I’m on the hunt for a used Powermatic 720HD Hollow Chisel Mortiser, or another brand with similar quality and specifications.  I would welcome any recommendations on alternatives to the 720HD and where to locate used equipment such as this.
I used to belong to a co-op shop that had a similar (possibly same??) Model machine and a very similar jet machine. They were both extremely similar but the jet cost less for no particular reason. I would say either does a fine job if you want a mortiser. However. As someone who owns a floor model mortiser, I would say that if I had to do it over again I would buy a domino first.
As for where to buy? Craigslist and eBay. Search Craigslist using 3rd party search tools like search tempest. That way you can see tools outside your area. Be prepared to drive quite far. I drove over 5 hours each way to get my mortiser and counted myself lucky to find one that close. Floor mounted Mortisers are not typical weekend warrior equipment so they show up on the used market far less frequently.
Thanks for the Festool Domino recommendation.  I agree that it is a good choice for many applications.  However, I also believe the Hollow Chisel Mortiser has its place as well.  In time, I plan to have both in my shop.
I have been looking on Craigslist and eBay for a floor model HCM comparable to the 720HD without success.  I’m growing impatient, so I am posting here to see if anyone out there has some insight into where I might find what I want.  Again my thanks for any assistance you can provide.
Have you given consideration to cutting your Mortises with a plunge router and edge guide or duel edge guides.  Its a pretty simple set up.
Since you bring it up..  I had both (HCM and Domino) in my shop and got rid of the HCM..  Since then, I've had one project where I wish I still had it.  Was an easy work around.
Your shop, your flow, just my experience.  Good luck with your search!
I've got a drill press HCM attachment that hasn't been used since I got my Domino.  Far easier to use a Domino on long or heavy pieces than taking a part like that to a stationary tool.
I bought a Delta drill press that came with HCM bits.  As far as I can tell, they work just fine, improved my mortises immensely and very much shortened the time to construct an outdoor table.
Not to say that the Festool solution wouldn't have been an improvement (my buddy swears by them.)
The HCM bits came with the Delta drill press as a freebie.  I'll bet many folks never unwrapped them.  You might try looking or requesting on CL.
Whatever mortisers you look at, one thing that machine designers seem to have forgotten is that with a strong clamp that secures the piece or work against the fence, the table, fence, and clamp needs to be made all in one piece.  If the clamp is mounted to the machine base, and the fence moves independently of the base, no method of clamping the fence down will prevent the possibility of moving the fence back with the work clamp.  I'm sure that's why Powermatic changed the design of the little benchtop mortiser by doing away with the clamp.  If the whole assembly is cast in one piece that includes the clamping mechanism, it's a good design.  Otherwise, pass.
You didn't mention price. Price? Not much for the Domino...
  • Who's Online   3 Members, 0 Anonymous, 36 Guests (See full list)
    26,008
    Bob44
    Bob44
