Popular Post Ronn W Posted June 10, 2016 Popular Post Report Posted June 10, 2016 Most every project for me includes something that I have not done before. In this case it is veneering, ¼ x ¼ corner banding a box and a hand rubbed finish. I asked some questions on this project in previous threads. Thanks for all your input. The box is ½” Baltic Birch plywood with waterfall cocobola veneer and maple banding. Since the piece is only 10” long I used parallel jawed clamps and 8/4 maple cauls to clamp the veneer in place. Used tight bond original glue. I was pleased that all sounded solid when I tapped with my finger nail after removing the clamps. I made it as a closed box rabbeting the sides at the corners and rabbeting the top to the sides. The bottom is ¼” plywood in a rabbet on sides. I cut the rabbet for the banding at the table saw after the box was totally assembled. I installed the banding on all12 edges and smooth the surfaces with a block plane and 220 grit sand paper. Cut a box apart is nerve racking since there is no room for error. One of you suggested that I set the TS blade height to cut almost but not quite all the way through. That is what I did. When slid my handsaw into the kerf it went through the reaming wood without taking a stroke and the box was in 2 pieces. Great suggestion. Thanks. I applied the banding to the bottom of the lid and the top of the bottom. Sanded it all with 320 grit and I was ready to finish. I started with 2 coats of Aqua Coat since the veneer grain was very open. After my first coat of Arm-R-Seal I used the Aqua Coat again since I found a couple of places that I new the Arm-R-Seal would never fill in. I had problems with the finishing. For the top surface I used Arm-R Seal applied with a sponge applicator so that each coat (especially the last would be thick enough to withstand the multistep finish and polishing process without breaking into the previous coat – and that went well. But when it came to the sides I found that my technique was lacking. I could not avoid runs. Thanks to the person on the forum who suggested that I was applying the Arm-R-Seal to thick. I switched to using a rag and after a couple of practice pieces I was able to apply the Arm-R-Seal to the vertical surfaces without any runs and without friction marks. I have 5 coats on the top and 7 coats on the sides. The final step was to wet sand the top with 1000 grit then 2000 grit. Then some serious rubbing with Mequiar’s mirror glaze #2 followed by a light polish and buffing with Mequiar’s mirror glaze #7. I had learned on my practice board that it took a lot of hand rubbing to smooth out the 2000 grit with the #2 enough to avoid a hazy end product. I had intended to use #5 in between #2 and #7 as recommended by a local finishing guru but it is no longer sold. Today I glued green felt to the inside of the top and bottom and lined the inside of the box with unfinished mahogany with mitered corners. I decided against hinges since I want the box to survive my granddaughters childhood. My take away from this project is that while the box itself came out fine, I would not use Arm-R Seal for this type of finish on a box again. I have never used lacquer or shellac and since my ventilation is questionable learning about shellac is now on my short list. 5 Quote
..Kev Posted June 10, 2016 Report Posted June 10, 2016 Beautiful job! I hope she's old enough to understand what's there! Quote
shaneymack Posted June 10, 2016 Report Posted June 10, 2016 Box looks fantastic Ronn ! Great work! I hope this box survives your granddaughters childhood so she can really appreciate what she has there ! Quote
Janello Posted June 10, 2016 Report Posted June 10, 2016 Very well done, Ronn. Looks like you nailed all three new techniques ! Quote
mat60 Posted June 10, 2016 Report Posted June 10, 2016 Looks great Ronn..The maple and cocobola look great together. Quote
Popular Post Ronn W Posted June 10, 2016 Author Popular Post Report Posted June 10, 2016 Next week is her first birthday so am sure she fully understands. I'll talk to her mother (my daughter) - we may save it for a couple of years. I just had an itch to make this box and had to scratch it. But I can't think of anyone else I would rather give it to. Thanks for the kind words. 3 Quote
bradpotts Posted June 10, 2016 Report Posted June 10, 2016 The finish looks really nice. The veneer looks awesome! Quote
wdwerker Posted June 10, 2016 Report Posted June 10, 2016 Impressive ! Dont forget to sign it and date it . Quote
Dknapp34 Posted June 10, 2016 Report Posted June 10, 2016 Beautiful box! Love the wood choices and the finish came out great. Sent from my iPad using Tapatalk Quote
wtnhighlander Posted June 10, 2016 Report Posted June 10, 2016 That looks great, Ronn! It won't be long before she's asking Grandpa to make more stuff! Quote
Coop Posted June 10, 2016 Report Posted June 10, 2016 Ronn, Great looking box. I've never done veneer before but looks like you nailed it! Put a little aside in a good investment into the box each year and at collage age, her tuition will be paid for. As far as the ARS, don't give up on it. No offensive, but sounds like user error. Quote
bleedinblue Posted June 10, 2016 Report Posted June 10, 2016 Nailed it! That looks fantastic. I need to try this decorative box thing, it looks like a fun build. Quote
Ronn W Posted June 10, 2016 Author Report Posted June 10, 2016 1 hour ago, K Cooper said: Ronn, Great looking box. I've never done veneer before but looks like you nailed it! Put a little aside in a good investment into the box each year and at collage age, her tuition will be paid for. As far as the ARS, don't give up on it. No offensive, but sounds like user error. Oh, you are right. It was user error. As I started to do the vertical surfaces where I got the runs, I was thinking that I would hand polish the whole box and I had heard that ARS and varnishes have a boundary between coats that will show up if you accidentally sand too much. That is why I was going for thicker coats. When I switched to wiping it on the sdies (thinner coats) I played it safe and abandoned the idea of rubbing out the sides of the box. The veneer was fun and because the box was small enough to be clamped it was easy. Someday I want to veneer are large piece with mirror grain veneer or something fancier but that will be a whole different ball game. 1 Quote
Chestnut Posted June 11, 2016 Report Posted June 11, 2016 Looks great. Lacquer does buff out very nicely but it is with it's own learning curve. I have yet to try the process for shellac. The speakers i made in my project journal are coated with lacquer, i did a slightly sub par on the finish for them. Quote
Ronn W Posted June 11, 2016 Author Report Posted June 11, 2016 For those of you that are thinking about trying a finish like this for the first time. I learned a couple more things today and, naturally, it is too late to do anything about it. I took the box out of the shop this morning and happened to set it on the kitchen table in the sunlight. Pow! A couple of small imperfections jumped right out at me. Very frustrating to say the least. But the project is done and the lessons are learned. Heck, a am giving this to a young child - what's it going to look like in a few years. [Rationalization]. Anyway, so 1) next time it will examine the finish in various types of light and from all angles at each step of the process and 2) The closer you get to the end, to that gloss perfect finish that you are striving for, the more the little imperfections become visible. 2 Quote
