Coop Posted June 3, 2016 Report Posted June 3, 2016 I can see this piece being copied, at least once in Houston! Good idea too about the band saw blade storage! 2 Quote
..Kev Posted June 4, 2016 Author Report Posted June 4, 2016 Boss let me back in the shop for a bit so, got the other drawers built.. Was a set of glides short.. I'll pick them up this weekend. 4 hours ago, K Cooper said: I can see this piece being copied, at least once in Houston! Good idea too about the band saw blade storage! Let me know if you need anything from it Coop.. Happy to help! Quote
Coop Posted June 4, 2016 Report Posted June 4, 2016 Thanks Kev! I like every part of it. I brought my utility trailer home from work today and plan on going down tomorrow and getting some bb ply. I may have to float it home though. Looks like you made the entire build from 3/4", drawers and all? Quote
..Kev Posted June 4, 2016 Author Report Posted June 4, 2016 5 minutes ago, K Cooper said: Thanks Kev! I like every part of it. I brought my utility trailer home from work today and plan on going down tomorrow and getting some bb ply. I may have to float it home though. Looks like you made the entire build from 3/4", drawers and all? Yep.. Drawer bottoms are 1/4 except for the drawer bottom that holds the tenon jig, I did that in 3/4. I'll add some maple trim and probably walnut drawer fronts to it to dress it up as the scrap material is available but, it's shop furniture. I was't concerned with screws showing or that it's obviously plywood. Quote
Coop Posted June 4, 2016 Report Posted June 4, 2016 I agree. Functionality, availability and common sense sometimes have to come into play. I mean, I'm going to copy this down to the tenoning jig drawer, as mine is on a top shelf now, that requires a ladder to access. The only difference , mine will be on casters. Thanks again for the influence! 1 Quote
bleedinblue Posted June 4, 2016 Report Posted June 4, 2016 Man, you built this thing in like what, an hour? You work fast! Quote
..Kev Posted June 4, 2016 Author Report Posted June 4, 2016 Just now, bleedinblue said: Man, you built this thing in like what, an hour? You work fast! Not quite that fast.. Probably about 10 hours in it total.. Just seems fast on here. Quote
bleedinblue Posted June 4, 2016 Report Posted June 4, 2016 Ha, well I was exaggerating a little. I'm just envious to see a project come together in hours or days, versus weeks or months 1 Quote
Cliff Posted June 4, 2016 Report Posted June 4, 2016 You guys make drawers in cabinets look so easy, I really hope it is since I gotta work on some of that coming up. Congrats on the new drum sander! 1 Quote
..Kev Posted June 4, 2016 Author Report Posted June 4, 2016 5 minutes ago, Cliff said: You guys make drawers in cabinets look so easy, I really hope it is since I gotta work on some of that coming up. Congrats on the new drum sander! Nothing fancy about those drawers at all! Butt joints, glue, and screws.. It's shop furniture! The important part to using those glides is that you have to be pretty spot on with the width of the drawer.. There's just no a lot of tolerance for error. Too wide and they just flat won't work. Too narrow and you'll have to shim the glide to get it to work well with the drawer. I install the glides before I build the drawer. From there, I cut the front and back of the drawers so that they fit perfectly (sneaking up on the fit) between the glides. Then I cut the sides 1 1/2" shorter than the glide and build the drawer. 1 Quote
bleedinblue Posted June 4, 2016 Report Posted June 4, 2016 Getting that right size is the intimidating part I think. I've pretty well avoided projects with drawers, but not because of the joinery. I need to change that someday. 1 Quote
..Kev Posted June 4, 2016 Author Report Posted June 4, 2016 1 minute ago, bleedinblue said: Getting that right size is the intimidating part I think. I've pretty well avoided projects with drawers, but not because of the joinery. I need to change that someday. No reason to be intimidated. Like I said above, if you install the glides in the cabinet first, it's easy to sneak up on that fit. Even if you're doing dovetails, cutting the front and rear board are cut to that perfect size. 1 Quote
Coop Posted June 4, 2016 Report Posted June 4, 2016 41 minutes ago, TIODS said: Butt joints, glue, and screws.. And you didn't use a pseudonym in this build. Your reputation is at stake! 2 Quote
Popular Post ..Kev Posted June 4, 2016 Author Popular Post Report Posted June 4, 2016 1 minute ago, K Cooper said: And you didn't use a pseudonym in this build. Your reputation is at stake! Nope.. It's shop furniture. Absolutely no shame in it! If you want to practice something, then by all means, go for it on shop furniture! It's a great place to practice! I'm not saying I don't need to practice but, the new machine will be here Thursday, I'm heading out on the next Job next Saturday, my kid graduates tomorrow, I just needed it done. There's a time and a place for everything, this just wasn't the time and place to improve my hand cut DT skills. 3 Quote
Chet Posted June 4, 2016 Report Posted June 4, 2016 49 minutes ago, TIODS said: Butt joints, glue, and screws No pseudonym required, like Kev said a couple of times it shop furniture. Shop furniture can be therapeutic, you can get all those I want to use screw/brad nail/pin nail/staples feelings out of your system for a while. 1 Quote
Popular Post ..Kev Posted June 4, 2016 Author Popular Post Report Posted June 4, 2016 19 minutes ago, Chet K. said: No pseudonym required, like Kev said a couple of times it shop furniture. Shop furniture can be therapeutic, you can get all those I want to use screw/brad nail/pin nail/staples feelings out of your system for a while. Yep.. Should have mentioned... I used some brads to hold the 3/4 ply in place until I got the screws in.. In my defense, I did don my flannel before firing up the compressor 4 Quote
gee-dub Posted June 4, 2016 Report Posted June 4, 2016 Flannel shirt approved ;-) Ya gotta love a machine base with storage. Coming along nicely. 1 Quote
..Kev Posted June 5, 2016 Author Report Posted June 5, 2016 Graduation festivities over! Back in the shop today.. Got the old sander moved to its new shop. Finished the drawers in the new stand and moved it into place. Pretty heavy! Then, I started making drawer fronts. Used up the walnut scrap that I had and will actually have to pick up a little more tomorrow for 2 of the drawers.. Currently, no drum sander so, these will just be sanded with a ROS, some finish slapped on and installed. Still undecided on handles. All of the other handles in the shop are hand made so, I may fire up the router table and make another batch for this.. 2 Quote
mat60 Posted June 5, 2016 Report Posted June 5, 2016 Looking good..What great storage you will have. 1 Quote
chrisphr Posted June 5, 2016 Report Posted June 5, 2016 I can see this piece being copied, at least once in Houston! Good idea too about the band saw blade storage! Ditto that. There will be another copy in Charlotte! Sent from my iPhone using Tapatalk 1 Quote
Chet Posted June 6, 2016 Report Posted June 6, 2016 I thought it was going to be positioned so that you had the recessed area to the left of the small drawers for band saw blade storage - change in plans? Quote
..Kev Posted June 6, 2016 Author Report Posted June 6, 2016 5 minutes ago, Chet K. said: I thought it was going to be positioned so that you had the recessed area to the left of the small drawers for band saw blade storage - change in plans? Nope, they're back there and tucked in nicely. Once the actual machine is here, I'll see how far I can pull it away from the wall. Worst case is that I have to pull it each time I need a blade which wouldn't be the end of the earth. I used some coat hooks in that cavity to hang the blades. Quote
Popular Post ..Kev Posted June 6, 2016 Author Popular Post Report Posted June 6, 2016 Since I realized I wouldn't be able to get the side drawers open without handles, I set up the router table and batched out a couple decent size sticks in maple to contrast the walnut.. Just a bull nose on the inside, cut off at the TS, and then a round over on the outside. Simple but, good enough for shop furniture. Then I went to the chop saw and batched them out in 4" lengths. There were 2 shorties left that I'll hang onto for something at some point in the shop.. 6 Quote
..Kev Posted June 6, 2016 Author Report Posted June 6, 2016 5 minutes ago, Llama said: Looking slick Kev. Thanks Mel! 1 Quote
