of the arches.
  • Replies 137
  • Views 34.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • It's DONE !!!! 9 pm on Friday night and I am exhausted ! I think I'm going to sleep late tomorrow.
  • After several distractions I got back on the arches.  Had to make templates for the top and bottom curves. Getting the blanks glued up was a bit tricky but the came out with tight joints and dead flat
  • Main shop is 20 x 50 w 16 ft ceilings I think. Office, bathroom ,kitchen & storage 12 x 50. Loft is 12 x 30 , stairs up to loft sure  beats the ladder I had in my old shop. Main outfeed /assembly
Posted Images
Took the mantle and lower sections of the wall paneling to the jobsite for a test fit & scribed the panels to fit the hearth. Measured for trim etc.
Really nice work here Steve!! Taking notes I have always thought our surround was a bit weak for the wall its on.
Hard to no what to say except much respect for your great workmanship and knowledge.
Thanks, we will be back on it Thursday. Had to pause and run a batch of shelves for my biggest client.
I got a call that my color matched finish was ready but they forgot to check the expiration date on the cans. The finish I have used for many years is a pre-catalysed waterbourne. It's easy to use and has a 1year shelf life, unfortunately all the cans they had on the shelf expired in April. After it expires the drying time is much longer and it is a much softer film.  When the catalyst works it produces a very tough finish that works well even on tables & counters. At least he checked the expiration dates before I came to pick it up.
Finally got the large 5" maple crown installed ! I learned that large thick crown is a bear to cut & install. I had to rework the support framework.  Not going to ever use that approach again.
IMG_3023.thumb.JPG.59f7b4f8e64ab88438e74237656eca9c.JPGIMG_3024.thumb.JPG.ab19faee212c3e5e699a2eca2b3e7c66.JPG
Kinda glad it's getting painted.  Joints could have been better but the crown was so stiff and had slight bows & twists that complicated closing the gaps.
  • 2 months later...
Finally on the last steps of this job. Got the left bookcase installed after shaving both plywood sides by 1/8th . The walls in the house varied and when we installed the center mantle section I kinda painted myself into a corner.
Trim , raised panel doors , drawer fronts and the Right side cases are primed at the shop. Now I have a disgusting amount of sanding to do. Abranet 1000 grit leaves a beautiful surface for the finish coats.
As usual, beautiful work Steve.  That 1/8th had to be a PITA.
Yes the job is looking great Steve.  Do the side cabinets have lights in them?   I see the wire sticking out of the wall.
Looking great Steve! What paint will you be using? We just had our cabinets painted and they used SW ProClassic. The finish is fantastic but even with the kitchen area sealed off with plastic, the smell was unbearable for 3-4 days and gosh awful for 2 weeks to follow.
M L Campbell Agualente  pre-catalysed (it's sort of a water bourne lacquer) comes in clear and a tintable white base. A clear sanding sealer and a white primer dries fast and sands easily after an hour or so. Smell is kinda like windex . You would want plenty of masking, plastic and a fan in the widow to spray it in a kitchen. You can touch up with a foam brush but it's meant to be sprayed. I've got a tiny spray gun just for touch ups that runs on 10 PSI.
The catalysed finish is tough as hell. You can actually buff it with a white abrasive pad to get a semigloss if you spray satin. A grey pad  then a white pad will smooth out a scuffed finish. Only drawback is $68 a gallon off the shelf or $78 for color matched/custom tinted. My supplier has a guy that can match paint colors and stain colors too.
It's DONE !!!!
All i can say Steve is WOW!!! beautiful work sir and i'm sure the clients are more than pleased, you sir are a craftsman of the first order, oh yeah, sleep in for at least a couple of days, you earned it. great journal, i love to follow your work.
Steve, you just keep me floored with the quality of your work. If I had the time without life being in the way, I'd come apprentice with you.
Thanks for the kind words gentleman ( I use the term loosely ) !  I feel much better after a steak and some fine tequila. Guess who loves steak scraps ?
Whoda thunk it?  Is he still a wild little thing?  Hell, I like steak scraps to.
Fantastic work, Steve! My only criticism would be going with black socks.
I have been waiting to see the final product on this build.  You get the most interesting projects.  That is a real majestic piece in a great setting.  Just wonderful work.
Awesome work as usual Steve!
A wise member here reminds people to "sign it and date it" and it's pretty good advise!
