Wood for a Spa shelf
I'm constantly irritated by my beer being knocked off of the side of the jacuzzi do have decided to add a small shelf to two sides simply mounted to corbels.
This be in the sun all the time and direct water contact.
What do you guys think as far as lumber? I'd rather not put a thick coat of anything that will look like plastic as the sides are a flat finish stain.
Thinking real teak, mahogany... Looking for input.
Ipe will last forever & you'll just need to reapply an oil finish every year or so. It is quite beautiful.
I did a shower stool in Ipe and it's holding up well so far after 3 months of use. I like the look of it and the cost was quite nice as well. Only down side is the stuff stinks something nasty.
10 minutes ago, Immortan D said:
That wood looks really easy to carve.
those woods above will work and so will western red cedar also cypress does well in the weather. No sap on the cypress...I think the key to making the wood last is that all the water drains off. If it stands for a long time on the wood could be trouble. Maybe a drill hole to drain water if necessary?
43 minutes ago, Brendon_t said:
My dealer only has ipe in 1x6 decking. Is that about standard?
Maybe, I've been able to purchase it in the rough but i know it's used for decking a lot.
Brendon, what size piece(s) do you need. I have some smallish stuff in teak that I salvaged off of a sailboat that probably looks as good now as when they built it. It’s yours for the asking.
I built my table to hold my Big Green Egg out of teak 22 years ago. Just let it weather to a nice gray. I'm sure teak would last as a spa shelf longer than the spa itself.
Probably depends on how much activity goes on in the spa. But you’re right, spas are like workout machines and boats, usually short lived.
Looks like ipe is going to be it. At 3 a linear foot, I can't complained when teak is 27 a board foot.
Thanks but probably bigger than was salvaged. Going to run the shelf the whole 96" on one side and  at least half the other.
Just be aware the Ipe can be a bit of a challenge to work with. I've never used wood as hard as it. And wear a mask.
Do wear a mask. I found that it wasn't difficult to work at all. It isn't Wenge.
Well, I've not worked much Wenge, but it wasn't near as hard as Ipe. I just looked up the hardness; Wenge is around 1630 Janka to Ipe at 3500. Ipe is almost as splintery as Wenge too.
Really! Wow i must have gotten some nice Ipe, i didn't really notice much of a difference between it and hard maple or Hickory.
There are other similar looking tropical hardwoods that are often passed off as Ipe, but are not.
Or it's Ipe and natural materials vary a lot tree to tree and board to board.
Thanks for the input and yes, I'll be sure to have the good respirator on. God knows I smoke enough, I don't need all that imported wood toxin too.
Everything over 3000lbs janka will be splintery, fibers are stronger than the bond between them. But if you can get cumaru/almendro (often sold for decking/flooring as well), it's a little less splintery than ipe.
