Pennsylvania spice box build
I guess you can’t see the router bits too well in that last picture. Here they are out of the packages in better light.
Yep, the one on the left has a chip but the other cutter is fine so it still works.
  • Replies 94
  • Views 22.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Chip Sawdust
    Chip Sawdust
    So I cut the groove perfectly with my router and a spiral upcut bit.  On the wrong side of the board.  Ok so I cut a piece and put it in the groove as a patch, flipped the board over and started t
  • Chip Sawdust
    Chip Sawdust
    Thé partitions are alder and sapele, just jointed and glued Some 3/4” material together. Ran them through the “real” bandsaw to resaw a little thicker than the 1/4” final thickness, then ran it throug
  • Chip Sawdust
    Chip Sawdust
    Finally got to glue-up for the box. Sanded everything from 100 to 220, did a little tune-up on a couple spots that I left till last, then dabbed some Titebond II on the pins and squared it up. Inserte
Posted Images
Thanks Highlander - with the bits I have and whatnot I think that’s the best way. I don’t have bits that’ll make that exact profile so I’m going to have to dream up something that looks traditional but is doable :)
5 hours ago, wtnhighlander said:
I think that breaking that profile into more managable sections and gluing it back up at the end is the way to go. I can't see how you would maintain a reference face, otherwise.
Doing it in sections will work fine.  All your glue lines will be lost in the design of the overall profile.  I did something similar to this years ago using three different crown moldings to make a mantel for our fire place.
Finally made the drawer fronts. Need to cut the sides; I think I can use the resaw leftovers for the drawer backs.
It’s not perfectly square but the next one will be better :)
The right side has no drawer or door as she wants it that way. Simpler for me :)
will you be adding in a lock for the sugar? :)
I know many old spicy boxes had a area to put expensive sugar in the 1800s also expensive silver might be stored in a spice box.
Funny you should ask :) I have a mortise lock ready to go, and only Mama will have the key. So if she wants to put sugar in there, I’ll never know!
I don’t know how I got away from this but looking darn nice bud!
Thanks @Coop, it’s going slow, but I did start on the drawers a couple days ago so there’ll be updates soon. I also got another 1/4” plug cutter so I may try the berries on the door again. Going to have to take it real slow in that red gum wood. That Aussie stuff is tuff!
Ok is this a sin? I couldn’t find poplar wide enough to run the grain across the long drawer, but it’ll fit this way. Am I looking for trouble? It’s 12 3/4” x 8 1/2” and 1/4” thick.
It looks like heartwood so I’m hoping it won’t be an issue.
1 hour ago, wtnhighlander said:
If I read that right, this is for the drawer bottom? If so, running the grain across the width is good, as the rear can be left to expand outward.
Thanks Highlander, I was worried about whether I got it right. I ALWAYS use plywood but this plan calls for 1/4” bottoms so I cut everything with that in mind then D’OH realized all my “1/4” ply is 3/16” *shrug*
  • 2 months later...
Finally made some more progress in the past few days. Christmas is gone, Valentine’s is past, anniversary is past, wife’s birthday is past, but we have 4th of July to look forward to! :wub:
Lots of dovetails and resaw 1/4” poplar drawer bottoms (cut fatter then run through the planer to thickness). Two screws on the bottom (didn’t like the nail idea) to hold it in place while the glue dried. They seem to fit well. Thé partitions ended up not quite square, despite measuring what I thought was carefully. That’s frustrating but there’s no fixing it now. I’ll make adjustments the best I can when I glue them together
I have a piece of ebony I’ll use for the pulls. Started flattening and shaping that this afternoon. One doesn’t use a hand plane on ebony often, but on a 1/2” piece I found the smoother worked best. Better  than the low angle block planes did. Who knew...
Started setting up router bits to make crown moulding. Using a pine piece to test a couple arrangements. That’ll be the next challenge, amongst others. Starting to feel like I’m back in the shop groove again. I want to see this project done :)
  • 3 weeks later...
So before the end of May I finally got around to trying out some router combinations for the crown moulding. I did at least a dozen, no, I think more than that, bit changes/setups in order to get a profile that I like. It's close to the one in the plan but then again, this is MY project so the plan doesn't have to be followed exactly in every way. That said, it was still a PITA to get what looks like the right profile. So... I managed to do it with two router bits and some judicious hand planing, and I think I have what will be a good setup. My test pieces were in pine, and I haven't cut the piece of thick sapele yet to make the actual piece, but it took a fair chunk of my afternoon to get to this point and after that I had other things I had to take care of.
The picture shows three bits but after consideration take the small one out of the equation and that's what I'll use. OK there are five bits, ignore the ones on the top of the pic. The profile in the lower right corner is what matches.
Hard to believe it took about three hours to get to that point but I'm not the cleverest woodworker in the bunch :)
Looks great to me @Chip Sawdust, sometimes it just takes a while to get things the way you want them, but not wasted time IMO, you learned something and shop time is always good.
Nah, it takes me that long to gimp out to the shop 126' from the house.
OK that's the silver lining so I'll take it. No shop time is BAD shop time :)
  • 26,009 Total Members
  • Joseph b Newest Member ·
