Popular Post Ronn W Posted April 3, 2017 Popular Post Report Posted April 3, 2017 Just a fun project. Used my new dovetail jig to make itself a home including the Leigh bits, collet and bushings that are used only with the jig. Cherry and Hackberry. Dovetailed sides, top and bottom of cabinet and finger joint the accessories box. Have not yet put the ARS on the little box. 16 Quote
wdwerker Posted April 3, 2017 Report Posted April 3, 2017 Nice home for your new jig ! I like the grain match on the panels. Quote
treeslayer Posted April 4, 2017 Report Posted April 4, 2017 +1 on the matching panels they look great as does the case, i like to have everything for one tool in the same spot helps me keep organized. 2 Quote
..Kev Posted April 4, 2017 Report Posted April 4, 2017 Very cool! I just might have to steal that idea for mine! Quote
Janello Posted April 4, 2017 Report Posted April 4, 2017 Very nice well thought out project ! I've been wanting to make storage for my Omnijig, but I'd need a crane to lift it into a wall cabinet. Quote
Coop Posted April 4, 2017 Report Posted April 4, 2017 Pretty darn cool Ronn. I sure like the hackberry grain. The trim against the panels, is that sort of like glass stop in that it holds the panels in place? Like the way you did that! Quote
RichardA Posted April 4, 2017 Report Posted April 4, 2017 I like it, well done and magnets for the doors. Quote
sheperd80 Posted April 4, 2017 Report Posted April 4, 2017 Nice job. Looks great and i like the handle/hold-open situation. Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
wtnhighlander Posted April 4, 2017 Report Posted April 4, 2017 Very nice! I'm digging the cherry/hackberry contrast, too! Quote
Ronn W Posted April 4, 2017 Author Report Posted April 4, 2017 1 hour ago, RichardA said: I like it, well done and magnets for the doors. I made a note to myself: "Always double check the polarity on the magents before gluing them in" or they will push the door open. Cost me an extra trip to Home depot "cause I actually got all 4 of them wrong. Odds are that I could get 2 out fo 4 right but, Noooooo! 3 hours ago, K Cooper said: Pretty darn cool Ronn. I sure like the hackberry grain. The trim against the panels, is that sort of like glass stop in that it holds the panels in place? Like the way you did that! Thank you. That detail is courtesy of a Freud router bit set for panel doors. Quote
wtnhighlander Posted April 4, 2017 Report Posted April 4, 2017 Ronn, magnet polarity has bitten me before, too. I switched to using one magnet mated with one steel plate (or washer) whenever possible. Quote
Ronn W Posted April 4, 2017 Author Report Posted April 4, 2017 8 hours ago, wtnhighlander said: Ronn, magnet polarity has bitten me before, too. I switched to using one magnet mated with one steel plate (or washer) whenever possible. Good idea. Thanks. Quote
prov163 Posted April 5, 2017 Report Posted April 5, 2017 Very nice Ronn. I like the fact the doors slide out of the way. Cool. 1 Quote
Chet Posted April 5, 2017 Report Posted April 5, 2017 Very cool cabinet Ronn. That some great work. When I am doing projects with magnets, I take two that are stuck together properly, then, while they are alined I scuff up the ends that will go down in the epoxy, that way when I go to set them in the epoxy I look for the side that is scuffed and put that side down. Quote
