  • 9 months later...
On 10/25/2018 at 9:30 PM, Cliff said:
I'm going to go out of my way to take my time so I don't have a repeat of my last journal which is still unfinished.
I don't want to brag, but I might just finish this project.
I'm setting records for the most and dumbest mistakes and yet still have a functioning project. Since this is my first ever actual furniture project, I find most of these errors somewhat ok. It's just a learning curve.
I made a template for my legs, and set up my new sawstop router wing. I made 5 legs. Glad I did, I destroyed the first one and my template almost immediately. Next four went much better.
Overall my experience went pretty ok. There were some major inconsistencies. So I clamped them together and sanded those inconsistencies out.
Then I started on the rails. I have to admit, I should have thrown these away and restarted them, but I'd have had to go buy more material because the only 8/4 walnut I have is still drying.
Here are the mistakes I made, in no particular order:
1. I cut a curve into them, which ruined my inset glass door idea.
2. I cut a curve into them BEFORE trying to cut dados for the glass and back
3. I cut my material too thin and had to glue on extra stock after the curves were cut - which btw, was a terrible grain and color match.
4. This may be a leg issue too, but I completely screwed up my placement of the glass and left no easy way to put in shelf pins.
And here are the pics
Then fixing the rail thickness
This seems like  a lot of clamps
Popped the rails out of the clamps and did some clean up, not terrible. The color mismatch is very noticeable, but thats how it goes.
Laid out my dados
And threw in a test clamp
Made the dados on the router table
Started domino-ing my way through the project. It was a lot harder than I expected. First I had an issue with my domino.. it wouldn't plunge all the way in to 25 mm. So I had to trim the dominos (turned out to be a plastic piece stuck that was causing this.) Second there were something like 16 joints to make and I managed to not label them all.
And or some reason, my dominos were not snug. It could be because I cut the mortises then worked about 6 80 hour weeks in a row before coming back to the project so humidity changes screwed it up.
Also, here I pluged from wrong reference side
While I was at it I chiseled my stuff, conveniently forgetting to do the back dados, which is fine since I forgot to cut dados in the back leg pieces anyway.
Since my dominos were so loose, I put some more in.
Then did the sub glue-ups. I did the sides first, actually a few days apart.
Then the rest. This was easily the most frustrating and stressful glue-up I've ever done. I used titebond 3 because I knew it would be bad, and it still almost set up with things not together right. I thought I planned well, but it turned out that I really didn't.
This rail tried to twist, so I had to run a 12 inch clamp on it to get it to stay straight.
Cliff, there are three settings on the Domino that dictate how wide the slot is.  Its a knob on top of the machine that you can adjust the width with, BUT make sure that when you change the setting that the Domino is turned on.  I believe it mentions this in the manual.
3 hours ago, wtnhighlander said:
Cliff, I know mistakes can be discouraging, but perserverance is what its all about. You are doing great!
This is true. Fixing mistakes is part of the journey.  Things are looking good.
I meant loose in thickness.
I made them wide because I'm not confident in my ability to perfectly line up my mortises.
Learning pains. If you included the pictures and never mentioned the issues I'd never have guessed. It looks good seriously.
All you need is more projects under your belt for some confidence and you'll be constructing like a pro. I think you have a good eye for design. I had quite a few spectacular failures in the beginning.
  • 1 month later...
Not gonna lie those statues are awesome, totally didn't even notice the beautiful curly walnut till the last picture. I think you did an excellent job. Just try and forget the mistakes and after a year or 2 you won't know any better either.
Very nice work Cliff, the lights really set off the figures. The only reason I would add doors is for dust and then I would go frameless sliders as I think any frame would block the view of the contents. I wish my first real project looked anywhere near that good, well done sir!
Looks great! And looking at the finished piece, the only way someone would notice your mistakes would be from reading this thread or if you told them.
Great job, Cliff. As others have said, learning to repair/recover from mistakes is a big part of woodworking. We all make them. Almost is if it had been planned, fully half the students in the class I'm teaching this semester spent the last class repairing mistakes - dominos that din't align, making a frame a ½" short because he wrote the length down wrong, hinges that didn't line up, etc. We all make them and coming back from 6 80 hour weeks doesn't make it any easier!
Nice recovery and beautiful project. That's some gorgeous walnut!
21 hours ago, Cliff said:
Also I don't know if anyone noticed by I had like 7 statues when I first started this project. Now I have 19. And 6 more on order. I might have a problem.
Ahhh time for case #2? It doesn't look like you have much space left.
Might be time for a new house to hold more cases!
  • Haha 2
  • Who's Online   2 Members, 0 Anonymous, 52 Guests (See full list)
