Popular Post gee-dub Posted November 20, 2023 Popular Post Report Posted November 20, 2023 There is a near-floor-to-ceiling linen cupboard at the end of a hallway. This is situated so that you see it if you look down the hall when entering the house, walk down the hall to the bathroom or to go to a guestroom . . . in general it is in-your-face. It is not bad per se; it's just that it screams 35 year old contractor grade built-in. Working with LOML as design consultant "we" are wanting something more like this. We talked about various materials and styles. I even made a run to the lumber yard. If they would have had some red birch or red alder that was wide enough I would have gone with it. Alas, it was not to be. SWMBO says it shall be sepele. Ever since I built her a buffet out of sepele she has been hooked on the stuff. I pull some stock out of the racks. I use my "chop saw" to break down a thick plank that will supply all the floating panels. I like to take pieces from the same board (or boards from a flitch). This makes figure and color matching much easier. These get the usual face joint, plane faces parallel, edge joint routine. We all have a feel for what material we free hand at the bandsaw and what material we employ some handling aids to process. The board size is right on the line of what I like to muscle through a resawing so I add some feather boards and an outfeed. I rip 1/2" off the blanks. I use the jointed face of the remainder of each blank to re-plane the faces parallel. I then adjust the feather boards and saw another 1/2" off the remainders. These blanks get set aside to get comfy while I work on some frame stock. I will mill them to final size in a day or two. 6 Quote
Chet Posted November 21, 2023 Report Posted November 21, 2023 On 11/20/2023 at 3:46 PM, gee-dub said: SWMBO says it shall be sepele. Ever since I built her a buffet out of sepele she has been hooked on the stuff. I have to stand with her on this, I used it on my Morris chair and it has been pretty high on my list from that time on. 1 Quote
Popular Post gee-dub Posted November 21, 2023 Author Popular Post Report Posted November 21, 2023 My "cutoff saw" comes into play again. That was a close one . . . . My original design was going to use typical rail and style joinery. Given the scale of the doors and the weight (not bad at around 14 pounds) I decided to go with bridle joints at the corners. This makes all my horizontals nearly 5" longer than I originally marked out Parts is parts . . . joint and plane, joint and plane . . . Here's all the blanks at approximate size with parallel faces. Time for a lunch break. 3 Quote
pkinneb Posted November 22, 2023 Report Posted November 22, 2023 I need to switch my jigsaw to a cordless model that would make it so much more user friendly for breaking down stock. I typically find another way as apposed to pulling it and a cord out. Quote
gee-dub Posted November 22, 2023 Author Report Posted November 22, 2023 On 11/21/2023 at 4:31 PM, pkinneb said: I need to switch my jigsaw to a cordless model that would make it so much more user friendly for breaking down stock. I typically find another way as apposed to pulling it and a cord out. Agreed. If you’re already established on a battery system, just keep an eye out for a black Friday sale on that brand. That’s how I ended up with the one I have, it was some sort of buy the batteries and charger and get a free tool or something like that. Since I have a variety of other, Ridgid tools that made sense for me. I have a corded Bosch barrel grip that I use when I need an accurate jigsaw, so I wasn’t really worried about the cordless one as it would be just for rough work like this. 1 Quote
wtnhighlander Posted November 22, 2023 Report Posted November 22, 2023 3 hours ago, gee-dub said: ...This makes all my horizontals nearly 5" longer than I originally marked out It hurts a little with more costly species, but I've developed the habit of making the initial rough cut to a bit larger than the maximum possible dimension for each part, for exactly this reason. Plus,it eliminates a lot of math.... Quote
Chet Posted November 22, 2023 Report Posted November 22, 2023 On 11/21/2023 at 4:31 PM, pkinneb said: I need to switch my jigsaw to a cordless model that would make it so much more user friendly for breaking down stock. I don't know what battery family you have but the Milwaukee M-18 cordless jigsaw is a beast at breaking stock down. Fast and lots of power, even with 8/4 stock. 1 1 Quote
Popular Post gee-dub Posted November 22, 2023 Author Popular Post Report Posted November 22, 2023 When I am milling parts to final thickness that require more joinery later I make a spare or, in the event of large parts, mill some scrap to the same dimension. I use these for joinery setups. My first guess was pretty close but, the closer I get the machine work the less follow up work I have to do. The length of these parts and the depth of the cut are about at the limit of the dimensions I would use the tenon jig for. Much larger and I would do them horizontally at the bandsaw. Something about the nature of this operation was rooster-tailing a lot of spoil out the back of the backup block despite running the DC. Probably the opening made by the first cut is the path of least resistance for the spoil of the second cut. I keep a couple of tube socks filled with marbles in the shop as soft weights. This is a good job for them. A bit of sheet magnet and a 1-2-3 block with a magnet make enough of a corral for the shop vac to gather the spoil. There we go. I was just told that as opposed to going somewhere for turkey day, we are hosting(???). At any rate I will take a break and help LOML get the back yard ready. 3 Quote
pkinneb Posted November 23, 2023 Report Posted November 23, 2023 On 11/22/2023 at 12:07 PM, gee-dub said: When I am milling parts to final thickness that require more joinery later I make a spare... Great advice!! I usually do but on my current project did not and then proceeded to bugger up a piece 30 minutes later I had a new piece ready to go would have been much quicker to make a spare while I was milling the originals. I did an extra leg not sure why I skipped the extra stretcher. 1 Quote
Popular Post gee-dub Posted November 23, 2023 Author Popular Post Report Posted November 23, 2023 Tried to squeeze a little effort in this morning before guests arrive. The male part of the bridle joint is just the opposite of the mating cut. There's a bunch. I think one of the reasons I like the bridle joint other than the strength is it is self squaring. I also like the play between the edge and end grain. 4 Quote
Popular Post gee-dub Posted November 25, 2023 Author Popular Post Report Posted November 25, 2023 I'm at that phase where I think I do a lot but not much shows . A couple of 1-2-3 blocks make layout lines a snap. Again, not for every job but when you need to cut 40 mortises in a lot of similar parts . . . Test fit. Tomorrow I will profile the panels, groove and profile the frame and see how things look. 5 Quote
Chet Posted November 25, 2023 Report Posted November 25, 2023 On 11/24/2023 at 4:52 PM, gee-dub said: groove and profile the frame and see how things look. I really like the design so far. Your wife has good taste when it comes to design and wood selection and it seems she selected a good husband that can execute her ideas well. 1 Quote
Popular Post gee-dub Posted November 27, 2023 Author Popular Post Report Posted November 27, 2023 Thanks all. Have you ever noticed how you don't seem to get as much done in a day as you thought you were going to? I'm glad I didn't put the Domino table away yet. As I was laying out for the frame grooves I realized I had missed the side mortises in a batch of parts. Once that was resolved I marked the mortise positions. I don't want the groove to go right through the mortise area. I want to stop and start the groove leaving a shoulder for more long grain glue surface for the tenons. I stop and do a dry fit now and then to make sure I don't wander off. I really thought I would get more done today . . . *** sigh *** 5 Quote
Coop Posted November 27, 2023 Report Posted November 27, 2023 want to stop and start the groove leaving a shoulder for more long grain glue surface for the tenons. Good thinking. I’m working on a similar built project now where I cut the groove on the ts all the way across for simplicity’s sake and wish now, I had left shoulder room like you did. Every little bit of glue contact surface helps. 2 Quote
curlyoak Posted November 29, 2023 Report Posted November 29, 2023 On 11/22/2023 at 1:07 PM, gee-dub said: When I am milling parts to final thickness that require more joinery later I make a spare or, in the event of large parts, mill some scrap to the same dimension I do the same thing. But sometimes I use up the spare and need more, So I find a scrap and mill 3 sides including one face. Then if it is not too wide, I rip on edge for an oversized thickness, I then take it to the thickness planer which is already set for thickness from planing the previous boards. It takes one pass. 1 Quote
Popular Post gee-dub Posted November 29, 2023 Author Popular Post Report Posted November 29, 2023 Thanks guys. I clamp up a frame so I can profile the edges that face the panels. I want the profiles to stop at the corners. The router bit bearing automagically makes this happen. I will use a portion of this 1/8" round over. For the panels I use an 1/8" round over that I ground the bearing mount post off of. This lets the bit fit under the rabbet. The fence controls the position of the material. I use a dimensioned piece of scrap as a backer. It has to fit under the rabbet to support the raised panel portion during the cutter's exit. Here's a before and after on some setup scraps. Here's the dry assembled frame and panels with both profiles complete. I rigged up this doo-whopper to hold the southern door ajar. We have a near-constant breeze and sometimes hellacious gusts in the fall so I have the means to hold doors open, closed, and in between. If I open anything else, like the attic trap, I get a good air flow. There's a full length ridge vent on the roof. With some decent ventilation and my PPE I put a pre-assembly finish on the door panels. This prevents any peek-a-boo unfinished wood showing during seasonal changes. 4 Quote
Ron Swanson Jr. Posted November 29, 2023 Report Posted November 29, 2023 You're meticulous methods are always inspiring. Thank you for sharing your work! 2 Quote
Popular Post gee-dub Posted November 29, 2023 Author Popular Post Report Posted November 29, 2023 I forgot to mention. I use these antiperspirant lids as non-pointy "pyramids". They're great for smaller items. 3 1 Quote
pkinneb Posted November 30, 2023 Report Posted November 30, 2023 @gee-dub this is a great tip I saw you do this a while back and started saving mine I thing they work better then the commercial ones I had much less tippy. Quote
Popular Post gee-dub Posted December 1, 2023 Author Popular Post Report Posted December 1, 2023 Once upon a time I mixed up the carefully book-matched panels in a piece and didn't notice till the glue was dry. Since then I check, double-check, and triple- check my layouts. I have a batch of spacers for such tasks, even so I had to make a couple more to have enough for these doors. Two pieces of old gift card and two layers of tape. There are a lot of moving parts in these doors so the clamping starts to look like the proverbial porcupine. I clamp them for about an hour and then set them on a flat surface. Last one is in the clamps. I'll confirm the fit and drill for hinges tomorrow. 4 Quote
Coop Posted December 1, 2023 Report Posted December 1, 2023 On 11/22/2023 at 8:31 AM, Chet said: I don't know what battery family you have but the Milwaukee M-18 cordless jigsaw is a beast at breaking stock down. Fast and lots of power, even with 8/4 stock. And the Bosch Progressor blades that you turned me onto, compliment the saw nicely. 1 Quote
Mark J Posted December 1, 2023 Report Posted December 1, 2023 I always marvel at how quickly you, and other skilled woodworkers here, can complete a project like this. 2 Quote
gee-dub Posted December 1, 2023 Author Report Posted December 1, 2023 @Mark J Thanks. I'm sometimes surprised myself. It definitely helps to be retired and enthusiastic. When I was working things would take many, many times longer . 1 Quote
Popular Post gee-dub Posted December 2, 2023 Author Popular Post Report Posted December 2, 2023 I usually clean up bridle joints with a block plane but decided to give the edge sander a go on these. I watched a demo on this jig and they were having a special price plus, free returns if you weren't satisfied. I think the regular price is only about $60 anyway. It has a built-in De-Sta-Co style clamp that works well. The drill guide goes on and off easily. However, the drill guide insert for the hinge screws does not align with any of the Blum hinges or Blum-like hinges that I have(???). Not a big deal for me as being able to bring the 35mm drill to the work on larger pieces is what I was after. On smaller doors I just use the drill press and fence. These doors are just big enough to be awkward. Another negative is that the shank on the 35mm drill bit seems proprietary. The documentation states that you should use their bit and it seems they've made it better if you do. That being said the drill bit will probably last way long enough to make the low price of the jig worthwhile. The dust collection is near perfect. So, setup the jig, do 12 holes, and clean up in a very short time . . . I'm OK with it. I only got one of the doors finish sanded when I ran out of gas. There's always tomorrow. 5 Quote
