Sculptured Lectern/Music Stand
6 hours ago, wdwerker said:
I hope all of your music stands end up on the same stage in front of musicians who have skills on par with your woodworking !  These all need to be signed and dated !
Thanks Steve, and yes these guys will be signed and dated!
  • Replies 59
  • Views 18.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Been a busy week with family, work, milling lumber, visiting friends....   Finally had a few minutes today to assemble my first of three music stands. I finished with 3 coats of oil/varnish and 2 coat
  • Made some progress today in the shop, many focused on the legs Each leg is made of 2 pieces joined at a 45 degree angle. The plan calls for 2 dowels but I'll use 1 domino in each. I milled and sized a
  • This project was just what I expected, a definite challenge, and I mean that in a good way. Haven't moved very quickly with this, but I am moving forward. Here's some progress; Some more shaping
Posted Images
Amazon delivered the 1" bradpt bit I needed and onward I moved with this project. Got the goosenecks cut out and 1" holes drilled in them and shaped them, which was a decent amount of rasp work. With double sided tape I adhered the spline to the back of the top piece of the lectern and got my first look at the assembled project. Since I'm going with a solid top the design of this is completely up to me and I'm enjoying that. Tweaked the top and I think I've developed a clean look. Also did some lathe work to turn the knobs that cover the 1" oak dowel that joins the gooseneck to the top.
Here are the goosenecks after bandsaw work and 1" holes drilled;
Shaping begins, used a 1/2" roundover bit for the outside of the gooseneck but it was all rasp work for inside of the necks;
Next it was on to the support spline for the top, I put it on with doublesided tape and to me my first effort looked clunky and bulky;
Here it is with my first look at the stand assembled, again the support spline looks out of place;
After some sculpting I developed a shape I liked better;
Next i shaped and worked the maple knobs that cover the ends of the 1" dowel that holds the top pieces together. At first these looked bulky to me, but again after some sculpting I like the look I was able to develop;
Moved to the top next and worked out some design details here. Here's a full view and a few details I decided on where subtle sides, rounded bottom ledge and a slight curved top profile. Another thing you'll notice in this pic is the grain match is not great. I concentrated on matching the grain on the other side of the top, that is the side that I thought was most visible. The grain in thjis view is just the way it worked out by concentrating on the opposite side.
In this pic you see the subtle side pieces fade out as your eye moves to the top edge.
Finally for the top I drove a few 1/8" brass dowels in from the bottom to add a little support to the bottom ledge;
Last thing i did for the day was glue the support spline to the top and glue the gooseneck to the support post;
Shaping and final sanding today and then the same process for the other two stands.
Thanks for looking.
Bmac you do some amazing work!! One question on the top are the sides and the bottom applied or is that all one piece?
Those pieces are actually applied. I saved the post glueup cutoffs from the top piece when I squared/sized it and used those for the bottom ledge. That is why the grain match is so consistent. The side pieces where cutoffs from the top prior to the glueup of the panel.
Nice job!! It was hard to tell, I was like dang how did he get that so even LOL
Would you be willing to give me a week long class? this is awesome work!
Thanks Drew, really enjoying this project and it has been challenging. I'm not sure how much I can teach you, sometimes I feel like I'm just figuring out. When it comes to power and hand sculpting I feel like I learn something each time in the shop. Doing the Malloof Rocker with Marc's video instruction really gave me a sound base, and I enjoyed that project so much that I keep picking new projects to build off that.
As for a week long class we should meet at Spanky's for a week, do woodworking, get some nice stock, and you bring Megan's food. In the end I'll likely learn more from you and Spanky than I could ever teach.
Bmac a week long class sounds good. But I may need more than a week on woodworking. I could use the extra help sawmilling, you and chestnut can run the mill. It’s alittle step up from a chainsaw mill.  But I think chestnut needs to chainsaw mill two logs before he can saw on a bandmill. :)
Been a busy week with family, work, milling lumber, visiting friends....   Finally had a few minutes today to assemble my first of three music stands. I finished with 3 coats of oil/varnish and 2 coats of oil/wax. Once finished I could attach the top to the main post. It's attached with a 1" dowel. The plan calls for it to be glued, but you need to be careful glue doesn't get on the part of the dowel that the top pivots on.
I used epoxy, put the dowel most of the way through, put glue in the hole one the one side and glue on the dowel on the other side.
Then pushed it through. You don't see any glue on these pics because I took the pics during my dry run.
Then I put epoxy inside the decorative knobs that attach to the 1" support dowel. I also drove 1" long 1/8" diameter  brass dowels into the 1" dowel to further secure the support dowel and as a protection against the unlikely instance the glue bond gives out between the support dowel and the support post;
Those brass dowels are basically invisible when the support post is lowered into position;
Here's the stand all finished;
Liked the way the detail ended up with the decorative dowel caps;
Top of the stand, subtle curve at the top outline, subtle side pieces and a blended bottom ledge;
Vibrant grain and color on the top. This is the part of the stand that is most visible and I was pretty satisfied with the way the grain matched up, but I was even happier with the great figure;
This stand is ready for Church tomorrow. Still working on the other two and doing some fun stuff with those stands. I made the other stands basically out of Maple and the tops will be cherry. I'm excited to see how that combination works.
Thanks for looking.
Ok those have exceeded the furniture category . You are into the functional sculpture zone . That's a music stand for someone playing a Stradivarius !   I'm  Thinking signed, dated and a serial number with the appropriate insurance appraisal.......
Bmac you should get to sit on the front row at church in the morning.
Thank you for your high praise. I will say this was the most challenging piece I've done so far. Looking forward to completely the other two I'm working on.
Man that walnut is striking with it's color and grain. I'm assuming that we'll get to see all the stands together at some point?
No worries there, my wife makes me sit in the front (second row) every Sunday anyway.
I plan to get a photo of all three when finished.
Yes, the colors in that walnut are pretty sweet. Well worth the wait with air dried wood.
Ditto the comments above.  Super nice work!
Bmac did that walnut come from a farm that had cattle running on the farm? I have seen walnut that was cut on a cattle farm that had the same colors.The mineral salt that they feed cattle will make rainbow poplar over time.
You are a man that knows your wood and knows your cows. Yes, this Walnut is from the family farm, it was in a hedgerow along a fence line of a cow pasture field.
I know the vibrant colors will fade as time goes by but I'll enjoy them while I can.
Old country boy, beef farmer, logger, sawmill guy. Makes a well rounded country boy!
Most people don’t know that about mineral salt. The limestone rocks we have here in the south will make mineral stain in some trees. I like the mineral stain in some of the lumber, but not any oak it will have black streaks in the lumber. Mineral stain a down grade on all logs to the big boys, but not to the woodworkers. I can look at the end of a log and tell you if it has mineral stain in it. So can the guys that buy the logs and they will pay you alot less for them with mineral stain.
6 hours ago, wtnhighlander said:
So now you know why such wood is popular with us poor hobby guys! :D
Ross the mineral stain wood not cheap to the woodworkers they will pay big money for it. Rainbow poplar has been the best selling lumber I have ever cut and I have cut alot of lumber.  Mineral stained walnut sells like new candy too. They are hard to find.
  • 26,009 Total Members
  • Joseph b Newest Member ·
