Jewelry box build
Thanks guys!! Getting close now :)
First up today was to pull the first door out of the vacuum bag and see what we had. Other then a small crack from too much over hang on the back of the door (you can see how its bent on the left side of the pic on the back edge) it looked pretty good. Not totally happy with the book match seem but not terrible either. The front corner match turned out much better.
The form will need to be repaired before door two :o
It was made for clamps and not a vacuum bag...
Form repaired and cut down, door two in the bag!
Here are some pics of the first door after some quick clean up
...and a back shot
And a quick repair of a chip out I had while planing the front veneer even to the door
Next up I started milling stock for the various drawer dividers. First time using the new BOW Products Guide Pro it worked well and quick to set just a pivot pin in the miter slot.
Then I used the drum sander to bring them down to an 1/8" thick
Cut them to length with a miter gauge
Then ganged them together with tape to cut the slots using the TS and a flat bottom blade
Here they are prior to final clean up. I will add cloth bottoms to the drawers that these will sit on
Next up I will finish up the other two drawer dividers, one for rings and one for longer items. Then I will pull the other door out of the bag clean it up and fit and glue the hinge bars to the doors.
  • Replies 135
  • Views 34.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • First up today was to breakdown the lumber, used a jigsaw and bandsaw for this This should provide about 95% of the parts for the project And this stack can go back to the lumber r
  • 4th times a charm...Bought a new forstner bit, added self stick sandpaper to the sides, and used pine for the center of the blank that gets drilled out. Here is a pic of one of the earlier o
  • I can't believe it's been 7 weeks since my last full day in the shop and since I posted to this build, that's ridiculous!  First up was to route the stopped grove for the drawer bottoms at the ro
Posted Images
Nice work!  I'll have to look into the Guide Pro, first I've seen it..
I got like a preproduction offer but they are generally available now I think. I have an extension that will take it up another three inches or so as well. This was my first time using it and I thought it worked very well and quick to reset.
Only got 90 minutes in the shop tonight but I was able to get the second door out of the vacuum bag and cleaned up.
Fit and glued the hinge bars to the doors
Finished the last two drawer organizers.
This one is the box for the ring section now I need to wait for the material, pad, and backer board to finish the drawers out. I will do that while I am waiting for the finish to dry. Blue tape for clamps :)
Next up mount the doors and make the last wood item, the necklace bars for the doors. Then on to final finish prep and finish...I really need to decide wait that's going to be
Waterbourne finishes won't yellow that beautiful veneer. Superblonde shellac might be nice, but perfume spills might hurt the finish.
If I get a vote, I think an oil finish would look great on the wenge with a clear waterbourne finish on the veneer. Great job on this.
I fell behind on following this but some real nice work as always Paul.  With the fact that you put veneer over the magnets, you could have skipped gluing them in, correct?  I know it was no real extra effort though.
Thanks guys!! With almost 120 hours into this little project I think some test boards are definitely in my future :)
Thanks Chet! You are correct but I was concerned if they fell out during glue up, and I didn't notice it, I would be kicking myself so a little super glue insurance for the guy with bad eyes was in order :)
Veneer over the magnets is a very nice touch, both visually and that it provides a softer close than direct magnet to steel.
That was my thought as well. The other side is not hidden but it is not as obvious as it is on the door edge.
7 hours ago, Belle City WW said:
That piece is awesome!  great work!!!
john
Thanks John!
Tonight I knocked out the hinge mortises. First I clamped the doors to the case with spacers top and bottom for alignment
Then grabbed some marking tools
Laid them out
Then roughed them out with a router
Cleaned them up with a chisel
...not perfect but hey I have 7 more to get it right. You can see the board I clamped here to help steady the router
Then I did the back same process but used the vise this time
there that's better
Now I need to get some metal screws to cut the threads in prior to installing the brass screws.
Next up I milled some stock for the necklace bars that will hang on the doors. Then ran a 1/8" cove on each side at the router table
I cleaned them up with a hand profile sander
Then drilled the pin holes before calling it a night
Tomorrow night I will fit them to the doors and glue them in, at that point the wood construction will be complete and the finish process will begin. Thanks for following along!! This one is almost a wrap :)
Just fantastic work, Paul. I have to admit not following this build since I wasn't that interested in building a jewelry box. That said, the techniques and approaches you've used are applicable to the improvement of any project. Now I'm kicking myself for not following along.
Great journal!
Since it's a late present you could slip a gift wrapped piece of jewelry in one of the compartments. That would add a nice surprise.
3 hours ago, Belle City WW said:
Hockey Taped Handle, someone has been hanging out with Rob Cosman :)
Absolutely! I started watching him about 3 years ago now. Watching his videos introduced me into handtool woodworking and really changed the craft and my approach to it. I still use his DT saw, chisels, and several of his processes like sharpening and cutting DT's. Unfortunately after about a year of his paid subscription I stopped watching just to much downtime in his video's to keep my attention. I will be forever grateful to him for teaching me via video to use a plane, sharpen hand tools, and cut dovetails!
Great journal!
Thanks Mick! I appreciate the kind words! I am looking forward to starting the Morris chair later this year and your book matched arms is on my list :)
Hey let's not get carried away Steve I mean I did buy her a new car LOL...having said that she has wanted a new mothers ring for a while hmm...
Etsy, Overstock, Gems Tv...plenty of places to get nice but reasonably priced jewelry.  Never had a lady react badly to any piece of jewelry. Usually the reactions are very pleasant !
Watching this build now.  I bought the Spagnuolo plans and want to make 3 boxes: 1 wife and 2 daughters.
Got a couple hours in the shop tonight. First up was to finish the necklace bars I started last night. The bars will be glued to the doors after they are finish prepped. Then the brass pins will be epoxied in once finish is complete.
Then I installed the hinges I used a self centering bit and steel screws for pilot holes.
CONSTRUCTION COMPLETE! :)
Next up determine and apply a finish. Then the final steps will be reassembly, wax the drawer runners and make and install the fabric (see below) drawer bottoms and ring holder. I received the cloth today but waiting on the fiber backer board which should be here Monday.
Sounds like you have been Red Head shopping for a while now?
Kind of like paying a late fee.
Even before the finish that is a stunning piece, and some super work all the way through.  Woot Woot.
Well after preparing a few samples the boss choose the semi gloss lacquer (sprayed.) So I got the parts prepped and into the finish room they went. I started with the drawers and dividers.
Since the drawer fronts are booked matched I added numbers to the bottoms
Those are ready so I moved them out to work on the cloth bottoms
Then the case and doors went into the finish room
Then I started on the drawer bottoms pretty straight forward some backer board, cloth, padding, and fabric glue. I cut the fabric squares and pad first.
Then laid them out and started to glue them down corners first
Then I cut some of the cloth out of the corners and glued the sides down
That's it easy peasy. Then put them in and use a ruler to clean up the corners if any cloth is sticking out
Then I moved on to the ring tray. First I rolled up some strips of padding and glued the edge so they don't unroll
Then I glued the 9 rolls to the backer board...at which point I ran out of glue so I will have to finish this tomorrow night
...but the other 5 drawers are done
Sneak peak of the finish
Next up should be the last post for this project - finish the ring drawer, epoxy the necklace hooks in, install the doors, wax the runners, and take some beauty shots.
Completed the ring drawer
And the completed project pics
...and that's a wrap!
Absolutely beautiful work!! I have learned a lot from following along with this one. From start to finish shows your command of the craft, be very proud of your work and take a couple of days off and have an adult beverage. Thanks for taking us along for the ride.
It was some  really nice work through out the whole project and it came out absolutely superb.  Well done Paul.  I really like the design and wood choices, just the right amount of contrast.
...and its only the first week in July.  Just missed the goal date but a smidge. ;)
  • 26,009 Total Members
  • Joseph b Newest Member ·
