Combo blade or dedicated blades?
18 members have voted
  1. 1. Which do you use most of the time? Soon I hope to have a working hobby shop, and I am contemplating buying a combo blade, like the Ridge Carbide TS2000
    • I used a combo blade most of the time, unless I need to rip really thick stock
      14
    • I always switch between a crosscut and rip blade for best possible cut
      4
Posted (edited)
Soon I will have my table saw in order.  I am thinking a combo blade might be best to reduce change over time.  Wondering how most of you go about table saw blade selection.  Do you use a combo blade most of the time, swapping it out only for things like ripping thick stock?  Or do you use a specific blade for each cut (potentially lots of blade swaps)?
Edited by andrew-in-austin
For years I used a combo but the last year or so I have used  rip and cross cut blades.  Some times I paint myself into a corner and feel like I am constantly changing back and forth, but most of the time with a little planning I can get good use out of a blade change.
I keep a Woodworker II on most of the time. If I have a lot of ripping to do, I'll change, but it has to be a lot.
x2 Same here.
I'll also swap to a #1 grind if I'm doing joinery, but 90% of the time the WWII 40T stays on.
Dedicated blades do the job better than combo blades, hands down, no doubt about it.  But combo blades do most jobs good enough and they're great for the lazy...which makes them great for me.
I like the combo as well. Most of the time I will rip on the bandsaw, close to the line and finish on the ts with the combo. I do like the flat grind though for cutting out for splines.
Posted (edited)
The better the blade and the sharper it is and the more HP the saw, the more you can get away with a combo...
If you take all my time at the saw, I'd bet 70%+ of the time, it’s a combo --- the Forrest WWII ATBR-grind blade. The #6 grind is a combo, but slightly more 'rip' oriented for those typically working with hard woods...
Heavy ripping session (meaning 1hr or more just ripping) -  I switch to WWII-rip grind (forget the number).
Final cross-cut session with repeated fine xCuts - DuraLine Hi/AT.
Joinery session - WWII FTG grind (#1-grind, if I remember, maybe it's #7).
Finger Joints – Forrest Finger Joint Set (4 plates)
Dados – DadoKing.
Plywood – DuraLine Hi/AT (this is an expensive option). Forrest now makes a 'plywood' blade for $50 less.
Edited by hhh
Posted (edited)
A general purpose blade is really handy even if you do use separates.....it doesn't have to be an either/or scenario....you can definitely have both!  I switch depending on the need at the time.  Most of the time a good general purpose blade does fine, but I keep a good assortment of specialty blades for when I need them.
A GP blade won't rip as efficiently as a true rip blade nor crosscut as cleanly as a good dedicated crosscut blade, but you may find that it’s more than acceptable at doing both tasks for most situations. A valid argument in favor of using one high quality general purpose blade is that the GP blade leaves a cleaner edge than the rip blade, crosscuts faster than a crosscut blade, and does so with the convenience and cost of using one blade. Most higher quality general purpose blades will leave a glue ready edge, which is often as good as it needs to be. Task-specific blades (typically a 24T ripper and a 60T or 80T crosscutter) will generally stay sharp longer than a single general purpose blade because they share the work load, but will cost more upfront and will also cost more to re-sharpen when the time comes.
The TS2000 is an excellent choice for a GP type of blade.  Holbren has it for ~ $90 shipped all the time.  However, since a GP blade is a compromise in design, sometimes I question the need to spend near $100 for one.  The Infinity Combomax 50T is great easy to use option that won't break the bank (< $70).  The Delta 35-7657 is on closeout from from Cripe and others in the $30 range...not the best out there, but is surprisingly good...a best buy for sure, saving you money for a good specialty blade for those moments when it matters.
Edited by knotscott
I have 2 saws so I keep a rip on the saw with the longest outfeed table and a crosscut on the saw with the sliding table. But for your purposes a combo is the place to start. Your next blade to buy would be a good crosscut blade because a combo usually rips pretty good.
Its important to keep your blades clean. The build up of resins leads to faster dulling.
Steve, what is your method for cleaning a blade?
Personally...I use a dedicated rip and crosscut most of the time. I try to keep my work flow so that I make all my rips, change the blade and make all my crosscuts for a given project. It doesn't always work out so well, but most of the time I am only changing out once per project.
  • Who's Online   2 Members, 0 Anonymous, 41 Guests (See full list)
    26,008
    Bob44
    Bob44
