My question is I have a Laguna 1412 .And I am wanting to get a resaw blade I will only use here and there.I don't want to break the bank I need to know what to get there are so many
available out there and by a ton of different companys The Blades I have used are Timber Wolf and I have gotten a couple from Blades .Com .And have good luck with both of these companies My question is width of blade and TPI
any help in this Matter would be greatly appreciated  I will be using for Walnut and Cherry and Soft Maple mostly
I'm no expert, but I have the Laguna Resaw King on my 14" craftsman, and I'm pretty happy with it. Some of the guys on here seem to get practically glassy finishes from it. I haven't been able to duplicate that, but it still cuts a faster and straighter line than anything else I've tried. Like you, I mostly cut domestic hardwoods.
I bought the 5/8" silica blade from Laguna for my 1412 and it worked great. Very smooth cuts. I was drooling for  RK 3/4" but have yet to buy one. I'm that happy with the 5/8". $35 iirc
I bought some timberwolf blades (including a 3/4") but they're for resawing logs not really veneer. They work great for what they're made for but the ones I got are far too coarse for veneer resawing.
1 hour ago, pkinneb said:
Buy this blade and use their online set up procedure (PDF at the bottom of  the page). I have tried a lot of blades ranging from this one at about $38 all the way up to the $200 plus carbide tipped blades and I just keep coming back to these. I get a 1/2" for my saws Laguna 1412 and Laguna HD16.
https://www.highlandwoodworking.com/wood-slicer-resaw-bandsaw-blades.aspx
+1
That's the way I am leaning after doing some reading And getting info also thanks much
I need to try these, I've been using the Laguna Resaw King. One thing about the Resaw King is that it stays sharp for a long time with the carbide tips and it can be resharpened (which I have yet to do). How does the sharpness of this blade hold up?
Of course with the price of $35 to get one for my Laguna 1412 the price is right.
So I do a fair amount of re sawing and I find they hold up fairly well but if you are going crazy at it like Cremona then a carbide tipped blade is probably in order. I have a resaw king I bought with the saw many years ago (over 10) but I have never liked it. I sometimes wonder if they have changed that blade since I bought mine it gets great reviews. I've also thought about trying the blade Matt uses I think its a Tri Master but honestly I am just really happy with these and for what they cost just think they are great for folks like myself or someone just starting out. I also think the set up HWW recommends is better than anything I used before and made the process much more enjoyable. Again I am sure there are better blades and maybe even setups but for sub $40 with great results I think its hard to beat.
  • Thanks 1
So just to clarify, are these recommendations just about resawing or are we also thinking about veneer slicing?
Veneer slicing would seem to me to demand a smoother cut that's more even and thin than resawing.
I still have to buy some blades for this new bandsaw and my first needs are going to be more along the lines of veneer slicing.
Same recommendations then?
Do you think the woodslicer could yield a glue ready surface?  I'm thinking about a project where I would be gluing up a stack of "veneers" to form a larger turning block.
I have found that any decent blade can saw veneer if the machine is well setup.
1/2" Resaw King, 1/16" veneer; contrary to some videos on the web I have no issue slicing veneer against the fence:
Three pieces done with three different blades; Ellis 1/4", Woodslicer 1/2" and a Timberwolf 3/4".
These are a fat 3/32" and cut on the outside of the blank as I was demonstrating blade changes without adjusting for drift, not veneer slicing.
We have the Laguna 14 SUV with 1" Resaw King blade and that's all that's ever been on the saw.  I regularly resaw thin pieces against the fence.  I guess the thinnest I've cut is around 0.70" but usually cut in the range of 0.100" to 0.125" for guitar sides, backs, tops, headstock veneer, etc.  That works just fine for me and the Resaw King blade leaves a pretty smooth finish.
David
When I resaw I don't care about finish so a coarse blade is OK. But the 5/8" silica Laguna blade I mentioned earlier works great for a good finish on veneer and for $35 I thought it was a decent blade. And the silica blade will last a little longer than the steel blades. No competition on the carbide blades though, obviously those will outlast all the other types.
Check you blade for burrs on the teeth and if you find some take a diamond plate to it. I've had 3-4 RK blades and 2 of them had burs that needed to be cleaned up. After i took the 2 burs off it went from traditional band saw blade to table saw quality.
I have a wood slicer sitting in a box that i'm going to use when i cut the veneer for the dresser i'm going to make here shortly. Otherwise i leave a reasaw king on my band saw. I figure the carbide teeth will make it worthwhile because i cut everything with my band saw and really only use the table saw for joinery. Tune up is key for the RK if it cuts weird completely re setup the saw taking all the guides apart and reset the tracking. I've found it stays on the saw so long stuff starts to shift slightly wither or not it should is another topic.
The blade that lives on my 14-12 is a starrett 3/16" 10 tpi.  Gives a good cut but I seldom resaw more than 4".  I can cut down to 1/16" in a pinch and cut all my curves.  I guess I just don't like changing blades.;)
  • Who's Online   2 Members, 0 Anonymous, 63 Guests (See full list)
    26,008
    Bob44
    Bob44
