Current Bench Build
I am currently in the process of building a new LONG AWATED workbench for the Shop.  I have been working on and IKEA slab bench and it has served me well, but I went to a Hand Tool Event at Lie Nielsen toolworks and used their benches and that was all she wrote.  Couldn't buy one of theirs at the time, but I purchased their vises and the Hard Maple was given to me as a gift.  Didn't have enough to do the base also so it is Sugar Maple, hard maple, and ash combined.  The base is really heavy and sturdy.  The bench top is 4" solid slab of hard maple.
Here are some pics of the progress:
Bringing the lumber home
Rough layout before final milling
Laid out in sections - to accomadate my 8" jointer
Sections set for glue up
Then the base was started
These are the sugar maple
They stretchers are ash
Dry assembly to check mortise and tenon alignment
Jig for top of the legs
 Tops of the legs that will NEVER been seen again :)
Base assembly all done with the bench bolts added
Face vise under bench work
Face vise hardware test fit install
Hard maple is fun to chisel - NOT
Nice work!
I always thought sugar maple was hard maple and all the others, like red and silver were soft maples?
3 hours ago, curlyoak said:
Good work. How did you cut the top to length being 4" thick?
curlyoak.
I used a DeWalt Track Saw, cut half way through, flip, and repeat.  Then I belt sanded the end grain.  It came out better than I was expecting. ;)
Thanks to all for your kind comments
Bench is looking good. Hard maple really is a pain to work with at times. It's hardness and tenancy to have swirly grain makes it awfully difficult for hand tools as well as power tools.
Sugar Maple = Hard Maple = Rock Maple These are all names for the same tree Acer saccharum.
Any other Acer tree is considered soft maple, Red maple, silver maple, Norway Maple, Boxelder, etc.
Worked on the Face Vise yesterday.  And got it glued up.
Made sure to highlight my vise hardware parameters
Usually I am not an Instruction guy but this is an exception, I find their instructions in dept and easy to follow
Used a router plane and chisel for these and the power router for the larger section material excavation
Marked the waste just so I don't get confused and take the wrong material out :)
Glued up.
Now I have to clean it up drill the prescribed hardware holes and install, then I will tackle the tail vise.
I am interested in how the tail vise goes for you. I have one sitting in my shop waiting for me to build my new bench. Getting close to starting.
I am going to tackle that last :)
I will let you know how it goes.
Installed the face vise hardware.......  I have a couple of minor adjustment to make before I drill and tap to secure the vise hardware.
You can see that it is a little low on the left, I need to take just a little bit of material off the bottom of the bench in the hardware pocket and it should sit flush.
I like your use of the plastic sleeves to organize the plans. I always end up with them out of order and I can't stand the texture of sawdust on paper.
Bench is looking good!
After a lot of fiddling and fussing the 24" face vise is completed.  We are in the home stretch now, the sliding tail vise is the last phase........
No racking at all in this vise and it is a smooth operator, I am definitely going to be spoiled with this! :)
Robby,
I will be starting that today!  I will let you know how it goes.
I've always been curious how those chain drives perform over time.  Even though the opening is on the bottom it looks like it will collect a lot of sawdust.
Mark,
Lie-Nielsen has been making these for years now and I have never heard of dust being a problem with their chain drive mechanism.   If I encounter any problem like that, I will just blow out the cavity with compressed air re-oil the chain and make a removable cover for it.
My Veritas has been in use for about 4 years.  Although there is a cover on this design it is hardly air tight.  When I opened it to adjust chain tension after the first several months of use there was saw dust present.  None of this effected the action and I would have never known had I not wanted to tighten up the chain a bit.  It seems the same "non-air-tight" design that let's the spoil in, lets it out as you use the vise.
Awesome job!! That looks like it was a bit of work to get in there but will be so worth it.
Thank you!  Yeah it took me 5 tries to get it just right!
Started on the sliding tail vise hardware installation yesterday.  Had to mill out a 7/16" deep mortise for the main body of the internal slider to fit in.  I used the LN Router plane and it worked great.
This top is REALLY heavy :)
Testing the fit to make sure the jaw will slide freely
Now I have to hog out a 2" wide by 9" long by 3/4" deep dado on the bottom of the bench so that once installed the vise can be adjusted.
  • 4 weeks later...
The tail vise is being a bit more difficult than I had anticipated, but I should have it figured out soon and the final reveal pics will be posted :)
Well, this has been one long (time wise) and very heavy project :)  All that is left to be done is drill the 3/4" dog holes and put some finish on it.
The Bench it replaced......
This vise is awesome to use.....
I even got the grain to match up on the sliding tail vise which simply means I lucked out :)
