Quick curing outdoor finish for my wedding reception tables? Time is a factor :D
Hi folks - I've built eight tables for my wedding reception that's coming up 16 June, and wanted to see if I should take a different approach to their finish than what I currently have in mind. I obviously have some time constraints given the date is looming closer by the moment so multi-day coating and surfacing programs are not going to work. Long story short, I am loading these tables into a trailer 10 June and driving them up to Pender Island in British Columbia the next day, so ideally I would like to complete the finish application tomorrow (8 June), let the tables cure for two days, and be finished with them so I can focus on my many other wedding tasks.
I plan to employ the finish that Izzy Swan describes here (70% teak oil, 30% helmspar urethane). The table tops are made out of doug fir and knotty pine veneered cabinet grade plywood, thickened up with shop-grade birch ply beneath, and edge-banded in solid VG doug fir. Three of the bases are trestle-style made out of kiln-dried construction grade doug fir, and the remaining five are simply 2x4 sawhorses. I plan to give everything two coats following the process in Izzy's video, and am fine with the finish only lasting through the week if that's what it comes to. I plan to sell and/or give them away after the event anyway, and if they need repair or refinishing I can do that.
What do you think of this approach? Should I go in a different direction? Here they are in their unfinished glory:
With much to do in a short time I would do shellac you can reapply the finish in about an hour of dry time. For more of a amber tone like the oil would give is go with amber shellac.
If I really didn't care about the finish holding up long term out doors, I'd hit them with General Finishes WB poly (High Performance).  40 minutes between coats, block with 400 between.
@Tmize - I thought about shellac but worried about it getting gnarly sitting outside for a week before the ceremony
@wdwerker - I already have the helmspar material. Do you think coats of that thinned with mineral spirits would fit the bill? I was thinking maybe water-based poly could be an option, too.
@..Kev - I have used that before with success on indoor products. Maybe I could find some in Wenatchee, WA (where I am located). Big box options might be the only ones that make logistical sense given my constraints, though.
I really appreciate the feedback, folks!
Would shellac be a bad choice anyway for a wedding, where there is a fair chance that someone will spill alcohol at some point? I thought that would mess up the surface.
There is a greater than zero chance that this will happen. Great point! Haha. No one wants shellac gunk on their elbows.
The Helmsman will dry slower and leave a softer finish. The fast drying does just that, especially if you use thin coats.  Can you return the Helmsman ?
@wdwerker - are you referring specifically to https://www.minwax.com/wood-products/clear-protective-finishes/interior/minwax-fastdrying-polyurethane or a class of products? I can return the helmsman.
10 hours ago, RichardA said:
In the OP's title.
Total skipped over that I even reread the post just not the title. My bad I change my response to a water based poly
There exists an exterior grade WB poly GF exterior 450. You should be able to build a finish fast with that. I'd return the helmsman. I used it once and even after a week the finish was soft. I think it took near a month to get firm enough that you couldn't dent it easily.
If you need the finish to last only a week interior finishes will last that long. My old hardwod dealer had wooden racks on their company vehicles he used regular interior minwax and said it lasted 2-3 years..
Yeah only a week outside no concern with using an interior finish. Only concern would be what you are doing afterwards with the tables, because dealing with a base coat of an interior finish you would have to pick carefully any future exterior finishes.
All I can add is Congrats on the wedding and move over Vizsla!
What are you going to do with all of them after the wedding?  with the time left, I would do nothing.  I was going to suggest lacquer, epiphanes or CPES, but like I said time isn't on your side.
If CPES were available (you usually have to order it) this would work - just do the CPES before the wedding, Epiphanes after the wedding.  Otherwise I like Werker's solution.
@Woodenskye - I plan to give a couple as gifts, and hopefully sell the others. They aren’t fine furniture by any stretch but can definitely hold up a few beers.
I ended up going with Minwax Polycrilic. I did a pretty sloppy job with two coats just to get the task finished so I can move onto others. The material is fine (obviously not meant for this particular application) and I am confident it would produce decent results given appropriate preparation and careful application.
Thanks to eveyone for your feedback!
Zita the Vizsla always makes sure she has pride of place.
@Minnesota Steve @Pondhockey @Woodenskye @K Cooper @AJ_Engineer @Chestnut @Tmize @wdwerker @Wood Basher @RichardA @..Kev
Hey folks - thanks again for the advice. I just wanted to share a couple pics from our wedding reception so you could see the tables in transit and in place. I designed a bench to go with the tables (technically four benches per table), and these were built on site by my friends and I using 2x material and rough sawn cedar planks sourced on the property. Luckily my friends largely enjoyed this impromptu woodworking mini-camp. We built 32 benches in ~4 hours.IMG_3568.thumb.JPG.317b9dc1f2c02f6199e531787d2f0724.JPGIMG_0936.JPG.e703c4b631b3b1444c0baaaae1a9b3df.JPGIMG_0941.JPG.9902c2cf594dd568eb7b2a7f558eec29.JPG
Wow thanks for sharing. That looks like a wonderful place to have a wedding reception.
Any of your friends called Jay Garrick?
