Barrister's Bookcase - Finished
  • Replies 123
  • Views 26.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • In finishing up the bookcase I drilled the holes to attach the top to the top section.  I drilled three holes toward the front of the case and three holes in the back.  The three holes in the back I e
  • Next I set up to do the door grooves on the router table. My test piece.  Because of the thickness of my ply material I needed to be 1 3/16 inches down from the top... ...and 1/4
  • After  I cleaned up the mortises... I cut the tenons. Did a quick dry fit. then cut the taper on the legs, and cleaned them up with my bevel up smoother.
Posted Images
I cut the tenons.
After that I cut the arch in the rails of the base,
Cleaned them up with the oscillating spindle sander and finished by hand with a block and sand paper.  Then added the chamfer to all of the base pieces.
Then glued and clamped them up.
This is the top and...
The edge detail on the top.
Base
plus one,
plus two,
And three.
Just a few things to clean up,  double check all of the sanding and then start applying the finish.
I only quoted this to drop it on the new page..
Looks amazing Chet!  Great work on the base!
The finish line is near - looking awesome!
I think Eric just kicked his Grizzly.
Really well done, Chet! It seems like it came together really quickly. Probably not as much as you...but I too am looking forward to the "pop" when the finish goes on.
Kev's speed has really rubbed off on Ya:D! Looking great Chet!
In finishing up the bookcase I drilled the holes to attach the top to the top section.  I drilled three holes toward the front of the case and three holes in the back.  The three holes in the back I elongated to allow for wood movement of the top itself.
As far as the finish goes with the help of Mike ( estesbubba) and after doing some testing, I tried something different.  I used a 2# cut of garnet shellac that was diluted about 25% more with denatured alcohol.  I sprayed one coat then sanded with 400 grit to knock the grain down then sprayed 3 coats of General Finish's High Performance, light sanding with 400 grit between coats.
We didn't want to to go with just clear glass for the doors,  We wanted something that had the waviness that you see in older glass.
Anyway here it is.
Couple of pictures of the top.
This is for Steve.
Turned out amazing Chet!  Love the glass!
All your work paid off.  Looks great Chet.
Great job, Chet.  Nicer than Marc's! :D
That thing is gorgeous ! I'm not one to get excited over a bookcase but colour me EXCITED !!
Sent from my SGH-I337M using Tapatalk
.  Nicer than Marc's! [emoji3]
Soon to be another moderator job up for grabs......
Now that's having full confidence in a first time finish offered by a friend! The finish and the build turned out fantastic!  The glass is a great added touch!
My wife has now seen the intro video to this project and pics from this thread....now I get to build one. Nice work Chet!
I am lovin' that thing.  The glass is a great detail.  The finish looks great and the setting is perfect for the piece.  Congrats!
The bookcase is gorgeous, The glass makes it quite different. I was wondering how well do you see what's inside with the glass?
In the photos you get a lot of light refraction with the glass but it isn't as busy as it looks.  When you put books on the shelves you have no trouble reading titles.  We took a number of books to the glass shop to test before we ordered the glass.  We haven't put any in the case yet, I wanted to get a cure on the finish, but when we do I will try to get a decent photo with out flash glare.
Makes sense, that would have been my guess that you did check beforehand on the glass, At first I thought it was some very wild figured wood as the first picture drew my attention before reading!
