Upgrading sliding glass/walkout basement door
The upgraded decking is on the back burner as my wife is officially "over" our basement door, which is the typical builders grade piece of junk.
We're gonna go with some sort of French door...I think I'd prefer one where both doors swing out, but that's not absolutely necessary.  It would help to get large items in and out of the basement though.
I've never hung a door before.  Is there any gotchas?  Will everything come in the kit, or do I need extra flashing/sills or anything for weatherproofing besides shims and caulk?
Just make sure outswinging doors are built to prevent opening by pulling the hinge pins. Out-swinging hinges are also exposed to rust & corrosion.  The top & bottom of doors needs just as much finish & protection as the rest of the door so don't forget to inspect those spots.
Gotchas tend to be plumb related. You want a swinging door to be dead plumb while your wall may not be. This can lead to some creative trimming.
Also measure from corner to corner, square is as important as level. Level in and out as well as side to side should be considered.  I use plastic ridged interlocking shims on exterior doors , caulk and flashing is your friend, moisture is the enemy.  I use long screws instead of nails.
Installing a prehung door unit is not exactly the same as "hanging" a door.
On swinging exterior doors, I always use ball bearing hinges.  Patio doors are especially heavy, and if used daily, will wear out a top, regular hinge in just a year or two.  I've never had to replace a ball bearing hinge on one of my entry, or patio doors.   I don't know of any unit that comes with ball bearing hinges, but I go ahead and replace them to start with.
On the question about everything coming in a "kit" that you will need:  I doubt it.
The main thing to do is not get in a hurry.  Once you have it wedged in place the best you can, double-check everything.  The most important thing is the way the bottom of the doors interact with whatever is below them.  Behind the upper hinges, cut opposing wedges that fit to completely fill up the space, and run one really long screw in one of the hinge holes into the jack, and stud, whether the manufacturer leaves one screw out or not.
I always make wedges out of a good wood for the jambs, and don't use the packages of softwood wedges.  Taper, and thickness of wedges will depend on how much space you have between the framing, and jambs.
I just love having Tom on here for things like this.  His real world experience really helps us now-and-then folks when it comes to house repairs and mods.
Another plus I thought of for outswinging doors, and ball bearing hinges.   The pin in a ball bearing hinge is captive, so someone can't tap the pins out, and drop the door to the outside to break in, like can be easily done with butt hinges.
Blue, are you thinking outswing due to lack of space on the inside? I replaced our sliding door a few years back with ones opening into the room and we almost never open both at the same time unless moving big stuff in, which is seldom. In the spring or fall, if we have get together on the patio, we’ll move a chair in front of the second door, which is only a temp inconvenience. Obviously a helper is a must and as others have stated, square, plumb and level are very important. Good luck bud.
I hadn't decided on outswing vs. inswing...I could really go either way.  I'd like both doors to be able to be opened, but realistically, in the seven years we've lived here there has probably been once or twice when I was wishing for a wider door.  It's rare.
As far as installation, is this as "simple" as putting the new door assembly in place, using caulk all around the frame and in the areas the instructions say, and using shims to square/level and plumb it before screwing it down?
Spray foam a good idea to have on hand in case of gaps?
Double doors are a little more complicated, since the two doors have to work together.   There's a little more chasing your tail involved, since you get one side working properly shimmed in place, and then the other side.  Often you'll have to reset the first side because the heights might not be exactly the same, and you need to adjust the height of the first one again.  You can't check the opening with any kind of level, and predict that it will work perfectly just by sitting it in the hole after looking at the level.
Use spray foam for windows, and doors, as it doesn't expand with the force of the regular stuff, so not as likely to push something out of place.
I was squarely on the fence on how necessary double doors were...that may be enough to knock me away from it.  I really, really don't want to get the old door removed then not be able to get the new doors adjusted properly or have to call for help mid-installation.  This needs to be something I can be relatively confident I can do by myself in a day or less.
Make sure you have everything possible on hand before Friday night. Start Saturday morning. Make sure plans aren't in the way for any possible spillover into Sunday. Prepare, execute and clean up.
A unlocking tool for the siding would really be helpful.
It's not THat bad.  The whole picture is just a bit larger than installing a single door.   It will be a heavy unit though, so not a one person job anyway.
Yeah, I just saw the listed weight for these things.  200+ pounds.  That's surprising.  Any reason why I couldn't take the doors off and carry it to the back of the house piece by piece?
Id sooner get some help before Id take the doors off.
If I can do it, anyone can. Just get two good able bodied helpers while you direct, and send mamma shopping so she doesn’t have to put up with the heat. I’m with Steve on having everything ready the night before. Demo the old and install the new in one day and trim it out the next.
The glass is where the weight is.   It only rattles one vibration.   You need some help, even if you take the doors out.  Most of the work in building is in moving weight.
A 73 year old carpenter I hired in 1974, Mr. Randolph Pearce, told me, "Building ain't about knowing what goes where, it's about how to get the plywood on the house."
My two helpers can almost read a tape measure between the two of them, but they can each bench press over 400 pounds, and deadlift all the weight I own.
The frame gets kinda floppy with out the doors holding it together. Which makes everything harder imo. I just did my shed double door and thought it was a little bit harder than a regular door but if you can shim it flush and square you can install it. The biggest thing i always fight as an amateur is getting the rough opening prepped. I'd pull your trim before you buy a door to make sure you have the space
Adding to Chestnut's post, since you have to remove the j-channel anyway maybe new construction doors would be easier to install.
Until you get to the high end ones, I don't see much difference between the others, so I don't see any need to favor one brand over the other.   I would check to see if you have Habitat stores anywhere near you.   I've bought some that were like new from a Habitat Store, for a fraction of the new price, and from a building material recycling place (salvage yard) in Maryland, a fiberglass unit that had never been used for 10% of new, but you have to have something to move them on yourself.
There may be something similar to one of these near you:   http://communityforklift.org/our-store/our-inventory-2/       Rather than pay a disposal fee, builders take stuff here to get a taxable donation for it.   I hate to pass through there without having a trailer with me.
We have a double french door on the front of our house, and I might open the second part once a year, but it is wonderful when moving things in and out of the house.
Our exterior doors on the house are all trimmed with aluminum so they don't require painting.   The doors that the borg has in stock are just primed wood, if you wanted aluminum cladding it's probably a special order.
I used a Jeld-wen 36" exterior door on my shed, and I have to paint the wood frame/trim about every 3-4 years.   It's what I'm going to be doing this weekend, so I just thought I'd mention it.
I've had good luck with the mastercraft doors from menards. Special order with the cased trim they still arrive in 7 days or less. Beats lowes and home depot think they quoted me 45 days for a special order door..... :blink:
  • 26,009 Total Members
  • Joseph b Newest Member ·
