Gwizzer Posted December 28, 2017 Report Posted December 28, 2017 Hi all, I’m looking for a drillpress that doesn’t come with preloaded runout. I recently bought a Jet 17” floor model and returned because the runout was so bad it vibrated the piece I was drilling out of my hands. Was very disappointed and it left me wondering how much money do I have to spend for a good drill press… I’m replacing an old Delta that was perfect until it was moved (and dropped) and parts were obsolete. Thanks Quote
RichardA Posted December 28, 2017 Report Posted December 28, 2017 I've had a couple of "new" drill presses over my life time. Each one had a little runout. But taking the chuck off, cleaning with Mineral spirits and putting it back on usually fixed the problem. I guess there are some that just won't work on, but if you do get another one, give that a try if it's only minor runout. 1 Quote
gee-dub Posted December 28, 2017 Report Posted December 28, 2017 This has been a near-endless quest over the last decade. Apparently it is harder to make a drill press today than it was 50 or 60 years ago. I have yet to upgrade my mediocre Delta 17" as the improvements of drill presses at the $1500 tier are not enough better to get me to move. After returning the big dog Powermatic for a variety of flaws I have been patiently waiting. I have put my hands on the latest Powermatic offering at different stores but, two had many of the failings of their predecessor and one was good. The Nova's have been pretty consistent but, the 15" swing has held me off. Two different floor models of the new Jet seemed "good" but, this may have been the luck of the draw. I have been leaning that direction. Was the Jet the older model format or the new JET JDP-17? I should qualify "good". The things that make a machine a no-go as an upgrade are run-out and quill slop. Chucks can be changed so don't judge a machine by a poor chuck. If I extend the quill a few inches and can get a definite "clunk" when moving the quill side to side I move on. Quote
wtnhighlander Posted December 28, 2017 Report Posted December 28, 2017 Oddly enough, I just bought a super cheap Porter Cable 10" bench top drill press, that has no detectable runout, at least no vibration I can feel. I didn't put a dial indicator on it. Probably not what you are looking for, but an interesting observation, none the less. Quote
Cheeset202 Posted December 28, 2017 Report Posted December 28, 2017 Many times the runout is a result of the chuck not seated properly on the morse taper. I had this problem on my powermatic 2800 drill press. I removed the morse taper and chuck, cleaned thoroughly with mineral spirits, installed taper in the quill, checked runout, virtually none, then installed chuck giving it a good hit with the dead blow, checked runout, maybe 0.002 - 0.003. Before doing this I was in the 0.010"+ runout range. The key is getting the chuck seated properly on the morse taper. 1 Quote
Gwizzer Posted December 28, 2017 Author Report Posted December 28, 2017 It was the JDP-17. I tied resetting chuck and Morse taper many time. It had 3 thousandths at the main before I even inserted taper. Was on phone with tech twice. My local store said they usually don’t see runout with that press, and it must have been bad one...but they only offered to swap it out for a floor model. The runout on that one was less, but not as smooth as I thought it should be so I passed. I’ll keep looking. Quote
Cliff Posted December 28, 2017 Report Posted December 28, 2017 I got the same drill press as @wtnhighlander and a pretty happy with it. On the other hand I don't even know what runout is. Quote
Marmotjr Posted December 29, 2017 Report Posted December 29, 2017 That new computerized Nova has me quite interested... if ever I needed to replace my 40 year old rockwell, and had lots of cash with no use.... Quote
wdwerker Posted December 29, 2017 Report Posted December 29, 2017 That Nova caught my eye too. Maybe when I hit the lottery. 1 Quote
Minnesota Steve Posted December 29, 2017 Report Posted December 29, 2017 10 minutes ago, wdwerker said: That Nova caught my eye too. Maybe when I hit the lottery. It just hit $300 million this week. I just have a Craftsman benchtop much like that porter cable. I haven't noticed any problems with runout, but haven't really measured either. But then these smaller benchtop's only have 2" of travel, not 5" like the JDP-17 so there is that... Quote
Pondhockey Posted December 29, 2017 Report Posted December 29, 2017 4 hours ago, Cliff said: I got the same drill press as @wtnhighlander and a pretty happy with it. On the other hand I don't even know what runout is. https://en.wikipedia.org/wiki/Run-out If you allow the spinning chuck to graze your finger (pointed tangentially and in the direction of rotation) you'll feel the runout as vibration against your finger. [On reflection, use a light stick, instead of your finger. - Not going to say what I do ;-) ] Quote
Coop Posted December 29, 2017 Report Posted December 29, 2017 4 hours ago, Cliff said: On the other hand I don't even know what runout is. Where there’s no wobble. A 1/4” bit makes a 1/4” hole. But in my case, I look forward to the run out to make things get close and fit! 2 Quote
Cliff Posted December 29, 2017 Report Posted December 29, 2017 I guess I've never really needed to use the drill press in a way that I would even need it to be without wobble, though, like I said, I haven't tested it. Only thing I've used it for recently is drilling out the waste in the half blind dovetail sockets. Quote
Tom King Posted December 29, 2017 Report Posted December 29, 2017 The only one I want, in addition to my two, old Powermatic 1150's, is one of these (currently on sale at $200 off-but the drill chuck costs an extra $175.00): http://www.trick-tools.com/Ellis_9400_Floor_Model_Drill_Press_9400_256 Quote
ClassAct Posted December 29, 2017 Report Posted December 29, 2017 It also doubles as a great bread mixer if you get the dough hook. 1 Quote
wdwerker Posted December 29, 2017 Report Posted December 29, 2017 That's a beast of a drill press ! None of my tools cost that much. But if your a machinist or working on farm equipment it make sense. Used ones probably scarcer than hens teeth. Quote
