Stand-alone shop build
9 hours ago, Chet K. said:
Thats going to be a great space when you get it finished.  Are you planning anything for the floor like epoxy or just going with the concrete look?
I'm just going with the sealed concrete.  Don't have the patience to wait for the concrete to cure and everything to stay out of the shop.  I'm considering a drive up to Tractor Supply for some of their rubber "horse stall" mats - those have had good reviews from folks.
  • Replies 230
  • Views 49k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Got a first coat of the main color on today - that rough pine really sucks up the stain...  went through 5 gallons and didn't quite finish.  I really see the appeal of those pre-painted steel pole bar
  • davestanton
    davestanton
    Man do I feel humbled! You know, I make these videos and I see the figures but to actually see an image of Barry and me on someone else's screen on the other side of the planet....I'm speechless!
  • Hey Mike!  Sounds like a smart inspector - for me it's a 46" TV and still feels too small! The interior's mostly done - you'll see it in the background of a few of these photos. I've had a b
Posted Images
The only big drawback to horse stall mats is the smell. It takes weeks for the fairly strong rubber odor to dissipate. They are fairly cheap and cover a decent amount of space. They aren't very cushioned but that lets you roll carts over them without sinking in. They stay put wherever you put them, the thinner mats slide around pretty easily.
And, they are easy as hell to trip over, don't ask how I know!
Matt, if I can come work in your shop, I'll keep it spotless for Ya and I can sleep outside, in a tent, and promise to stay out of your way?. Great looking place you've got there dude!
C'mon up, Coop!  Not too far outside NYC, we can have some fun nights out on the town!
Solid surface mats are great for most areas of the shop however at my sliding miter saw the dust collection is not that great and the floor gets dust on it and it gets slippery.  To solve that problem I purchased a Grease Resistant 36 in. x 60 in. Commercial Rubber Drain Mat from my local Home Depot.  The sawdust falls through the mat and it's very easy to vacuum it up from time to time.
Tools are starting to move in!  It looks like a shop!
Finished the lumber rack and stocked it up, some of the space is taken up by the pine trim for the shop, so I haven't moved all the hardwood out of the garage yet, unfortunately.
We had friends over last night and I convinced the 3 guys to help me move the jointer/planer out to the shop.  It's been in the garage since June.  When it arrived, I jacked it up and screwed some heavy duty metal casters to the bottom.  We got it about 8 feet out of the garage and it sunk into the gravel driveway.  Sucker weighs something like 1100 lbs!  We ended up using 2 sheets of plywood so it had something to roll on.
Today I was able to remove the wheels, take the crate apart and get it down off the pallet onto the ground by myself.  I've done lots of stupid things, this is up there.  I did it, but it was dicey there for a moment!
They sent me the wrong mobility kit, so no wheels yet.  I also got the table extension, so I can extend the infeed table 80cm.
Conversion from jointer to planer seems pretty simple, I'll know more when I get deep into a project.
I moved a few more tools over today, using the plywood trick again.  Looks like the saddest parade ever.
Tonight I started assembling the table saw.  I nearly cried when I saw the cast iron top of the saw:
I've had some problems with tools rusting in the garage this winter - I think it's humidity and then cold weather drops all the moisture onto tools - my handplane have needed some attention.
Luckily I'm stupid, and it was the rust preventing paper that was wrapped around the top of the table saw.  Same stuff was on the jointer/planer, so I shoulda recognized it... well, it's been a long weekend and I'm tired and dumb.  To be clear, I'm always dumb, the long weekend doesn't really contribute to that.
I finished getting the mobility base installed - tomorrow will be focused on getting the table saw finished and probably working on the router table.
Things are looking awesome have fun setting all those tools up and deciding on where they should sit.
Coming along!  The top will clean up, just a little more work..
Wow a hammer a3 41! That's quite the beast. What made you go with a combo machine with all that space you have there?
Looking forward to your thoughts on the A3. I'm looking at the same unit.
Nice shop! I know you're happy!
I wanted wide jointing capacity because I get some decently wide boards and I hate ripping them so I can joint them... and wide jointers are either stupidly expensive or you have to find some old thing, refurbish it, get 3-phase...  and I'm not going to do that.
So I'm already into stupid money territory, I thought maybe I can save a bit by using the same cutting head for planing.  And you get the added benefit of saving floor space.
Worst case, if the change-over is just a huge PITA, I'll dedicate the J/P to jointing and get a dedicated planer.  I doubt this'll happen, but I'll have that option.
Happy to share my thoughts when I get wood moving through the tool.  Comparison will be a 6" Jet that I added a Byrd head to and a snipe-y Ridgid 2 blade planer that I bought by turning amex points into home depot gift cards.  So not like I can compare it to a Powermatic jointer or planer, but I'll share my thoughts.
So far, the instructions are awful.  They either give you a diagram of how it looks when it's all finished, or they give you a ridiculous exploded diagram.  And there's very little in the way of English assembly instructions - most frustrating is all the part lists and descriptions are in German, so there's a lot of googling to translate.  Assembling the table extension, I'm looking at this tiny 1 1/2" square image trying to figure out where the thin nut, the thick nut, and the lock nut each go and then how that assembly connects to the extension table.
I installed and removed the aluminum rails 2-3 times each because it's almost impossible to understand how it goes together the first time ( these are for the extended table and the fence support to ride on)...
They did send me some videos of Harry the Austrian Tool Expert putting the thing together - that wasn't much help except to notice they send me the wrong mobility kit.
(ok, now I'm getting close to venting territory, I'm going to sleep on it and wrestle the Austrian behemoth in the morning)
Me too!  I am nowhere close to being able to buy one, but I really like the idea of the combo machine and this one looks awesome.  Looking forward to your review.  Bummer on the German instructions, sounds like a nightmare. Scheize!
Is this the same guy from this vid?
Actually a pretty cool video (nothing to do with jointer/planers).  The dude's accent always makes me smile
Yeah, the intro guy, not the male model woodworker.  I love that video - I had the N4400 and the FB510 on my short list before I ordered the PM1500.
7 hours ago, Llama said:
I like that guy :)  Has a nice rhythm.
Yeah, I think his enthusiasm is infectious - he gets so excited about the tools!  And he has great plaid shirts!
Lots of machine assembly at the beginning of April: jointer/planer, table saw, bandsaw, drill press, router table, and clearvue dust collector.  I was missing the hardware kit for the DC and I wasn't sure if I misplaced it or they didn't send it - but they were awesome about it and sent it out that day without even asking a question.  I then got a few more steps into the assembly and noticed the curved plastic bits for the transition to the filters were missing - and again, Cathy from Clearvue popped 'em in the FedEx box right away.  I can't say enough about how well they treated me.
I also got the workbench and the lathe moved over.  I had to add the wheel kit to my lathe (a Robust Sweet 16) before moving it - that was my first experience tapping a threaded hole - I was pretty worried about it but it turned out ok and I'm glad to have it in its new home.
I've had some problems with rust in the garage this winter and I'm glad I have the stainless ways on the lathe, but I've had a bit of trouble with rust on the non-stainless parts on the lathe.  I sent in photos to Robust and got a reply from the founder, Brent English, who suggested some WD-40 and scotchbrite - so that'll be a project for later this week.  Another company with great customer service.
After a week of camping with the kids in a RV for Spring Break, I'm glad to be back in the shop!
The focus is currently the ductwork for the dust collection.  I went with Nordfab - mostly because I've never had a shop this big and I'm pretty sure I'm setting it up all wrong and will want to move everything around.  This stuff is expensive but a dream to work with.  Here's a view of what I was able to finish in about 4 hours today:
And here's a little trick I mentioned on the wood whisperer guild group on facebook... I got one of those hydraulic carts from Grizzly (HF also sells them, I'm told) and it's been a life saver in getting the shop set-up, especially with tool assembly (like getting the wings on the table saw).  Today I stacked a whole buncha systainers on it and used it to support the ductwork while I made connections and strapped it to the wall or ceiling:
Going across the shop I used screw in J-hooks, 3/16" wire cable, and wire cable clamps to hold the ductwork up (please ignore the spot we forgot to paint above the garage door) - I'm really happy with how that worked out.
I think I'm going to need a few more pieces for the dust collection - most importantly I have to figure out how I want to connect the DC to the ducting (see below).  I think you want 5' of straight run before the DC - so I'm trying to figure out the best way to make the transition here.  I wasn't sure how this was all going to play out when I worked with the design service, so it's something I've gotta figure out now - thoughts welcome!
I enjoy this build it always seems like the gift that keeps on giving. I hope that it ends someday and your get to start making things in your awesome shop.
I cannot wait to be building things - I never expected it to take this long!
And people say festool is expensive? Look how multi functional it is! =)
Shop is looking awesome Matt! What is in the black systainers?
Supercool secret stuff, man!  I can't believe you're not in the black systainer club yet!
Ok actually just a few woodpecker one time tools - accessories for the domino and the track saw.  I'm a sucker for red aluminum like you are for neon green ;-)
the tracksaw parallel guide system is ok, I don't usually need that much precision on the track saw so isn't as useful as I thought it might be.  I haven't had a chance to use the domino offset jig yet.  This is where I'm just a sucker for manufactured scarcity.  Admitting it is the first step, right?
That's one expensive pipe jack!
Nice work!
Haha nice ! What is the domino offset jig? Like the seneca adapters?
  • 26,009 Total Members
  • Joseph b Newest Member ·
