Stand-alone shop build
  • Replies 230
  • Views 49k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Got a first coat of the main color on today - that rough pine really sucks up the stain...  went through 5 gallons and didn't quite finish.  I really see the appeal of those pre-painted steel pole bar
  • davestanton
    davestanton
    Man do I feel humbled! You know, I make these videos and I see the figures but to actually see an image of Barry and me on someone else's screen on the other side of the planet....I'm speechless!
  • Hey Mike!  Sounds like a smart inspector - for me it's a 46" TV and still feels too small! The interior's mostly done - you'll see it in the background of a few of these photos. I've had a b
Posted Images
2 hours ago, Chestnut said:
I really like the thought of a weathered grey stain on the plywood below the gray Sheetrock it might look really neat could try doing some small pieces next to each other.
We just picked up some grey stain and some pickled/white-wash stain that we're going to test on the pine and the birch ply.  My wife likes the idea of the white wash...  will test and share the results soon!
2 hours ago, drzaius said:
Insulation & drywall are good things to not do yourself. Looks good.
Are you building a separate room to house the compressor & dust collector?
Compressor is just going to sit in the corner - it's the Husky 33 gallon compressor.
Dust collector is going to hang on the wall - I'm going to see if I have room to close it in once it's up - I think it's going to be a tight fit.
1 hour ago, Marcel.F said:
You might have mentioned it in an earlier post. But I'll ask anyways. What are you using to heat the shop? Forced air, radiant tubs, Reznor unit heater, infloor hydronics? Or it's still up in the air.
as Steve said, it's a mini split for heating and air conditioning.  I went with one with "hyper heat" that can continue heating down to something like -13F.
Drywall is finished and the first coat of joint compound is on the walls.  I'm getting a much better feel for the space now.
You can get a better feel for the loft storage area and the vaulted ceilings.  The space feels a lot smaller!
56ee002322c65_drywall1.thumb.jpg.85702c4
56ee004b2f995_drywall2.thumb.jpg.8e27825
In the 2nd picture on the left you can see the bracket for the mini-split HVAC unit - I realized that it might be too high to get a 6" dust run above it - it may end up being a bit away from the wall.  When the HVAC guy comes back, I'll see if there's a chance we can drop it a few inches - even 2" would make a difference.
I also played a bit with the color scheme.  I have drywall, birch plywood, and pine that I'll be working with.  As for finishes, we have a paint color picked out, so we're trying to decide on how to treat the birch and pine.  I tried both a grey stain (minwax) and a pickled / white wash.  For the grey, I experimented with how long I left it on before wiping it off as well as what happens if I put a coat of the white wash over it.  Here are the test boards (pine is on the top left, painted drywall on the top right, birch ply on the bottom):
56ee011dc68e2_colorscheme.thumb.jpg.1d6b56ee0120b1571_colorscheme2.thumb.jpg.dd7
I didn't wipe the white wash off the entire board - it really wasn't changing the color of the board much at all...
We've decided on the grey stain, probably left on for 10-15 minutes (photo doesn't show the differences very well)
Question for the crowd: the minwax stain doesn't have any poly in it - the instructions say to follow-up with a coat of poly after it's dry "for protection."
Would you bother?
AFAIK either you stain and then apply poly or you tint the poly. If you want protection for your wood you need poly, oil, etc. Stain alone won't protect anything.
Matt the shop is looking amazing man. Our house is up for sale and we are moving and this thread is making me want to build a new shop when we move!!
I think you will need to lower your bracket quite alot more that 2" if you want to put a duct above it. The air intake is on top of those units and you also need to be able to open the door upwards to take the filter out to clean it.
Looks like the garage door rail is going to be a bit of a pita when using the loft storage or is that just the photo?
Matt, I like the second set of test pieces, without white walls, the dark samples may make it feel even smaller.  Then again my opinion won't even get me a cup of jealous coffee.  I would also put poly on it as well.
Poly or a waterbourne over the stain is a very good idea. Satin or semi gloss would be my preference. Gloss makes every flaw stand out .
A light sanding with the grain before staining will help get a more consistent appearance. 120 or 150 grit is fine enough. Sanding too fine will polish the surface and the stain won't take as well.
Thanks Shane, I'm in love with the space, I find myself walking out there all the time even though there's not much I can do at the moment!  I hope you get to experience the same thing in the new house.
I'll take a look at the air conditioning unit and see what the top and bottom look like.  Worst case I can go along the ceiling a bit out from the wall.
Re: the garage door rail - it's not that bad.  It's about 2' off the loft and I can get a ladder up to the right of it really easily.  The garage door is hopefully a temporary thing, my real goal is to have a set of out-swinging carriage doors which'll let me get rid of the garage door rails.  Anyway, I've been moving myself and sheets of plywood in and out of there - the only tough thing is how high it is!
ok, ok, I'll do the poly!!  :-)
Steve, the can of stain says sand to 220 - but you think I can get away with 150?
On ‎3‎/‎21‎/‎2016 at 10:01 PM, estesbubba said:
The shop is really coming along Matt and looking great!
Thanks, Mike!  Remember when you were doing all that painting?  I'm in that phase now.  Spent 3 hours this afternoon and then another 4 hours tonight after playing soccer just to get two coats on the ceiling done.  That vaulted ceiling's not looking like such a smart move now!
But the electrician is supposed to come tomorrow so I wanted to get the ceiling done before the lights go up.
Floor's not so pretty now - I'm such a messy painter.  Lots of drips.  Oh and I knocked over a can of paint and ended up with about half a gallon on the floor.  Bad words were shouted.
Any hints for getting latex paint off of sealed concrete?  I'm honestly not that precious about it, I may just leave it unless someone has a no brainer way of dealing with it.
If it's sealed couldn't you let it dry until it can just peal off? Grab something to scrape with and try pealing it off like tape.
I would try soaking it with methyl hydrate and use a stiff bristle brush to scrub it.
Oh yes I still remember how much that 19 gallons sucked! When I was painting my ceiling I put down a 10'x30' piece of poly that was leftover from my wall vapor barrier. Later when I was painting with a brush around lights, speakers, etc. I did get a few drips and tried to wipe up right away. I did miss a few and they are still there for character.
Come on man, its a shop floor not your dining room.  If it's going to look pretty all the time people are going to think you don't use your shop. :blink:
We've had a few days of good progress.  After staying up to 1am painting the ceiling because I was expecting the electrician the next day... he no showed.  But that's ok because there's a TON of stuff to do.
I worked on paneling the end wall with T&G pine (inspired by @Janello's shop, but with much crappier wood) while Mrs. K painted the drywall.  She got two coats on the drywall while I almost finished the wall:
56f6016d4a947_Vpainting.thumb.jpg.ea8af6
Here's my selfie with the wall that I shared on facebook... no more beard as I have to start interviewing to go back to work soon.  The "rare wood works" hat is just the joke-y thing I put all my woodworking efforts under... "rare" because it feels like I rarely actually make anything.
56f6017067b8e_Mwall.jpg.04e1bdd8c8a85849
Today I sanded and then we stained the plywood and pine - I even tricked the wife into helping again.
56f602a7e015f_vstaining.thumb.jpg.b0780a
56f602b2c35de_endwall.thumb.jpg.77892788
I'm happy with the color scheme - I know the accepted wisdom is reflective white walls, but I don't think I'll need it with the # of lights that are going in... and if it's terrible or my eyes get worse, I can always paint it white then.
A bit of trim, a bit of trim paint and we're getting pretty darn close!  Electrician is expected on Monday or Tuesday..
Looking great Matt ! You're gonna love having a mini split in there. Year round comfort! The addition of a nice pellet stove would look killer in there too though, it's got a cabin look and feel to it.
Oh, and hang a couple sconces and big moose head with a saw in its mouth on that gable end !
Looks really nice!  Getting near the end of a shop re do at my place.  The mini split arrives Thursday and I have the day off to do the install, living in the deep south the A/C can't get here soon enough!  Congrats on a great looking shop.
I really like the wood panel wall,  really like it.
I didn't subscribe to the all white either. Currently I have two walls still OSB colored and don't mind it at all,  in fact,  the wall right by my bench gives a nice warm and easy light for working.
It's looking great man.
Thanks John!  How about something like this?
Keep hold of everything!  I misplaced the remote for the HVAC... I think it got scooped up by one of the workers when they were cleaning up and now I'm waiting for the $50 replacement!  Luckily it's been 50s and 60s here, so I'm surviving!
Thanks Brendon - I love that wall, it's such a cool feature.  Here's a shot from tonight with all the lights installed - I think they compensate pretty well (oh and somehow a TV found its way onto that wall... no idea how that happened!)
I'm also working on wood storage.  I initially bought those orange portamate wood storage racks but they wouldn't use the space I have very well, so I'm going with that storage system Marc put in, though I have a different idea for the plywood storage.  So far, I just have the vertical boards in, screwed into the studs.  It's the space I had framed out for the extra garage door, so the studs are in pretty random places but I think this'll work for storing different lengths of boards:
Looking awesome!  I'm sure the picture just don't do it justice!
  • 26,009 Total Members
  • Joseph b Newest Member ·
