Getting a painted piece to look great is a LOT of work. I was doing some work in a high end house that was in the finishing stages. The painter was working on the mill work trim & at that point had 7 coats of lacquer down. He still had, he figured, 3 coats to go with spot putty & sanding between each coat. It already looked really good at that point.
Thanks for the good words !
I explained to the client that the simplicity and effort in the finish were a major portion of the price. They are also getting copies of all these pictures. I will be taking pictures of the install as well.
We cut about 2 1/2" off the grill. The top ended up at 37" high. The client wanted it at 36" high but that would have required patching part of the return which would show inside the shelves, and I don't do drywall if I can avoid it.
Beautifully done! Thanks for the step by step.
I wouldn't have thought that the finish would be that involved. It's great to see the painstaking attention you take in pulling something like this off.
10 hours ago, wdwerker said:
They are going to put on 3 of those hinge pin adjustable door stops to keep the door from whacking into the shelves.
Those things are horrible & almost guaranteed to ruin the door/hinge/jamb. Not a lot of options there though. Maybe if there was one on each of the 4 hinges & they were carefully adjusted and they don't let kids use that door.
I hadn't noticed there are 4 hinges. Empty nest couple so no kids. It's not the only door to the porch/balcony either.  They could also put a floor mounted stop. I will mention this to them. Thanks to all for bringing this up.
  • Who's Online   2 Members, 0 Anonymous, 54 Guests (See full list)
