Never seen that before. I suppose you don't want to use it in case it doesn't work but i'd say try it on scrap and see how it goes. If they guy sold you a dud that's what returns are for. They should understand.
At the moment I was thinking I could lower a 1/4" rounding bit and use that on my router table but the 1/8" is really what I wanted. You're right, at the price point it's no big deal but I could  get a Whiteside bit like I want for another $5 :)
I'll give it a shot and report back I reckon.
The more I think of this....
How far does the iron project? Chamfer planes with a V sole are notorious for not “rounding” well. Corner “easing” and the images make me suspect this here.
I have a toolbox full of small routers with roundover bits.  The 1/8" does get used a lot.  It hits tops, and bottoms of house doors, and many more uses that I can't think of.   I even have one 1/16", which makes more of a noticeable roundover than you might think.  That one gets used on door jambs.  I don't think I use anything larger than 3/8" with the small routers.  Barn posts get 3/4" by a 7518.
That plane looks interesting, but the picture makes it look like a Chamfering plane, rather than a roundover.
Like Tom I have 1/16" roundovers, 1/8" - 3/8" in 16ths and random hops up to 1-1/2".  I would order a Whiteside and wait a day or two rather than proceed with an incorrect size for the job or sandpaper both of which create the ultimate sin in roundovers; a soft, ill-defined, doughy look.
I didn't get out to the shop today but yeah, the more I think about it the more I'm planning on the router bit *shrug*
I may keep the plane and try it on bits n pieces rather than all these spindles, stiles and legs. It's a lot... And consistency is key like gee-dub said. Last thing I want after all this effort is a poor finished result because of a tool I'm not used to doing a half-baked job. Ugh
I don't use a router for eased edges at all anymore. Just a block plane and/or sand paper. Much less noisy, messy, & less chance of screwing something up. And it is just about as fast. I'll be interested in your report on that little easing plane though.
I use a block plane (or sand) as well.  But I'm interested in Gee-Dub's comment about a "doughy" look.
I've already softened the edges with a block plane and it looks OK, but there are 24 spindles and four splines plus the legs and all the cross pièces.  It's a California King size bed so it's 6' wide as well. I've used scrapers as well where the cloud lifts are, and sandpaper where those don't do the whole trick :)
Gee-dub I call that a well-illustrated point ! :)
So I tried the corner plane and no, it doesn't do what I want at all. If you have a board where you want to soften its edges, OK. But if you have a spindle (or 24) you want rond corners on, this ain't it.
I've ordered the rounding bit this morning. Woodcraft is far enough across town I doubt I'll run across to return this thing. I may find a use for it somewhere else.
Thanks to Gee-Dub;  I agree with the preference for the last example.  For me, part of it at least is the smaller radius.
[Edit:  I should say that all the pieces look like fine work, the softer corners might be very toddler friendly!]
I've got a 3/32 radius roundover bit that gives that tiny slight broken corner look without making the "doughy " appearance. It's sold to round the edges on ColorCore laminate which doesn't leave those brown lines. If the corner isn't perfectly flat and straight the bit doesn't cut the full profile but some sanding evens that out easily.
  • Who's Online   0 Members, 0 Anonymous, 26 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
