8 Drawer Dresser In Walnut
  • Replies 131
  • Views 31.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • This request from Megan has been on the table a long time. The only reason that it has been put off as long as it has is because other furniture was determined to be more important. Now that all the m
  • I have the drawers finished and knobs installed. My plan was to work on the top this week but that isn't working out. So here are some topless pictures.
  • Spent all day today cleaning up the drawer faces. Also had to do some final sizing. All i have left at this point is stops and figure out a device to stop the drawers from getting pulled all the way o
Posted Images
So the drawers need to be zied a bit. I made them a hair big and then plane down the sides to a perfect fit. Good way to plane drawers I've found is to extend a couple pieces of something over the edge of the bench and then hang the drawer on it.
Sanding the shop veneer went great. I cut it so that the outside of the blade was at 1/8" so the veneer was a kerf width under 1/8". I bought a woodslicer specifically for this and so far i can say the blade does a great job. The kerf is nice and thin and the cut quality is better than your typical band saw blade but still not as nice as the resaw king. I had a few issues with my RK blade with bad drift so i went for a sure deal. To sand i just used double stick tape to a piece of pine i jointed flat. I used painters tape first with a couple pieces of double stick tape. Then i realized i could get multiple uses out of the double stick tape and it was slightly easier so i just went that route.
I cut the veneer oversized. Trimming it down present me a problem so i opted to a high tooth count blade on the table saw. I used a piece of pine as a gripper of sorts and it worked great. Very grippy on the rough sanded surface. Als there was a lot of wave so i was able to hold the piece flat on the table.
For gluing them on. I can't remember where i saw using a towel between a caul but that's what i did. The fronts weren't perfectly flat so if i used used a board to distribute the clamping force there would be gaps. I put some wax paper between the towel and the drawer face.
I sparingly spread glue on both surfaces with one of those breyers.
Clamps, i used another piece of pine that was jointed and planed flat.
Here is what I've gotten done so far.
My question to the group is should i do the drawers like the top row or the 2nd row? Megan wanted to see it both ways. So i humored her and we couldn't decide.
Both ways look great but I like the top, the grain just seems to flow from the center out to the sides but it’s one of the times you can’t go wrong either way
I like both as well but I would choose the top.
Are those drawers interchangeable left to right? meaning once you have them all done and finished can you look at the whole dresser both ways?
Maybe depends on the route i go for guides. I can probably make them so they can swap side to side. I'll have to look into that.
If i do make them so they can be swapped one side will always be looser than the other as the openings aren't perfect. So gaps might not be the same all the way around.
I'm in with the top set as well.  I like the way the focus is drawn toward the center rather than trying to pull the eye out to opposite edges.
Another vote for the top pattern.  Both have the uplifting feel I prefer but, the top looks best to me.
For me it depends on how you want the piece to fit in the room.  Grain orientation can sometimes make a piece feel taller, shorter, wider or less narrower.
The top drawer orientation brings the visual focus to the center of then piece, making it feel smaller in width.  The lower drawer orientation spreads out the focus to the sides in long sweeping motions, making the piece feel wider than it actually is (in my opinion, of course).
If you have a big room and want it to feel like a big piece, I'd go with the lower orientation.  If you don't have a ton of space and want it to at least feel smaller, I'd go with the top orientation.
For my eye, the top match is so much more dramatic. It emphasizes the figure...
I don’t choose to be different, it just happens. So right now, as it sits, you can move any drawer where you want it? If so, can you post a pic of both rows the same in both orientations. To me, as shown, the first looks like SW Airlines logo and if repeated on down, it might look too busy.
Both are gorgeous and dramatic, but my eye tell me I like the bottom one just a little more. Having them alternate; top row with figure in the center, next with figure outside, next center, bottom outside might be worth mocking up just to see how it looks.
I think I like alternating, in and out on the figure, but I tend to have a bias towards high contrast...
@Chestnut
You've probably discussed this before, but how come you don't have a full Roubo Bench? Honestly with how many high quality projects and high quality tools you apparently have, I just sort of assumed you already had a bench like that. Just haven't gotten around to it yet?
I want to build one someday but what i have does work. I was going to purchase the hardware a few days ago but then a RAS 115E came up on the festoolrecon site so i snagged that, found a large nail in the tire of my pickup, and my computer died. So the spare cash i was hoping to use from my tax return vanished quite quickly on unforeseen expenses. I managed to grab a new Dell laptop off their outlet site for nearly 50% off what a new one would be. I think it's a scratch and dent deal but i don't care, I'm just going to add to the scratches and dents. The computer incident was last night, i was still up to that point thinking i'd be able to swing the hardware this spring and maybe the wood later on. Oh well now it's time to save for the spring and summer house projects. I need to upgrade my service to a 200A from a 100A and work towards finishing my garage. The last few days have reminded me why i want to install a heater out there.
So i was hoping for a spring 2019 roubo build, but it looks like it's getting pushed back. I'm not heart broken, after BC decided to pull that knob BS i think I'll wait until they get enough push back and hopefully correct their mistake. If they don't I'll just have to make my own knobs. What i need to do right now is flatten the top. It currently has a 3/8" crown in the center, which gets old fast.
Sorry about the unforscene expenses. I have to say, the lack of the bench doesn't seem to be holding you back much, keep up the good work. Still, I totally get wanting a full blown Roubo, I plan to build one myself. Looks like we might be making a local move that will hopefully lead to more shop space (and hopefully more vertical clearance) for me. I'd love to use my current bench as a glue up and assembly table and build a proper bench.
Like new property? Hope that it works out! Don't settle for something that doesn't have the potential for a good shop ;)   :D
Unforeseen expenses happen, the computer bugs me because i bought it a year ago. It was used mind you but it was a nice computer. One of the 15" dell latitude doo dads. Had an i7, SSD and all the bells and whistles. The new one i got is  slower but hopefully will last longer and wasn't that expensive at $445. I thought sawdust might have had a role in the computer's demise. But i tore it apart and it was very clean inside.
Thanks. I'll do my best to get a better shop space. Really, I try to not let my limited space be too much of an excuse. It is physically difficult, however, to manipulate large pieces in a confined space with 6'-3" ceilings, so a queen or king size bed frame would generally be a poor choice of a project for me.
Yeah that doesn't sound like a lot of fun. The one thing that i noticed that is really nice with a good space is your efficiency goes way up. I can come down and get to work instead of tripping over things all the time.
yeah, to actually get anything done, I realized I needed to be more organized and have a specific plan for what I wanted to accomplish, otherwise the space issues compound with general inefficiency and you really really get nothing done.
If i blocked this website on my shop comptuer i'd get more done. I won't do that because you guys already tell me i complete too many projects.
YES YES i can!
I also have the last 2 drawers in the clamps. This weekend I'll get to move on to drawer guides and then finishing. Oh yeah and a top.
Thanks for humoring me. I definately like the top pic a bunch!
you're not making this easy Drew, both look great, but i'm leaning toward the bottom picture on this one it has that book matched look. of course the final decision goes to your wife, if you're smart;)
I like the 2nd cause it reminds me of all the logos that have spread wings. Megan told me i get to choose because i don't get and space in the dresser. It's also on my side of the bed so i get to stare at it more.
Ex
