rodger. Posted December 11, 2016 Report Posted December 11, 2016 I have a collection of 4 regularly used blades. I use a Freud industrial 24" FTG blade for all my rip cuts, and a Freud Diablo 50 tooth GP for crosscuts and plywood cuts. I have the stock Festool Blade in my Kapex. I also have an 8" Freud Dado Stack. My setup seems to work well, especially the 24 T ripper and Festool stock blade. I use a sled for cutting framing for art/photos, and the cut smoothness is what I would call "very good". I get some small chipout from time to time on my pieces, which is mega annoying. I would like to get a dedicated blade for mitre cuts on the TS to help cure my issue. Should I go with a crazy high tooth count (like 80 or 90)? What type of grind is best for miters cuts? Or am I simply expecting too much and should just stick with a sharp 50 T general purpose? Quote
Just Bob Posted December 11, 2016 Report Posted December 11, 2016 I have 3 blades for my TS, Forrest WW1 60 tooth for ply and crosscut/sled, absolutely no tear out. A Forrest WW11 for general purpose and rips of 5/4 and less, another great blade. The guy that sharpens my blades talked me into a A.G.E. 24 tooth rip for thicker rips, and I highly recommend it, especially at $30.00. He also sold me on a 100 tooth A.G.E. for my 12" miter saw. Following his advice, and keeping a regular schedule for sharpening has really improved the quality of my cuts. 1 Quote
Chet Posted December 11, 2016 Report Posted December 11, 2016 39 minutes ago, Pug said: Looking at this one: I have the 10 inch and 12 inch version of this blade Pug and I have been real happy with it. When it shows any sign of tear out I get it sharpened. 1 Quote
gee-dub Posted December 11, 2016 Report Posted December 11, 2016 50 tooth is still in the general purpose category for me. My GP blade is a 50 tooth with a triple chip grind raker. I also have a 50 tooth plywood blade with a high ATB grind. For crosscutting I have a 60 tooth for quick work and 80 tooth for finish work. Quote
bleedinblue Posted December 12, 2016 Report Posted December 12, 2016 I know I'm not to the experience level of most of you guys, but I can't stand the thought of a dedicated rip and a dedicated cross cut blade. A quality 40/50 tooth combo blade and change blades only for a dado stack. I've got a 40 tooth Freud combo in now and never see any tear out in solid wood, rip or cross. Quote
rodger. Posted December 12, 2016 Author Report Posted December 12, 2016 2 minutes ago, bleedinblue said: I know I'm not to the experience level of most of you guys, but I can't stand the thought of a dedicated rip and a dedicated cross cut blade. A quality 40/50 tooth combo blade and change blades only for a dado stack. I've got a 40 tooth Freud combo in now and never see any tear out in solid wood, rip or cross. I used to be that way, until I realized how much better dedicated blades are. I often change the blade 3 times (or more) during a single project. Well worth the 60 seconds to swap out. 1 Quote
Chet Posted December 12, 2016 Report Posted December 12, 2016 11 minutes ago, bleedinblue said: but I can't stand the thought of a dedicated rip and a dedicated cross cut blade I think about the Forrest Woodworker II off and on but I keep staying with my dedicated blades. I am getting where my rip blade is on the table saw 90% of the time since I bought my 12 inch Bosch Glide. I am extremely happy with the accuracy of the cross cuts I get on the glide that the only time I swap out blades on my table saw is when I am using the sled. Quote
pkinneb Posted December 12, 2016 Report Posted December 12, 2016 37 minutes ago, Pug said: I used to be that way, until I realized how much better dedicated blades are. I often change the blade 3 times (or more) during a single project. Well worth the 60 seconds to swap out. I agree. Freud glue line rip and dedicated crosscut blades worth the time it takes to change them in my opinion Quote
wdwerker Posted December 12, 2016 Report Posted December 12, 2016 The Freud glue line rip rocks ! Clean the blade at the first sign of resin building up and it will go so much longer between sharpenings. 1 Quote
Chet Posted December 12, 2016 Report Posted December 12, 2016 25 minutes ago, pkinneb said: I agree. Freud glue line rip 2 minutes ago, wdwerker said: The Freud glue line rip rocks Yep, this is the one I have. I have had it for about three years now and like Steve said, it rocks. Quote
gee-dub Posted December 12, 2016 Report Posted December 12, 2016 10 hours ago, wdwerker said: The Freud glue line rip rocks ! Clean the blade at the first sign of resin building up and it will go so much longer between sharpenings. Glad that was brought up. Keeping your cutters clean is like stealing money from the sharpening shop. Dedicated blades also extend your cutter's service time between sharpening. The blade in use has the tooth count and geometry for the job at hand. Quote
knotscott Posted December 12, 2016 Report Posted December 12, 2016 The lowest tear out possible will come from a high tooth count blade with a Hi-ATB grind. Precision manufacturer's I'd look to are Infinity, Forrest, Freud, CMT, Amana Tool, Ridge Carbide, to name a few. Full kerf should offer the best stability, Quote
Alan G Posted December 12, 2016 Report Posted December 12, 2016 I have a few Ridge Carbide blades and they are excellent. I also run a WWII and have the Freud 80T hiATB. For the quality and price Ridge carbide is hard to beat. They are all great blades. Quote
AJ_Engineer Posted December 12, 2016 Report Posted December 12, 2016 So as a minor hijack to the thread, what do folks use for cleaning their saw blades? Quote
shaneymack Posted December 12, 2016 Report Posted December 12, 2016 38 minutes ago, AJ_Engineer said: So as a minor hijack to the thread, what do folks use for cleaning their saw blades? http://www.leevalley.com/en/wood/page.aspx?p=30062&cat=1,41080,41165,30062 1 Quote
gee-dub Posted December 12, 2016 Report Posted December 12, 2016 Save your money. The yellow L.A. Awesome spray cleaner from the dollar store works great and lasts a long time. I clean frequently and am only on my second bottle. Hard to beat a buck per year and proven safe for brazing in independent testing. http://i.walmartimages.com/i/p/00/72/24/29/32/0072242932010_500X500.jpg Quote
bleedinblue Posted December 12, 2016 Report Posted December 12, 2016 Fair enough. One day I might try a 24T ripping blade. As far as speed if blade changes, it's actually kind of a pain in my newer Grizzly. The arbor bolt literally doesn't give much wiggle room, so the blade tends to get stuck easily. Quote
xxdabroxx Posted December 12, 2016 Report Posted December 12, 2016 37 minutes ago, bleedinblue said: Fair enough. One day I might try a 24T ripping blade. As far as speed if blade changes, it's actually kind of a pain in my newer Grizzly. The arbor bolt literally doesn't give much wiggle room, so the blade tends to get stuck easily. Mine fits pretty tight too, the bigger issue for me is when I drop the stinking nut into the pile of sawdust in the bottom of the cabinet. (no chip collection) 1 Quote
wtnhighlander Posted December 13, 2016 Report Posted December 13, 2016 So as a minor hijack to the thread, what do folks use for cleaning their saw blades? Hot water and a few drops of dishwashing detergent. Or just run it through the dishwasher. Quote
rodger. Posted December 13, 2016 Author Report Posted December 13, 2016 i use freud blade and bit cleaner - works great. Quote
knotscott Posted December 13, 2016 Report Posted December 13, 2016 13 hours ago, xxdabroxx said: ...the bigger issue for me is when I drop the stinking nut into the pile of sawdust in the bottom of the cabinet. (no chip collection) Get one of those telescoping rare earth magnets for a couple bucks....they work great for that application! 2 Quote
Elroy Skimms Posted December 13, 2016 Report Posted December 13, 2016 17 hours ago, xxdabroxx said: Mine fits pretty tight too, the bigger issue for me is when I drop the stinking nut into the pile of sawdust in the bottom of the cabinet. Glad to hear I'm not the only one. 3 hours ago, knotscott said: Get one of those telescoping rare earth magnets for a couple bucks....they work great for that application! You, sir (or madam), are a genius. Harbor Freight, here I come! -E 1 Quote
