Men's store display shelves
No base. It will just sit on a oriental rug behind a leather sofa.
 It would have been easy to not mention the mistake but I prefer to show what I do warts and all. Other than being kinda thin and runny that Extend glue saved my ass today !
  • Replies 67
  • Views 14.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Delivered and installed ! Client was so happy he ordered  2 more pieces. Same style, wood and finish but different sizes. New pieces will go on either end of the sofa. One will b
  • A client contacted me requesting a shelf display for a menswear store in a high end shopping district.  He wanted some rough price numbers and options. We settled on a design and I drew a crude sketch
  • Sanding the framework was no fun. Reaching in between all of those crosspieces is really awkward. 128 individual faces and being careful not to sand through at so many corners. After that sprayin
Posted Images
Brave move to disassemble 20 minutes after a perfect glue up ! Good recovery.
I have a few Bessey duo clamps that spread with force in the opposite direction to push joints apart. They've saved my but a few times.
Those who do not learn from their mistakes are doomed to repeat them !
After a long boring morning sanding and sanding we vacuumed and set up to spray sanding sealer. I put two thin coats on and we called it a day.
Tomorrow we get to sand some more then spray a top coat of satin.
If enough of you want to see I did take some detail shots of how I set up to spray in the shop.
Yes please!
13 minutes ago, Just Bob said:
Yes please!
Me too!
After vacuuming up all around the table, bench & saw areas to prevent a cloud of dust from being disturbed by the air from the spray gun I cover the saw & table with 1/4" MDF. I made a box to fit over the front rail of the tablesaw. I also used some 3/4" square scrap to put a lip that would stiffen the MDF that was bigger than the table.
Eventually the screw holes pull through the MDF , that's kind of its nature isn't it ? I just move them over a bit. These sheets have years of overspray on them. Periodically I sand them smooth with 80 grit. The shelves and top on the table are sitting on boxes I shot together from scrap. Make sure they are all the same size. I bought a package of cotton bar towels cheap. I put one over each box to prevent any scratches or scuffs on the freshly sanded faces. Spray the back or underside first. When the back is completely dry ( check on the scraps you spray at the same time ! ) flip the parts and repeat. IMG_0804.thumb.JPG.883d9a843fa97539e8f4448c427c4caf.JPG
Painters pyramids can leave dents if you aren't really careful. But they are great to keep stuff up and out of overspray bouncing off the table. I screw three of the ones that will link to a square of ply. Clamped to the table keeps them from shifting while you spray. The rags and boxes are safer for doors and shelves that will be seen from both sides.
crosspieces is really awkward. 128 individual faces and being careful not to sand through at so many corners. After that spraying the final coats was a breeze.   I set the shelves in place for a few pictures then called it a day.We will deliver it tomorrow so it has overnight to cure.
Thanks for the good words !
I use M.L. Campbell's Agualente. It's a pre- cat waterbourne finish. Most places only sell it to the trades. They make a post catalyzed version too, you have to mix it and use it within a few hours. The pre-cat has a finite shelf life. I have sprayed some past the expiration date. It dried but wasn't nearly as hard as the fresh stuff. So I use old finish to seal backs and undersides. I have played with General Finishes water bourne finishes and stains etc. The water based dyes are great ! You can thin them out with their reducer to get lighter shades and use multiple coats to build up to the exact level you need.
Client was so happy he ordered  2 more pieces. Same style, wood and finish but different sizes.IMG_0814.thumb.JPG.7b11a11a8cfb889bfdf00240127f4bd6.JPG
New pieces will go on either end of the sofa. One will be end table height and have clipped corners. The other will be 48 " tall and hold hanging shirts. Both will be open on all sides.
beautiful work as usual Steve, and the bonus of a repeat customer and great reference piece for other clients , nicely done sir!
Ah, that's-a nice.  Those look great and really up the look of the display.  Nicely done.
awesome and congrats on the on the spot repeat business!
How much weight cant those painter pyramids actually hold?
Quite a lot but softer woods can dent. I put a lot of pyramids under heavy pieces or use  a bar towel and a box or block of wood. I bought a big package of cotton bar towels for the shop, use her towels at your own risk !
Were they previously used?
  • 26,009 Total Members
  • Joseph b Newest Member ·
