So I went to check mine and couldn't even find a name on it. That did get me to wondering how long should one keep a fire extinguisher before replacing? This one is probably 14 years old and never been used.
If used in a business, the extinguishers are required to be inspected at least annually. The ABC dry chemical are the most common and require a 6 year tear down and refill. A hydro test of the extinguisher is required every 12 years. Drew, if yours has a metal valve, you probably don't have any worries. If mine were older than 12 years, I would go to a local fire extinguisher sales and service company and buy one of the aforementioned extinguishers. Then I would go home and take your old extinguishers to the back yard and you and your spouse practice using it on a play like fire, just for the experience. It does make a little mess so make sure your down wind of the pool and vehicles.
I'd take it outside or someplace that you can clean up the mess test it out but replace it.
Pool? You mean lake? The one in my show is the metal valve that is rechargeable. I attempted to buy a brand that wasn't kidde but they appear to be rebranding their stuff due to what I'm sure is poor reputation.
When i worked for the city i got to do yearly safety training with the fire department. They had a cool little mock fire that you had to try and put out. It taught me a lot and was fun.
Worst idea ever. You'd never be able to find it when you need it. :D
Yeah if I got that anywhere near my wife's pool I would need more than a new fire extinguisher I'd probably need a good divorce atty...Of course she stays clear of my shop so all is good. Not to mention since i'm the pool boy i'd have to clean it up...better to take it into the back woods and let it filter to my neighbors house :o
So does this look like a decent unit? I'll have to check but pretty sure my current one is a 5lb
https://www.amazon.com/Amerex-Chemical-Class-Extinguisher-Bracket/dp/B00F5CK9X6/ref=sr_1_3?rps=1&ie=UTF8&qid=1530209374&sr=8-3&keywords=abc+fire+extinguisher&refinements=p_89%3AAnsul|Amerex|Badger%2Cp_85%3A2470955011
Perfect!
2 hours ago, JosephThomas said:
Everything at the local HD is 'Kidde' brand...what a blow.
AceHw and Lowes both sell 'First Alert' branded stuff only...are those any good?
Actually I think First Alert is mfg. by Kidde as well, not sure but no, we won't service those either. the one @pkinneb  links to is a good one at a decent price. The B402 or the B500 are just about the same extinguisher, with the B402 having a little bit higher rating.
  • Thanks 1
1 minute ago, K Cooper said:
Perfect!
Awesome thanks Coop!! I ordered that one.
When I volunteered at Road Atlanta everyone had to take the "Crash and Burn" safety course before the racing season started.  The plan was to use up every extinguisher on the property. They poured a tiny paper cup of racing fuel on the engine of a wrecked race car and lit it. Then after it had burned long enough to get the block nice & hot one of the volunteers got to put it out. Then they poured a full cup of fuel on the hot engine to simulate real race conditions. That was a much bigger fire !  After several people worked together to put it out they poured a gallon of fuel on the car and lit it once again.  I got to put it out using a huge extinguisher that was the size of a large gas welding rig. Big tall tank held the powder and a shorter tank has the inert gas to propel it. I think it was called Purple K. Made a hell of a mess !
Several races into the season a car rolled right in front of the corner I was working. As soon as the pack passed they flagged the course and we scrambled across the track.  The electric cooling fan was grinding on something and making a hell of a racket, some fuel spilled but never ignited, and I was standing there with a 20 lb extinguisher heart pounding. They pulled the driver out, we rolled the car back on its wheels and rolled it out of the way . Nowadays they have safety disconnects on the power
1 hour ago, Mick S said:
I've learned more about fire extinguishers reading this thread than I've even known. Our 4 Kidde extinguishers will be replaced tomorrow!
If you need fire extinguisher info.  Speak to Ken Cooper. He just a year or two ago sold his fire prevention business, and loved it so much, he stayed on as a paid consultant.
3 hours ago, K Cooper said:
Like an insurance policy, may you never need to use it!
Thats why I have 2 20# Ansul a 10# and a 5# all filled with Foray just in case the worst happens.
Purple K was the stuff Steve there is also Foray and Plus Fifty, not common in home fire extinguishers but all have specific uses. I was sent to the Ansul Fire School for 5 days one time and we had a blast putting out large fires of all types, learned a lot and it was a great time.
  • Thanks 1
Dang dude, you are well informed! We’re hiring:D  Briefly, or maybe not, there are, for the most part, three types of fires. Class A, wood, paper, trash, anything that leaves an ash. Class B, fires involving flammable liquids. Class C, fires that involve live electricity. An ABC rated fire extinguisher can be used effectively and safely on these three types. The Foray (ABC) and Plus Fifty (BC) are Ansul trademarks. The Purple K, or PK as the industry and the military call it, is great on flammable liquids and Class C fires.  Most extinguishers manufactured after approx. 1980 will have the class symbols on the label.
Ansul makes two types of extinguishers, cartridge operated and pressurized. Unless you are familiar with a cart. op. extg. like Dave, just go with the pressurized, the ones with the pressure gauges.
For our home use, the ABC, all purpose is the way to go. But keep in mind, it’s capabilities, regardless of the size, are limited.
And now, after five decades in the business, you know as much as I do. ;).
I watched a VW with a magnesium block burn in a parking lot. The whole back of the car was glowing brilliant white ! The fire department scrambled and got a dump truck full of sand to bury the car. Then we saw a stream of molten metal running out from under the pile.  For years you could still see the burnt pavement with the melted streams spreading around it. Metal fires are intense.
I have one of those... A buddy who was with the fire department recommended it.
I also have a Kidde, but it's a larger unit with metal handles and such.
So while I was going through my father's stuff I found a little kitchen fire extinguisher he must have bought back in 1975 or so... the gauge still shows it has pressure.   So I'm going to take it out back this weekend and give it a try.   I'm guessing it doesn't work, but figure I'd try.
  • 3 weeks later...
How about this one? It’s probably still good, right? :lol:
I believe this has been floating around our house/garage since I was a kid, but I may be mistaken. Who knows why it has made so many moves.
Sorry to revive this thread, but I found this in my mom’s basement when I was visiting and going through some old things and thought of this thread.
“Probably still good, right”? Not an assumption I would want to make if my life or home depended on it. There’s no pressure gauge on it to tell and it’s the smallest extinguisher made so, no, replace it with a manufacturer recommended and no smaller than a 5# capacity. I see on the label that it was made in 1976. These things cost $50 or so. How often do you replace your $30k - $50k vehicle?  Speaker no of vehicle, do you have one in it?
  • Who's Online   0 Members, 0 Anonymous, 45 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
