Tom Cancelleri Posted July 7, 2015 Author Report Posted July 7, 2015 Aren't you missing the metal plate in the bottom of that mortise? Yes, this was a dry fit to make sure the criss cross was able to pivot cleanly. Sent from my 831C using Tapatalk 1 Quote
Tom Cancelleri Posted July 8, 2015 Author Report Posted July 8, 2015 Layout lines and domino lines. Gigantor the Routinator strikes again! Glue and clamps Puppy tired of me not paying attention to him tonight. Sent from my 831C using Tapatalk Quote
Brendon_t Posted July 8, 2015 Report Posted July 8, 2015 Are those blocks of cherry for the top of the chop? Quote
Tom Cancelleri Posted July 8, 2015 Author Report Posted July 8, 2015 Are those blocks of cherry for the top of the chop? Yessir Quote
Brendon_t Posted July 8, 2015 Report Posted July 8, 2015 Sweetness. I don't know why but I see my chop ending up the shape of a coffin. Just seems awesome to me. . 2 Quote
Tom Cancelleri Posted July 8, 2015 Author Report Posted July 8, 2015 My plan tomorrow, once the chop is dry is to run it through the drum sander to get it to final thickness, left it a touch oversized to account for cleanup passes. Need to drill the holes for the vise screw. Also going to put a curve at the bottom of the cherry and shape it a bit, chamfer the edges. really need to figure out how I'm gonna do the 2 3/4" acetal bushing on the leg. 35 bucks for a 1 time use forstner bit isn't my idea of smart. My circle cutter for guitar rosettes and sound holes starts at 3" as the minimum. I guess i could make a template with some MDF and cut it out with the scroll saw and clean it up with the spindle sander. Woodcraft stopped carrying circle templates for using pattern bits and bushing kits etc. Quote
Woodenskye Posted July 8, 2015 Report Posted July 8, 2015 Tom. Bench is really coming along. Don't know if you want to spend the money or wait for shipping, but here is a circle template for use with router. http://www.eagleamerica.com/product/400-1140/router_access_-_router_templates Quote
..Kev Posted July 8, 2015 Report Posted July 8, 2015 My plan tomorrow, once the chop is dry is to run it through the drum sander to get it to final thickness, left it a touch oversized to account for cleanup passes. Need to drill the holes for the vise screw. Also going to put a curve at the bottom of the cherry and shape it a bit, chamfer the edges. really need to figure out how I'm gonna do the 2 3/4" acetal bushing on the leg. 35 bucks for a 1 time use forstner bit isn't my idea of smart. My circle cutter for guitar rosettes and sound holes starts at 3" as the minimum. I guess i could make a template with some MDF and cut it out with the scroll saw and clean it up with the spindle sander. Woodcraft stopped carrying circle templates for using pattern bits and bushing kits etc. I bought the bit but, it also gets used for the mantle clocks so, I get a dual purpose out of it.. Quote
Tom Cancelleri Posted July 9, 2015 Author Report Posted July 9, 2015 I gave in and bought the Forstner for 25 bucks. Also bought a Pica pencil. It writes nice and dark. Sent from my 831C using Tapatalk Quote
Tom Cancelleri Posted July 9, 2015 Author Report Posted July 9, 2015 Sent from my 831C using Tapatalk Quote
wdwerker Posted July 9, 2015 Report Posted July 9, 2015 Roll of tape, pint can, quart, gallon, 5 gallon etc very handy circle templates ! Quote
Brendon_t Posted July 9, 2015 Report Posted July 9, 2015 I love the high speed, low drag circle template Quote
Tom Cancelleri Posted July 10, 2015 Author Report Posted July 10, 2015 A mix of bandsaw, hammer, chisel, oscillating spindle sander, ruler, block plane, smoother, cabinet scraper, card scraper, hand sanding, random orbit sander. I tapered the bottom under the cherry about 5/16" on each end. Quote
wtnhighlander Posted July 10, 2015 Report Posted July 10, 2015 Ok, now you're just making eye candy! 1 Quote
..Kev Posted July 10, 2015 Report Posted July 10, 2015 Awesome stuff! Thanks for the video! It's very cool to operate the BC stuff! Quote
RichardA Posted July 10, 2015 Report Posted July 10, 2015 Why is this build giving me some hard....wood? Quote
kevinmallick Posted July 10, 2015 Report Posted July 10, 2015 This looks awesome! Workbench is next and I'm taking notes. Nice job. 1 Quote
Greenaqua Posted July 10, 2015 Report Posted July 10, 2015 Tom, not sure what your plans are for the chop length but I did mine per the plans and wish I had a bit more clearance between the floor and the chop. I don't currently have enough space for floor mat to fit under..... Eventually it will bug me enough and I will take it apart and take another 1" off the bottom I think. Quote
Tom Cancelleri Posted July 10, 2015 Author Report Posted July 10, 2015 I started my crisscross mortis at 3 inches up from the bottom. And left me plenty of room to take more off if I need to but I think the clearance I have now should be good Sent from my 831C using Tapatalk Quote
Tom Cancelleri Posted July 12, 2015 Author Report Posted July 12, 2015 Tenons. Lots of tenons.... Marks, so I don't mess up the top short rails. Sent from my 831C using Tapatalk Quote
Tom Cancelleri Posted July 12, 2015 Author Report Posted July 12, 2015 Looking at those pictures, my dado stack doesn't make pretty cuts. Yay for hand tools. Sent from my 831C using Tapatalk Quote
