treesner Posted February 6, 2019 Report Share Posted February 6, 2019 So I’m setting up a leather workspace and the cutting table is super deep which makes it hard to do a tool wall behind it with all the tools hung or magnated. Anyone have a similar problem and come up with a solution for having close places for frequently used tools so they don’t clutter up the bench kind of thinking a side tool wall or building an overhang halfway deep into the bench but in the air a bit so that I can still cut under it. If it was fancy could do that on some kind of slider to push it farther back if I need the vertical space. But that would make it unsturdy for pulling magneted tools on and off Quote Link to comment Share on other sites More sharing options...
treesner Posted February 6, 2019 Author Report Share Posted February 6, 2019 Or maybe it’s hinged in the corner or the middle side so I can have the tool holders in front middle most of the time but hinge back out of the way when I need the space for big cutting this is what I wish my tool wall looked like Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted February 6, 2019 Report Share Posted February 6, 2019 I like the idea of a double-sided tool board that pivots on one edge, so it can be out of the way for working, but swing out over the workspace for tool access. Quote Link to comment Share on other sites More sharing options...
Mark J Posted February 6, 2019 Report Share Posted February 6, 2019 I would want to maintain the view out the window, so I would look at a rolling cart that would be at my side when working and park underneath the work area when I was not working. Quote Link to comment Share on other sites More sharing options...
Chestnut Posted February 6, 2019 Report Share Posted February 6, 2019 I put a shelf 4" under the top of my bench and set tools on that. Key is to keep the height small so you can only put short items on it, but enough that it's easy to grab tools and then put them back. Another random idea or modification to take you wall holder and turn it into a drawer. Have the holes in the bottom to orient your tools vertical and just make sure to have enough space below it. Kinda like the caddy you have in your first picture but as a drawer. Quote Link to comment Share on other sites More sharing options...
Tpt life Posted February 6, 2019 Report Share Posted February 6, 2019 Corner anchor a tv swing arm? Pivot to back wall or side wall. Quote Link to comment Share on other sites More sharing options...
fcschoenthal Posted February 6, 2019 Report Share Posted February 6, 2019 Have your tool wall be a french cleat system with the tool holders able to sit on the bench by themselves. You could have only the tools you are currently using on the bench and the rest on the wall. Chris "It's never too late to have a happy childhood" Quote Link to comment Share on other sites More sharing options...
Coyote Jim Posted February 6, 2019 Report Share Posted February 6, 2019 What about this style of a TV wall mount? You could attached a piece of plywood to the face and do all your tool hangers on the plywood. Then you can just pivot the thing around and out of your way. These kinds of mounts are usually good to hold up a couple hundred lbs so it should work. 1 Quote Link to comment Share on other sites More sharing options...
gee-dub Posted February 6, 2019 Report Share Posted February 6, 2019 I would be tempted to make drawers that suit my needs at that location. Things are handy and you don't lose your window. You do lose the space for whatever is already under there so you would have to choose ;-) Quote Link to comment Share on other sites More sharing options...
Coop Posted February 7, 2019 Report Share Posted February 7, 2019 Magnated? perhaps something like this. https://www.google.com/shopping/product/9975470001081399895/image?q=scissor+type+bracket&client=safari&hl=en-us&prmd=sivn&biw=320&bih=471&sa=X&ved=0ahUKEwij1fPnyKjgAhUNYK0KHTsHA5wQnUAItgI&prds=cid:9975470001081399895,cs:1,paur:ClkAsKraX_q8GzhV-tLwUdXbMfS2bodGsD7iJ7AUlABrkwE96EIXLV_om_YC67jwD6bqNpfMWIZh4hcy5g-jUM8aQiqCNOIxg_l5zLtTV71TfpJg0LahW5FJthIZAFPVH72jgcpunXeqLK9A6TgdXhDweox2pg,sgro:iv,mvi:0 Quote Link to comment Share on other sites More sharing options...
Goober Posted February 7, 2019 Report Share Posted February 7, 2019 I have had a terminal case of re-arranger-itis (Stumpy Nubs), meaning that I will have it until I die. To help with this I make all tool walls using the French cleat system. That way I can move anything anytime I want with minimal effort. If you over anchor the cleats it will hold quite a bit of weight, securely. Springs a coming and the fish are biting. Quote Link to comment Share on other sites More sharing options...
treesner Posted February 8, 2019 Author Report Share Posted February 8, 2019 On 2/6/2019 at 8:32 AM, Coyote Jim said: What about this style of a TV wall mount? You could attached a piece of plywood to the face and do all your tool hangers on the plywood. Then you can just pivot the thing around and out of your way. These kinds of mounts are usually good to hold up a couple hundred lbs so it should work. That’s a cool idea, bummed that I threw one of those away when moved into the house! Quote Link to comment Share on other sites More sharing options...
treesner Posted February 8, 2019 Author Report Share Posted February 8, 2019 On 2/6/2019 at 6:24 PM, K Cooper said: Magnated? perhaps something like this. https://www.google.com/shopping/product/9975470001081399895/image?q=scissor+type+bracket&client=safari&hl=en-us&prmd=sivn&biw=320&bih=471&sa=X&ved=0ahUKEwij1fPnyKjgAhUNYK0KHTsHA5wQnUAItgI&prds=cid:9975470001081399895,cs:1,paur:ClkAsKraX_q8GzhV-tLwUdXbMfS2bodGsD7iJ7AUlABrkwE96EIXLV_om_YC67jwD6bqNpfMWIZh4hcy5g-jUM8aQiqCNOIxg_l5zLtTV71TfpJg0LahW5FJthIZAFPVH72jgcpunXeqLK9A6TgdXhDweox2pg,sgro:iv,mvi:0 I’m not quite sure what that is or how you envision it? Can you explain Quote Link to comment Share on other sites More sharing options...
treesner Posted February 8, 2019 Author Report Share Posted February 8, 2019 On 2/6/2019 at 6:18 AM, Chestnut said: Another random idea or modification to take you wall holder and turn it into a drawer. Have the holes in the bottom to orient your tools vertical and just make sure to have enough space below it. Kinda like the caddy you have in your first picture but as a drawer. this type of thing? this doesnt really solve my problem but a cool idea to drop it down when you're working and put it up under the cabinet when you're not Quote Link to comment Share on other sites More sharing options...
Coop Posted February 8, 2019 Report Share Posted February 8, 2019 It’ a motorcycle lift, meant to scissor up an down but in your case, could be mounted on your wall and mount your cabinet to it. Quote Link to comment Share on other sites More sharing options...
G Ragatz Posted February 8, 2019 Report Share Posted February 8, 2019 6 hours ago, treesner said: this type of thing? I would think wider, and not so tall - it would be a PITA to crouch/bend over to get to the tools down below. A drop-in system like for the knives in the photo would work for some tools - e.g., awls - but not so well for others, like wide bench chisels where the business end is as wide or wider than the handle. Might also be a problem in terms of identifying the tool you're after - all my bench chisels look the same from the handle end. Quote Link to comment Share on other sites More sharing options...
treesner Posted February 9, 2019 Author Report Share Posted February 9, 2019 On 2/6/2019 at 7:07 AM, Tpt life said: Corner anchor a tv swing arm? Pivot to back wall or side wall. More I think about it cooler that sounds. Wonder if it would bounce around every time you pulled a tool off a magnet or whatever. Can you like lock them and unlock them? Those dentists always have cool moving took trays and such.. think incould make something out of pipe that double hinges like that? Quote Link to comment Share on other sites More sharing options...
treesner Posted February 9, 2019 Author Report Share Posted February 9, 2019 http://lumberjocks.com/projects/101448 Quote Link to comment Share on other sites More sharing options...
treesner Posted February 11, 2019 Author Report Share Posted February 11, 2019 this one looks easy to just mount on workbench amazon Quote Link to comment Share on other sites More sharing options...
gee-dub Posted February 12, 2019 Report Share Posted February 12, 2019 Hmm, with a 14 pound limit you would have to double check what you want to put on it. We use a similar product at work and with a 13 pound monitor they are very solid and stay where you put 'em so they may be being conservative. Quote Link to comment Share on other sites More sharing options...
treesner Posted February 12, 2019 Author Report Share Posted February 12, 2019 3 hours ago, gee-dub said: Hmm, with a 14 pound limit you would have to double check what you want to put on it. We use a similar product at work and with a 13 pound monitor they are very solid and stay where you put 'em so they may be being conservative. thanks I guess ive never weighted my tools haha the hammers would be the heft of it Quote Link to comment Share on other sites More sharing options...
Dave H Posted February 12, 2019 Report Share Posted February 12, 2019 You could make frame that hangs on the wall and using some plywood make some panels connected with piano hinges so they accordion into the wall mounted frame, the last panel would be the tool wall holder thingamajig piano hinges can accommodate more weight than flat panel tv brackets. It seems to me like it would be a simple build you probably have enough scrap chunks of plywood laying around the shop. Quote Link to comment Share on other sites More sharing options...
treesner Posted February 12, 2019 Author Report Share Posted February 12, 2019 11 minutes ago, higtron said: You could make frame that hangs on the wall and using some plywood make some panels connected with piano hinges so they accordion into the wall mounted frame, the last panel would be the tool wall holder thingamajig piano hinges can accommodate more weight than flat panel tv brackets. It seems to me like it would be a simple build you probably have enough scrap chunks of plywood laying around the shop. thats a good idea and a nice DIY solution. My only problem is that I feel like It may move to freely like when you pull a toll off or go to put a tool in. the thing I was thinking might be nice about the TV thing is that it's probably pretty stiff and hopefully adjustable with some kind of allen tension at the pivots Also the accordion thing made me think of these tool boxes. although not enough reach for what I'm looking for it would be pretty cool to see a tool wall built like these boxes but mounted on the wall so it came out horizontally instead of vertically, would allow you to still mount stuff on the wall next to it (or stack up wood) and have the tool case come out in front of that stuff when you need something Quote Link to comment Share on other sites More sharing options...
treesner Posted February 23, 2019 Author Report Share Posted February 23, 2019 so I tried this one out which also has vertical movement. you can only adjust the tension of the up and down movement non of the other parts you can adjust unfortunately. however it seems to be working pretty good with this experiment board I tacked up real quick. I think I'm going to go wider and taller but I like how it works. the tools jiggle around a little bit when you grab a tool which sort of annoys me. but I've really liked being able to pivot it around from one bench to the other bench https://www.amazon.com/gp/product/B0722YHHX7/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 1 Quote Link to comment Share on other sites More sharing options...
Chestnut Posted February 23, 2019 Report Share Posted February 23, 2019 Is this the trial run to see if you like it? I cna't help but notice it's just clamped in place. Quote Link to comment Share on other sites More sharing options...
