The legs need some refinement. I wanted a bead on the corner, but have no beading bit. Time to improvise. First, a 1/8 radius round over.
Here's a "pro tip". Don't panic about gappy miters until you refine the corner. Rounding took this:
To this.
Now that the corners were round, I took a 90* V bit, set it about 3/32 deep, and used a steel rule and gauge block to set 3/16 from the fence.
A pass around each side of the corners, and viola, beads.
Lots of things can be made to look perfect with small round over or chamfer.
Thats a cool bead technique.
  • Thanks 1
You have mentioned more than once about the lack of space in your shop. So obviously it’s not the size of the coliseum but the skill of the warrior. Looking great bud!
  • Thanks 1
On 9/17/2021 at 7:23 PM, wtnhighlander said:
This one felt a wee bit sketchy
Knowing you machine, confidence in your set up and having your head in the game makes the difference.
Having said that, good time for a auxiliary tall fence.
On 9/17/2021 at 8:02 PM, Chet said:
 . .  good time for a auxiliary tall fence.
+1.
I have one that clamps to the table.  Not great for adjustability but, gets the job done.
With your style fence, one that clamps on could be used.
Just having a bit more surface gives more confidence in the operation.
All that noise aside . . . I'm lovin' this journal.  Very cool approach on the legs (dado becomes tenons).
  • Thanks 1
On 9/18/2021 at 7:53 PM, wtnhighlander said:
The face side of the beads is a different matter. If I had thought about order of operations, I would have rounded the corners first. But I rushed, didn't think, snd made a boo-boo.
Time for CA and sawdust!
After a little carving of the groove, it isn't so bad. The color going on this piece should hide that pretty well.
Moving along, I started cutting to "cock-beaDing" that goes around the legs.
I put a 45* block on a bench hook to help, but these thin pieces were pretty simple to cut.
Since my marking knife won't fit in that groove, I use the marking pin stored in my combo square to punch a mark for the inside of the miter, then take it out of the groove and mark witb a knife.
A sharp pull saw can really take a fine cut!
So, here is the cock-beading in place. No glue yet, so the tape helps to avoid losing any small bits.
Here is what the lower shelf looks like with legs attached.
Details such as these are what makes a good woodworker stand out! Well done.
  • Thanks 1
On 9/21/2021 at 5:11 PM, wtnhighlander said:
Shop floor looked like a pink coral beach.
I can only imagine.  No way to do it outdoors?
To me padauk is the worst.  No matter what your DC does, that dust gets everywhere.
1 hour ago, Coop said:
I tend to be a little slow and have no imagination. Why did you re-attach the sides to the oval part?
Gluing the sides & ends back on, but with an offset upward (on the face side) gives me an extra 3/4" or so of depth.
I have done similar operations outside, using a weighted wooden stool and hand-screw clamps to hold the work. Not an ideal working height, and noise from the grinder is a lot more of a nuisance to anyone in the house, or nearby houses. I only do that during mid-day work sessions, not early or late.
Got it. Couldn’t tell from the pics. Great idea and one I would have never thought of.
  • Who's Online   1 Member, 0 Anonymous, 43 Guests (See full list)
