Do i need FLG blade?
Im trying to make the wood whisperer's cutting board, and im just using a 24 tooth blade from diablo, and my cuts into the hardwood makes it look like there is a bump in the middle so when I try to glue up the cuts together there is a gap on top and bottom and only the middle is touching, I've made many adjustments to the saw as much as I could but I still have that middle sticking out. my plan was thinking a planer would fix this but if both sides have that bump i don't think that will work because i need at least 1 side flat. So is it my blade? my tooth angles seem to lean left and right every other tooth is that makes a difference. Thanks in advance
First off, never run end grain through a planer!  That's inviting trouble you don't want.
Can you joint the individual pieces to get them flat?
I run a 40T blade most of the time and don't have this issue.
I'm not sure I fully understand what you're describing but it sounds like something is out of alignment on your saw, or the stock you are using is not straight to begin with. Can you post a couple pictures of the issue or go into more detail about what steps you have taken so far?
I agree a pic would help.  If this is a rip cut, how are you creating the flat edge to run along the fence.  If you are not creating a flat reference edge, your trouble starts here.  Compound that by all the cuts and parts in an end grain cutting board and you have problems.  If this is a different cut at a different step, I guess I need a picture ;-)
Any chance you are cutting from one face, then flipping the board to cut through from the opposite face? I can't understand how the circular blade can make a bulge in the middle of the edge if you are cutting through in one pass.
If taking multiple passes, having the blade off square to the table might cause this.
Try a test on a similar sized piece fo scrap would and double check the piece for square.
That's exactly the part I'm on, I want them to be flat before I glue them up because the gaps are pretty big, I'll admit my fence isn't 100% true, I got it the best I could for an amateur, I havent exposed end grain yet
I'm sure something is out too but I've done my best to make it true, it's a hybrid delta and I wish I just bought a better saw, I've just done first step and cut all the sizes and I'm ready to glue up but I have tons of gaps
I just used the factory flat side. One side was milled and opposite side had rugged edge so I used the flat side against my fence
I'm doing something wrong but I'm not sure what and I just cut 1 side off the side from previous cut, no flipping, I used a widely to make sure blade was 90 degree to table, maybe the wixley is off?
Is it my bad eyes or is that throat plate sitting above the saw table? If it is first job would be to make one that fits correctly. You will have a hard time getting a good cut if the stock is moving.
Also, if you haven't already done it, the Wixey should be zeroed out on the table.
From your comments, OP, it sounds like you need to do a serious calibration of that saw:
1. Get the blade parallel with the miter slot
2. Set the fence parallel with the miter slot. Some like to have the back of the fence slightly farther from the blade, but it should be no more that a couple of thousandths out.
3. Adjust the insert plate so it's perfectly flush with the table.
There are a ton of videos showing how to do this, so I won't try to explain it here. Here's a good place to start: The Wood Whisperer
Right now you're just fighting the saw.
+1 to what @drzaius said. It may not the nicest saw on the market but it is more than good enough to make decent cuts (Unless it has been damaged).
Take your time calibrating it, and it may take several adjustments on the same part- sometimes adjusting one thing will affect another. Don’t expect to have it dialed in in 15 minutes. Make sure the tools you use to calibrate the saw are square and true.
I’m still not sure the issue is truly resulting from your saw, but you’ll only have frustration and problems if you continue to use the saw out of alignment.
One thing ill throw in here, is that when using the digital gauge to set the blade to 90 degrees, dont just set it until it hits 90.0 degrees and call it good. To me, its still not close enough. Get it close with the gauge, then fine adjust by making test cuts on a thicker piece of material and use a good square to check its dead on. If it isnt, keep adjusting the blade until it is.
13 hours ago, Valleyslim said:
I just used the factory flat side. One side was milled and opposite side had rugged edge so I used the flat side against my fence.
I hope we haven't scared you off with all the data.  I too am sometimes overwhelmed when I get recommendations from the cumulative experience of a century of woodworkers on here :D.  Our goal is not to overload but, you do have to read through the responses and kind of put them in order as they apply to where you are in the process.  Let me try to sum up in order of importance:
1. Align your saw.
uh, er, . . . well, I guess that's it in order of importance.  I know this has been discussed but, there is aligning your saw and then there is aligning your saw.  For cutting boards, the blade to fence is most critical followed by your sled for crosscuts.  Well milled material is already critical. When you are going to stack or laminate parts as with a cutting board, any error, no matter how slight, becomes amplified with each layer.
Your first picture probably shows the result of using a non-true edge as a reference edge against the fence.  The second picture looks like an un-milled edge against a milled edge so that can be improved.  One challenge is that any "fixes" you apply to any sub-optimal edges at this point will alter your dimensions.  I wouldn't let this slow you down.  Unless you're going for something like this:
Your irregularities won't kill the board.  Patterns like this . . .
. . . tolerate boo-boos pretty well.
If your current board isn't perfect, it will be a great learning experience and the next one will be that much easier.
16 hours ago, wtnhighlander said:
That looks like a job for the jointer. I think the blade is making to rough a cut. Do you own a jointer, or a hand plane to clean that cut edge?
If not, sandpaper stuck to your saw table can work, but you must be careful to hold the workpiece square to the surface.
Unfortunately I don't own either, I do want to pick up a planer or jointer during black friday
It's just a tad under the cast iron
Yeah I did do that
Yeah I'll mess with it again, I think the problem is I don't have a tool that's square, I only have a carpenter's and framing square from empire which I'm pretty neither is accurate especially my framing square as it looks like 89 degrees just from my naked eye
I'll do my best to give another go I already spent 2 hours trying to get it square but I knew after I gave up it wasnt perfect but as close as I could get it, for the longest time I fought with the fence as I noticed with I clamp the fence down the end of the fence would shift left making end of fence closer to saw blade, but I sorta fixed it, but there is a lot of play when I move the fence, I really don't like it.
Anyone have suggestions on a square or any device to help me with getting the alignment fixed? I'm pretty sure neither of my empire squares are accurate, I mean I paid 5$ each. I bought cheap tools to make sure I like the hobby and I do. I wish I bought the best I could afford back when I started. I can afford a saw stop right now, but I want to wait till I move out of Taxifornia so I don't have to move it, thanks in advance
Get yourself a dial indicator (not expensive) for aligning the fence & blade and get a decent square for getting the 90* & 45* stops set on the blade & miter guide. And don't 'mess with it again'. Go watch some videos on the process, get the tools you need, and be thorough & methodical about getting the thing calibrated.
Buying bad tools will only ensure that you will hate the hobby :wacko:
I didn't want to quote all that to erase a bunch for what I had to say...
Empire tools can not be counted on to be square!
So I'm also building a mobile kitchen island for my small kitchen and I built the counter top for it and I'm designing the base for it but then I realized that the glue up with those went very good in my opinion. The wood is only about 3/4 inch thick (I wish I bought think cedar planks but oh well) but I didn't mess with blade or fence alignment, and all cuts were made with same tablesaw, the way the cedar is glued is exactly how I want my cutting boards to look, so does the thickness of wood make a difference in forgiveness? I can barely see the lines of where I glued up my cedar planks. Also what's a good square, I was debating about picking up woodpeckers, also thanks everyone for the help
The cedar panel looks great!
Any square that provides a true perpendicular reference is a 'good' square. Test yours by placing the head against a known straight edge, like a factory edge on plywood. Draw a line along the blade, then flip the head over so the opposite side of the blade is against the wood, and mark another line. If the lines are parallel, your square registers true 90.
Harry J Epstien sells good squares and other tool at good prices, as they are 'factory seconds', perhaps scratched or incorrectly painted. PEC is a popular brand from their web site. Woodpeckers stuff is very precise, but pricey. I don't care to pay so much for aluminum that my fumble fingers are eventually going to drop on the concrete floor and damage.
What wtnhighlander said.  Also Starrette's expensive line (they make cheap stuff, too.).
If you're unsure what types of square to buy a Rockler or Woodcraft store could give you some guidance, if there's one nearby.  I have a Starrett combination square and then some Woodpeckers items, a couple of three squares (fixed blade), a 45* triangle and 3' straight edge.  I got some on sale and others when a need arose.
I didn't know about Epstein, and sometimes I just "needed it today".  I don't regret the purchases, because I no longer remember what I paid.  I store them carefully and they are there when the task matters.
When you test out what you buy, be sure to test out both sides of both blades of the square.
I have gotten lucky with a couple Empire items, but also recently got one that was WAY out of square. Fat 1/8” off over 12”.
I have heard good things about the Kinex brand (available on Amazon) and they are reasonably priced, but I don’t have any personal experience with them.
